Hi everyone,
I bought a Wireless Soil Moisture Meter XT300 at plantcaretools.com, as what more of you did, but I can't see it in Domoticz.
I've set the RFXtrx433XL to OPUS/ ImaginTronix, tried the receiver both close and a few meters away, tried other channels and tried to set learn just after the flash, as someone here wrote.
But it doesn't pop up, nevertheless.
Does one of you get this meter up and running without the base station XH300?
Can't find the Opus/ ImaginTronix XT300
Re: Can't find the Opus/ ImaginTronix XT300
I have these working in my setup, but I had troubles in the beginning as well. I think you need to enable both ImaginTronix as well as FineOffset/Viking protocol. At least the lather is required. Also check that you accept new hardware in the setup. Signal is not very good, but if you check close range than you should be able to receive it.
ffHakke
Enabling the FineOffset/Viking protocol did the trick. Thanks!!
