Behavior of Heiman Smart Siren and Zigate
Posted: Tuesday 19 May 2020 21:06
I have bought a Heiman Smart Siren HS2WD-E https://zigate.fr/le-materiel-compatibl ... rneheiman/
It is added in Domoticz as a Selector Switch widget with the following values:
0 Stop
10 Alarm
20 Siren
30 Strobe
40 Armed
50 Disarmed
When I select Alarm, Siren, Armed or Disarmed the siren will go off for a few seconds and then it stops.
Also if I select strobe, the light will flash one time.
Is this the normal expected behavior of this device?
I would expect to hear the siren continuously until I select "Stop"
The same with the strobe light.
Or better I would expect 2 widgets (not knowing if the device supports this)
1. switch to switch siren on/off
2. switch to switch strobe light on/off
Alternatively a switch with the following values:
0 stop
10 Siren on
20 Strobe on
30 Strobe and Siren on
Next to that the device apparently has a backup battery. It would be nice to see the status or see if it is activated (someone pulled the device out of the socket or switched the power off.
I have added the export of raw devices out of the Zigate Dashboard.
I am on plugin v 4.7.009, Domoticz v4.11070
0 Stop
10 Alarm
20 Siren
30 Strobe
40 Armed
50 Disarmed
0 stop
10 Siren on
20 Strobe on
