SolarEdge individual optimizer dzVents script
Dols
Post by Dols »
Another way to request data from the SolarEdge inverter.
Why:
- This also requests the individual optimizers data
it is an pure dzVents script that polls layout data from the website. It does not use the official API calls. Instead the API key, it uses the username, password and siteid to get the data. It's the result of one evening hobby. It works, no fancy stuff.
https://github.com/RDols/dzRequestSolarInfo
Regards,
Richard
snellejellep
Re: SolarEdge individual optimizer dzVents script
Post by snellejellep »
great project!
McMelloW
Domoticz version: V2024.1
Post by McMelloW »
Hello Richard,
What is the request you sending to the SolarEdge site?
The site is only updated every 15 minutes
Greetings McMelloW
Dols
Post by Dols »
It does an http get on:
https://monitoring.solaredge.com/solare ... ut/logical
XXXXXXX = Your siteId
It uses basic HTTP authentication. To test, you can login to your regular monitoring page, do a request to above URL (replace XXXXXXX with your siteid) and get JSON info.
It updates more often then 15 minutes, but it's dependend on how often the inverter (and optimizers) update there data. for the optimizers its close to every 5 minutes.
McMelloW
Post by McMelloW »
Dols wrote: Tuesday 19 May 2020 23:27 It does an http get on:
Richard, thanks very much.
A 5 minutes interval is not bad. The monitor page is updated every 15 minutes.
This generates a lot of data. I will look into this.
Greetings McMelloW
freijn
Domoticz version: Stable
Post by freijn »
Hi Richard
Well done. Will give it a go this long weekend.
Question How do you display the data ?
I was thinking Grafana?
Bikey
Domoticz version: 2020.x
Post by Bikey »
That would be nice. Although then it would be more logical to perhaps skip the use of Domoticz altogether and directly post it to a database like Influx (or to MQTT and then to Influx).
Eddiever
Domoticz version: 2022.1
Post by Eddiever »
Maybe I am just a bit stupid. But if I use your script I get:
Solaredge_optimizers.lua:86: attempt to call field 'toBase64' (a nil value)
I triple checked my account data in line 81 - 83. They are correct. What am I overlooking? Manually trying the http get works and I see a lot of data.
80 local function RequestSolardEdge(domoticz)
81    local username = "my username"
82    local password = "my password"
83    local siteID = "my siteID"
84
85    local authorization = string.format("%s:%s", username, password)
86    authorization = string.format("Basic %s", domoticz.utils.toBase64(authorization))
Eddiever wrote: Wednesday 20 May 2020 21:01 Maybe I am just a bit stupid. But if I use your script I get:
I implemented the toBase64 function in dzVents 2.5.2 (domoticz V4.11543). If you are on an older version this script will not work.
Eddiever
Post by Eddiever »
Thanks, I do have a older version on my Synology. Going to upgrade right away. Due to the lack of sun I don't suppose it wil work right away
Eddiever
Post by Eddiever »
That did it! It works:
2020-05-20 22:01:01.843 Status: dzVents: dzRequestSolarInfo : Inverter Inverter 1 = 13508.00 Wh
2020-05-20 22:01:01.843 Status: dzVents: dzRequestSolarInfo : Optimizer Panel 1.1.1 = 916.00 Wh
2020-05-20 22:01:01.843 Status: dzVents: dzRequestSolarInfo : Optimizer Panel 1.1.2 = 983.00 Wh
2020-05-20 22:01:01.843 Status: dzVents: dzRequestSolarInfo : Optimizer Panel 1.1.3 = 968.00 Wh
2020-05-20 22:01:01.843 Status: dzVents: dzRequestSolarInfo : Optimizer Panel 1.1.4 = 1000.50 Wh
2020-05-20 22:01:01.843 Status: dzVents: dzRequestSolarInfo : Optimizer Panel 1.1.5 = 1007.75 Wh
2020-05-20 22:01:01.843 Status: dzVents: dzRequestSolarInfo : Optimizer Panel 1.1.6 = 1009.75 Wh
2020-05-20 22:01:01.843 Status: dzVents: dzRequestSolarInfo : Optimizer Panel 1.1.7 = 1018.00 Wh
2020-05-20 22:01:01.843 Status: dzVents: dzRequestSolarInfo : Optimizer Panel 1.1.8 = 959.75 Wh
2020-05-20 22:01:01.843 Status: dzVents: dzRequestSolarInfo : Optimizer Panel 1.1.9 = 880.75 Wh
2020-05-20 22:01:01.843 Status: dzVents: dzRequestSolarInfo : Optimizer Panel 1.1.10 = 1002.75 Wh
2020-05-20 22:01:01.843 Status: dzVents: dzRequestSolarInfo : Optimizer Panel 1.1.11 = 1007.00 Wh
2020-05-20 22:01:01.843 Status: dzVents: dzRequestSolarInfo : Optimizer Panel 1.1.12 = 1011.00 Wh
2020-05-20 22:01:01.843 Status: dzVents: dzRequestSolarInfo : Optimizer Panel 1.1.13 = 987.75 Wh
2020-05-20 22:01:01.843 Status: dzVents: dzRequestSolarInfo : Optimizer Panel 1.1.14 = 1000.25 Wh
McMelloW
Post by McMelloW »
Dols wrote: Monday 18 May 2020 12:55 Another way to request data from the SolarEdge inverter.
Why:
Regards,
Richard
I find it still a bit frustrating to get all these data from the SolarEdge website, while it is all present in your SolarEdge Inverter.
Your inverter is sending it to the SolarEdge website and the dzVents Script is getting back from the SolarEdge website to you home.
Greetings McMelloW
McMelloW
Post by McMelloW »
Bikey wrote: Wednesday 20 May 2020 19:51 That would be nice. Although then it would be more logical to perhaps skip the use of Domoticz altogether and directly post it to a database like Influx (or to MQTT and then to Influx).
With the use of dzVent, you need Domoticz. dzvents is a part of Domoticz
Greetings McMelloW
Alain
Post by Alain »
This looks interesting. We have two inverters here. Will give it a try next week.
Hue | Zigbee2Mqtt | MQTT | P1 | Xiaomi | RFXCom | Modbus | TP-Link | Node-Red | Grafana |
Rene001
Domoticz version: v2020.2
Post by Rene001 »
Interesting. Going to check it out this weekend.
Rene001
Post by Rene001 »
To find out the name of the panels took some time.
The name of the optimizer in my case is "Panel 1.1.1"
as the site of my inverter
"name":"Module 1.1.1","displayName":"1.1.1"
020-05-21 11:09:02.189 Status: dzVents: Info: ------ Start internal script: SolarEdge Optimizers: HTTPResponse: "SolarEdgeWebRespondse"
2020-05-21 11:09:02.223 Status: dzVents: dzRequestSolarInfo : Inverter Inverter 1 = 7166.00 Wh
2020-05-21 11:09:02.225 Status: dzVents: dzRequestSolarInfo : String String 1.1 = 7235.50 Wh
2020-05-21 11:09:02.226 Status: dzVents: dzRequestSolarInfo : Optimizer Panel 1.1.1 = 637.75 Wh
2020-05-21 11:09:02.227 Status: dzVents: dzRequestSolarInfo : Optimizer Panel 1.1.2 = 629.75 Wh
2020-05-21 11:09:02.228 Status: dzVents: dzRequestSolarInfo : Optimizer Panel 1.1.3 = 555.00 Wh
2020-05-21 11:09:02.228 Status: dzVents: dzRequestSolarInfo : Optimizer Panel 1.1.4 = 639.50 Wh
McMelloW
Post by McMelloW »
Hello Richard,
This works great, well done.
Here is my log output.
2020-05-21 21:05:01.224 Status: dzVents: dzRequestSolarInfo : -=[ Start HTTP Request]=======================================
2020-05-21 21:05:01.225 Status: dzVents: dzRequestSolarInfo : -=[ End ]=====================================================
2020-05-21 21:05:05.659 Status: dzVents: dzRequestSolarInfo : -=[ Start HTTP Response ]=====================================
2020-05-21 21:05:05.660 Status: dzVents: dzRequestSolarInfo : Inverter "Inverter 1" Energy = 22976.00 Wh Current Power = 39.91 W
2020-05-21 21:05:05.660 Status: dzVents: dzRequestSolarInfo : to monitor create an dummy device type="Electric (Instant+Counter) name="Inverter 1"
2020-05-21 21:05:05.660 Status: dzVents: dzRequestSolarInfo : String "String 1.1" Energy = 22926.25 Wh Current Power = 0.00 W
2020-05-21 21:05:05.661 Status: dzVents: dzRequestSolarInfo : to monitor create an dummy device type="Electric (Instant+Counter) name="String 1.1"
2020-05-21 21:05:05.661 Status: dzVents: dzRequestSolarInfo : Optimizer "Panel 1.1.1" Energy = 1944.50 Wh Current Power = 13.23 W
2020-05-21 21:05:05.661 Status: dzVents: dzRequestSolarInfo : to monitor create an dummy device type="Electric (Instant+Counter) name="Panel 1.1.1"
2020-05-21 21:05:05.661 Status: dzVents: dzRequestSolarInfo : Optimizer "Panel 1.1.2" Energy = 1962.25 Wh Current Power = 10.74 W
2020-05-21 21:05:05.661 Status: dzVents: dzRequestSolarInfo : to monitor create an dummy device type="Electric (Instant+Counter) name="Panel 1.1.2"
2020-05-21 21:05:05.661 Status: dzVents: dzRequestSolarInfo : Optimizer "Panel 1.1.3" Energy = 1981.50 Wh Current Power = 9.85 W
2020-05-21 21:05:05.662 Status: dzVents: dzRequestSolarInfo : to monitor create an dummy device type="Electric (Instant+Counter) name="Panel 1.1.3"
2020-05-21 21:05:05.662 Status: dzVents: dzRequestSolarInfo : Optimizer "Panel 1.1.4" Energy = 1952.75 Wh Current Power = 7.31 W
2020-05-21 21:05:05.662 Status: dzVents: dzRequestSolarInfo : to monitor create an dummy device type="Electric (Instant+Counter) name="Panel 1.1.4"
2020-05-21 21:05:05.662 Status: dzVents: dzRequestSolarInfo : Optimizer "Panel 1.1.5" Energy = 1944.50 Wh Current Power = 7.31 W
2020-05-21 21:05:05.662 Status: dzVents: dzRequestSolarInfo : to monitor create an dummy device type="Electric (Instant+Counter) name="Panel 1.1.5"
2020-05-21 21:05:05.662 Status: dzVents: dzRequestSolarInfo : Optimizer "Panel 1.1.6" Energy = 1973.75 Wh Current Power = 8.73 W
2020-05-21 21:05:05.663 Status: dzVents: dzRequestSolarInfo : to monitor create an dummy device type="Electric (Instant+Counter) name="Panel 1.1.6"
2020-05-21 21:05:05.663 Status: dzVents: dzRequestSolarInfo : Optimizer "Panel 1.1.7" Energy = 1848.75 Wh Current Power = 11.37 W
2020-05-21 21:05:05.663 Status: dzVents: dzRequestSolarInfo : to monitor create an dummy device type="Electric (Instant+Counter) name="Panel 1.1.7"
2020-05-21 21:05:05.663 Status: dzVents: dzRequestSolarInfo : Optimizer "Panel 1.1.8" Energy = 1887.25 Wh Current Power = 10.46 W
2020-05-21 21:05:05.663 Status: dzVents: dzRequestSolarInfo : to monitor create an dummy device type="Electric (Instant+Counter) name="Panel 1.1.8"
2020-05-21 21:05:05.663 Status: dzVents: dzRequestSolarInfo : Optimizer "Panel 1.1.9" Energy = 1856.75 Wh Current Power = 9.06 W
2020-05-21 21:05:05.663 Status: dzVents: dzRequestSolarInfo : to monitor create an dummy device type="Electric (Instant+Counter) name="Panel 1.1.9"
2020-05-21 21:05:05.664 Status: dzVents: dzRequestSolarInfo : Optimizer "Panel 1.1.10" Energy = 1900.00 Wh Current Power = 11.53 W
2020-05-21 21:05:05.664 Status: dzVents: dzRequestSolarInfo : to monitor create an dummy device type="Electric (Instant+Counter) name="Panel 1.1.10"
2020-05-21 21:05:05.664 Status: dzVents: dzRequestSolarInfo : Optimizer "Panel 1.1.11" Energy = 1876.00 Wh Current Power = 12.52 W
2020-05-21 21:05:05.664 Status: dzVents: dzRequestSolarInfo : to monitor create an dummy device type="Electric (Instant+Counter) name="Panel 1.1.11"
2020-05-21 21:05:05.664 Status: dzVents: dzRequestSolarInfo : Optimizer "Panel 1.1.12" Energy = 1798.25 Wh Current Power = 8.59 W
2020-05-21 21:05:05.664 Status: dzVents: dzRequestSolarInfo : to monitor create an dummy device type="Electric (Instant+Counter) name="Panel 1.1.12"
2020-05-21 21:05:05.664 Status: dzVents: dzRequestSolarInfo : -=[ End ]=====================================================
Greetings McMelloW
McMelloW
Post by McMelloW »
Hello Richard,
Is there no figure for the Total Lifetime Energy? (Totale energie) I could not find it in the test output.
imo This a counter within the Inverter? At least it is also available on the monitor homepage.
Greetings McMelloW
freijn
Post by freijn »
I muat be doing something stupid but this is the only output I get
2020-05-22 19:34:00.531 Status: dzVents: dzRequestSolarInfo : -=[ Start HTTP Request]=======================================
2020-05-22 19:34:00.531 Status: dzVents: dzRequestSolarInfo : -=[ End ]=====================================================
any hint ?
I do net get how the
callback = 'SolarEdgeWebResponse'
should work, any hint ??
McMelloW
Post by McMelloW »
Did you fill in your email, password and SiteID?
It looks like you are getting no response on the HTTP Request
Greetings McMelloW
