Hello there,
I would like to buy a RFXtrx433XL device. But i'm afraid that not support my all 433mhz sensors.
My devices:
- Kerui Motion detector (supported)
- dooya 1602 remote (supported)
- Kerui doorbell - self powered (no info)
- Noname WS2032 weather station (no info)
Some Info. Kerui Doorbell is not compatible other Kerui security devices ( i saw that you already supported this) but i successfull able to set it with rtl_433. You found a detailed issue here(you also found here the correct settings and a sample cu8 file):
https://github.com/merbanan/rtl_433/issues/1350
.cu8 file
https://github.com/merbanan/rtl_433/fil ... 0k.cu8.zip
here my config that work with 250k sample rate:
decoder {
n=kerui_doorbell,
m=OOK_PWM,
s=68,
l=264,
g=500,
r=1800,
match={14}e1d0,
The weather station is similar state, we already set it with rtl_433. Detailed info:
https://github.com/merbanan/rtl_433/issues/1200
And the implementation:
https://github.com/merbanan/rtl_433/blo ... s/ws2032.c
So see the code. My question is that coding is supported with this device or able to imlement it in the future somehow this device? Because if i order it i would like to cancel all odher my RF gateways (rtl_433, Sonoff RF Bridge...) and use only with this device.
Some question before buy this device.
