Function within dzVents script?  [Solved]
doh
Post by doh »
I have a dzVents script that performs the same tasks 2 or 3 times depending on whether it was triggered by a timer or by one of a number of devices.
Is it possible to define a function within that script which I can call repeatedly for each case?
I know you can create global "helper" functions, but I'd prefer to keep it within the one script file.
dlube
Re: Function within dzVents script?  [Solved]
Post by dlube »
For sure :D
Have a look to the example below
	execute = function(dz, item)
          local function myFunction(variable)
               do your stuff
               return result1, result2
local a, b = myFunction(myVariable)
you can call this function from your code like you do with helpers.
Raspbian Buster on Raspberry pi 3 B+ Domoticz Version: 2023.2 (build 15474)
