isSystem event not set to true when occurs  [SOLVED]
dlube
Post by dlube »
Here below the dump of the item variable when system event occurs
2020-05-16 11:07:17.441 Status: dzVents: Start internal script: Netatmo_Token: Domoticz event: "start"
2020-05-16 11:07:17.442 Status: dzVents: > isGroup: false
2020-05-16 11:07:17.442 Status: dzVents: > isHardware: false
2020-05-16 11:07:17.442 Status: dzVents: > status: info
2020-05-16 11:07:17.442 Status: dzVents: > isTimer: false
2020-05-16 11:07:17.442 Status: dzVents: > isCustomEvent: false
2020-05-16 11:07:17.442 Status: dzVents: > message:
2020-05-16 11:07:17.442 Status: dzVents: > type: start
2020-05-16 11:07:17.442 Status: dzVents: > isDevice: false
2020-05-16 11:07:17.442 Status: dzVents: > isVariable: false
2020-05-16 11:07:17.442 Status: dzVents: > isSystemEvent: true
2020-05-16 11:07:17.442 Status: dzVents: > isSecurity: false
2020-05-16 11:07:17.442 Status: dzVents: > isScene: false
2020-05-16 11:07:17.442 Status: dzVents: > isSystem: false
2020-05-16 11:07:17.442 Status: dzVents: > isHTTPResponse: false
2020-05-16 11:07:17.442 Status: dzVents: > trigger: start
The unknown property "isSystemEvent" is set to true whilst isSystem is still false.
It is maybe easier to change the wiki. :D
Raspbian Buster on Raspberry pi 3 B+ Domoticz Version: 2023.2 (build 15474)
Re: isSystem event not set to true when occurs  [SOLVED]
dlube wrote: Saturday 16 May 2020 11:15 The unknown property "isSystemEvent" is set to true whilst isSystem is still false.
Thx for reporting. Changed the wiki as per your advice :)
