Water usage meter using esp8266 and proximity sensor
azonneveld
Domoticz version: 2024.4
Post by azonneveld »
Perhaps this post is useful for those measuring waterconsumption, or those who want to measure their waterconsumption
To measure the waterusage, I have implemented the watermeter as described here
Initially I used the 'puls counter' in ESPEASY as described by the obove example, but this generated false readings.
The false reading, are caused by the debounce timer. This timer is not restarted when a puls is received during the debounce time.
Therefor I changed the counting to normal switches, using rules.
On System#Boot do
	timerset,6,30 // Data send Timer
Endon
On Rules#Timer=6 do //send data to domoticz
        timerset,6,10 // reset data send timer
	SendToHTTP <domoticz-ip,port>,/json.htm?type=command&param=udevice&idx=<meterIDX>&svalue=[Waterteller#Count]  //send update to domoticz
	TaskValueSet,2,1,0  //reset waterpuls counter
Endon
On Waterpuls#State do
	timerset,7,1
endon
On Rules#Timer=7 do
   	TaskValueSet,2,1,[Waterteller#Count]+1
endon
full description on how to make the watermeter, is available here as PDF
PS how to configure domoticz is not included yet
rpi4 - zigbee2mqtt - roborock - espeasy - rfxcom - homewizard p1 - otgw - homebridge - surveillance station - egardia - goodwe (sems&modbus) - open weather map - wol - BBQ detection - rsync backup - zendure
jeroenkl
Re: Water usage meter using esp8266 and proximity sensor
Post by jeroenkl »
thxs!
THBR
Post by THBR »
I also use the 'puls counter' in ESPEASY as described by the above example, and also many false readings (high value peaks). Tried many settings without positive results.
So I disabled the counter in ESPEASY and made the two new devices as described in the attached PDF. However In Domoticz I get no readings of waterusage.
What's going wrong?
Thanks.
Rules Set 1.jpg (24.08 KiB) Viewed 7265 times
Image 3.jpg (27.33 KiB) Viewed 7265 times
Image 1.jpg (65.93 KiB) Viewed 7265 times
Gravityz
Post by Gravityz »
i think this design is not the best one.
also when you copy espeasy scripts you can not use them 1:1 if the setup is different.
i am using the pulsecounter without any problems but you need to know what is causing the false or spike pulses.
most of the time this is hardware related.
to help you out
i see 2 things which definately are not right.
TaskValueSet,2,1,0 writes value 0 into task 2, first entry(in your case DHT22 Temperatrure)
so this needs to be
TaskValueSet,4,1,0 (set the state back to zero.
the other
needs to be
TaskValueSet,5,1,[Waterteller#Count]+1 (the counter is incremented.
personaly i do not think you need al those timers
if you get a pulse
go increment the counter
send that counter to domoticz
i think the Waterpulse state follows the state of the switch so if the switch is on it is 1, if not it is 0
so the trigger should be
On Waterpuls#State=1 do
increment counter
send it to domoticz
reset the state to zero so it does not get triggered multiple times
also on the switch you created you ned to specify a debounce time otherwise if keeps on bouncing
start with 100ms
hope this helps
THBR
Post by THBR »
Hi Gravityz,
Thanks for the info and sorry for the late response.
I am a rookie in this field...
I have implemented your tips and changes and in esp easy both devices seem to work fine now. Used liters are now displayed in esp easy under "count:".
However, the data (used liters) is not visible in Domoticz. There the counter remains at zero/is not updated?
But if I in the browser e.g. input
192.***.*.***:8080/json.htm?type=command&param=udevice&idx=141&svalue=15 results a status/title "ok"/"updated" and then the water counter in Domoticz is updated fine!
Furthermore, no errors in the logs of ESP easy and Domoticz. I am using version ESP_Easy_mega_20220328_normal_ESP8266_4M1M Mar 28 2022.
The other devices in esp easy (P1 en DHT22 work fine).
Any idea what could be the cause of this?
Regards, Theo.
Gravityz
Post by Gravityz »
and if you try this
SendToHTTP 192.168.1.xx,8080,/json.htm?type=command&param=udevice&idx=141&nvalue=0&svalue=[Waterteller#Count]
THBR
Post by THBR »
Yes, that worked!
But, pff... now the actual value of the count in esp asy, e.g. 852, keeps increasing the waterteller in domoticz with 852 every 7? seconds without consuming water (a kind of loop). So in Domoticz its continues to increase by 852 liters every 7? second
My updated rules (devices unchanged):
On System#Boot do
Endon
SendToHTTP 192.168.0.144,8080,/json.htm?type=command&param=udevice&idx=141&nvalue=0&svalue=[Waterteller#Count]
TaskValueSet,4,1,0 //reset waterpuls counter
Endon
timerset,7,1
endon
On Rules#Timer=7 do
endon
A part of the esp easy log (debug), see attachment.
Thanks again!
log.txt
(15.35 KiB) Downloaded 192 times
