help with dzVents 2020.2 dim value  [Solved]
colint
Post by colint »
Hello All,
I am trying to get a dzVents script working but i have no succes.
The script i am using is from this topic viewtopic.php?f=59&t=29345
The problem is that de dim value is not changing at the times set is the script.
here is the script:
return
   on =
      devices = { 'Kinderkamer' },
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'dim based on time'
   execute = function(dz, item)
        dz.log('Kinderkamer state: ' .. item.state,dz.LOG_DEBUG)
        if item.active and item.lastUpdate.secondsAgo > 4 then
                if dz.time.matchesRule('at 09:00-21:00') then
                    item.dimTo(100).silent()
                    item.dimTo(20).silent()
        elseif item.lastUpdate.secondsAgo > 4 then
            item.dimTo(0).silent()
here is de log:
2020-05-09 11:24:36.478 Status: dzVents: Info: Handling events for: "Kinderkamer", value: "On"
2020-05-09 11:24:36.478 Status: dzVents: Info: dim based on time: ------ Start internal script: Kinderkamer dimstand: Device: "Kinderkamer (Z-wave stick)", Index: 42
2020-05-09 11:24:36.478 Status: dzVents: Debug: dim based on time: Kinderkamer state: On
2020-05-09 11:24:36.478 Status: dzVents: Info: dim based on time: ------ Finished Kinderkamer dimstand
My setup is Rpi 4 with AeonTec zwave+ and qubino dimmers
thanks for the help.
Colin
ronaldbro
Re: help with dzVents 2020.2 dim value
Post by ronaldbro »
I think the correct syntax is ‘between 9:00 and 21:00’
colint wrote: Saturday 09 May 2020 11:36 I am trying to get a dzVents script working but i have no succes.
What is your domoticz / dzVents version ?
between build 11886 and 12002 the lastUpdate value was not correctly send to dzVents
@ronaldBro
and
at 09:00-21:00
are both OK
colint
Post by colint »
My Domoticz version is:
Version: 2020.2
Build Hash: b63341bc0
Compile Date: 2020-04-26 13:47:55
dzVents Version: 3.0.2
Python Version: 3.7.3 (default, Dec 20 2019, 18:57:59) [GCC 8.3.0]
colint wrote: Saturday 09 May 2020 19:58 My Domoticz version is: Build Hash: b63341bc0, Compile Date: 2020-04-26 13:47:55
Yes this is one of the builds with the lastUpdate issue.
colint
Post by colint »
If i go back to 2020.1, the issue wil then be fixed?
colint wrote: Saturday 09 May 2020 20:22 If i go back to 2020.1, the issue wil then be fixed?
Domoticz will not allow you to go back if you use the same database. Between these versions database schema changes were applied and domoticz will not revert these changes.
My approach would be to make a good backup of your current domoticz directory and update to latest Beta. Check if everything works ok and if so stay on this version and switch off check for updates in the settings system tab.
If you see other issues then stop domoticz, restore your backup and start domoticz again.
beta's in domoticz are just the latest stable with some bugfixes and new features.
You can see on this wiki page what the changes are in the latest beta compared to latest stable.
colint
Re: help with dzVents 2020.2 dim value  [Solved]
Post by colint »
Updated to beta and it is fixed.
Thanks for your help!
