First of all, I want to thank you who read me but also and especially the developers who do a very good job at the evolution of domoticz!
I have been used now for 5 years with integrated protocols and several homemade arduino and everything is fine.
I allow myself to write to you because I encounter problems with the EnOcean ESP3 and USB300 integration. On / Off commands pass correctly. However, I have roller shutters and I want to be able to use in 4 different modes either to be able to open, close and choose which percentage for opening and which percentage for closing.
These four modes have a problem with home automation car can not send pulses of a second on the actuators (simulate the press of a button on a remote control). As a result, when pressing a control button in domoticz, the store activates for one second then stops and this goes up or down! I tried with several types of buttons in home automation and understood the shutters and it does not work well at all!
With a wall remote control, for the up or down control you need presses for at least 2 seconds depending on what I noticed. A short press on briefly activates the blind. I cannot reproduce this functioning in domoticz.
Could you please add the store functions in the implementation of the protocol?
Version: 2020.2 (build 12017)
Build Hash: d66b49520
Compile Date: 2020-05-04 15:41:20
dzVents Version: 3.0.4
Python Version: 3.7.3 (default, Dec 20 2019, 18:57:59) [GCC 8.3.0]
EnOcean ESP3 USB300 Imcomplete protocol in domoticz?
oxedgar
- Domoticz version: 2020.2
Personal custom devellopements for arduino: Wired Gardena irrigation system, Emphase solar system, ESP8266 DIY for many uses, EnOcean
gerald26
Re: EnOcean ESP3 USB300 Imcomplete protocol in domoticz?
I have exactly the same problem with the same hardware.
It seems that Domoticz sends the same datagrame whether it is an on / off command and a setlevel:
No one to help us?
2020-06-17 10:33:44.879 (Enocean-Stick) Lighting 2 (Volet chambre)
2020-06-17 10:33:44.872 Status: User: ***** initiated a switch command (55/Volet chambre/On)
2020-06-17 10:33:44.874 Status: EnOcean Send: 55 00 07 00 01 11 F6 10 FF 91 BF 84 30 49
2020-06-17 10:33:44.874 Status: EnOcean Send: 55 00 07 00 01 11 F6 00 FF 91 BF 84 20 A7
2020-06-17 10:33:45.087 Status: EnOcean: 02 (01/00) 00
2020-06-17 10:33:45.287 Status: EnOcean: 02 (01/00) 00
2020-06-17 10:34:17.546 (Enocean-Stick) Lighting 2 (Volet chambre)
2020-06-17 10:34:17.539 Status: User: ***** initiated a switch command (55/Volet chambre/Set Level)
2020-06-17 10:34:17.540 Status: EnOcean Send: 55 00 07 00 01 11 F6 10 FF 91 BF 84 30 49
2020-06-17 10:34:17.540 Status: EnOcean Send: 55 00 07 00 01 11 F6 00 FF 91 BF 84 20 A7
2020-06-17 10:34:17.700 Status: EnOcean: 02 (01/00) 00
2020-06-17 10:34:17.900 Status: EnOcean: 02 (01/00) 00 si un bureau en désordre dénote un esprit brouillon, que dire d'un bureau vide
if a messy office denotes a messy mind, what about an empty office
