Error from Osram Motion sensor
thomasbaetge
Domoticz version: 2023.1
Post by thomasbaetge »
I have a strange error in my Domoticz log every minute from my Osram motion sensor (despite the device operation is normal).
2020-05-08 15:32:12.415 Error: (Zigbee) ###### Device with hardware defaut : {'e': 'changed', 'id': '2', 'r': 'sensors', 'state': {'lastupdated': '2020-05-08T13:32:12', 'lowbattery': False, 'presence': False, 'tampered': True}, 't': 'event', 'uniqueid': '00:0d:6f:00:0f:83:fc:9e-01-0500'}
my setup is RPI with 2020.2 stable, deCONZ stick and plugin.
I had this error since I got the sensor, so it does not seem to be related to my domoticz version.
When I run the device over node-red, the errormessage is the same.
Any idea what could be wrong ??
Thanks for your help!
Thorgal789
Re: Error from Osram Motion sensor
Post by Thorgal789 »
Hello, you have explanation here https://github.com/dresden-elektronik/d ... ssues/2672
The modification have been validated, but It will be in deconz version 2.05.76
If you are bored with it, you can edit the plugin.py file search the line
if tampered or lowbattery:
and replace it by
if lowbattery:
But it will be a little bit more complicated to update the plugin after, github will see the file was modified and can cause problem at next "git pull", you probably will need to delete the folder.
thomasbaetge
Cool, thank you very much!!
Thorgal789 wrote: Friday 08 May 2020 17:07 But it will be a little bit more complicated to update the plugin after, github will see the file was modified and can cause problem at next "git pull", you probably will need to delete the folder.
If you do a
git stash
before
git pull
The pull will work. After the pull
git stash apply
will re apply the changes. Check if the change was successful can be done with
git diff
thomasbaetge
Thanks again :)
Thorgal789
Yeah thx a lot @waarren.
I can't try now, but I have so much problem with github, and I have never used "stash"
thomasbaetge
quick update on this one:
the issue got resolved with the phoscon / deCONZ update as promised.
no more silly messages ;)
