Wake-up alarm: Compare .text value (string)  [Solved]
dizzeenl
Post by dizzeenl »
I have made a Auto wake-up alarm script to wake me up in the morning (light, radio and rollershutter).
With a custom switch, the Wakeup selector, i can select: off, auto/calender of multiple time options
The auto/calender options loads a text string from a custom switch (text) where the next calender item is linked into (ical).
The time options (and the second part of the auto/calender option) are using the script below.
	active = true,
		devices = {'Wakeup selector'},
		timer = {'at 04:00'}
	execute = function(domoticz)
		if domoticz.devices('Wakeup selector').levelName == 'Uitgeschakeld' then
		    domoticz.variables('WEKKER').set('00:00')
		elseif domoticz.devices('Wakeup selector').levelName == 'Agenda' then
	        if 	domoticz.devices('Agenda').text == 'D8G' then
	            domoticz.variables('WEKKER').set('05:45')
	        if 	domoticz.devices('Agenda').text == 'IEG' then
	            domoticz.variables('WEKKER').set('06:45')
	        if 	domoticz.devices('Agenda').text == '8IG' then
	            domoticz.variables('WEKKER').set('07:30')
    	    if 	domoticz.devices('Wakeup selector').levelName == '06:17' then
	        if 	domoticz.devices('Wakeup selector').levelName == '06:37' then
	            domoticz.variables('WEKKER').set('06:05')
.... and so on....
As you can see it's not the most perfect way to get the job done.
1. i have troubles to compare the .text (string) form my calendar with the given codes. Somehow it never result in a match. if i print the value in my log it shows identical values with the one to compare with but it refuses to work :cry: .
2. Is there a cleaner option for handling the custom time selections? Because i cannot save the selector.levelName as a time variable i cannot count and say like, "set wekker .levelname minus 30 minutes." (not a big problem, just wondering how to solve this)
any tips/advice to solve this problem?
Re: Wake-up alarm: Compare .text value (string)
dizzeenl wrote: Monday 04 May 2020 23:41 I have made a Auto wake-up alarm script to wake me up in the morning (light, radio and rollershutter).
Can you try with this? I added some extra code to enable you to see what happens That code can be deactivated when the script is ready.
Please feel free to ask for clarification if things are not clear.
return
    active = true,
    on =
        devices =
            'Wakeup selector',
        timer =
            'at 04:00',
    logging =
        level = domoticz.LOG_DEBUG,  -- change to domoticz.LOG_ERROR when testing / development is ready
        marker = 'Wekker',
        local dz = domoticz -- too lazy to type domoticz
        local lodash = dz.utils._
        local agenda = dz.devices('Agenda')   -- virtual text device
        local selector = dz.devices('Wakeup selector') -- selector
        local wekker = dz.variables('WEKKER') -- time variable
        deltaTime = 32
        local function printAttributes(object) -- debug function
            for key, value in pairs(object) do
                if type(value) == 'table' then
                    dz.log(object.name .. ' >> ' .. lodash.str(key) .. ' : (table)',dz.LOG_DEBUG)
                elseif type(value) ~= 'function' then
                    dz.log(object.name .. ' >> ' .. tostring(key) .. ' : ' .. tostring(value),dz.LOG_DEBUG)
        printAttributes(agenda) -- only during development / test
        printAttributes(wekker) -- only during development / test
        function makeMinutes(myTime)  -- produce minutes from hh:mm string
            local pattern = "(%d+)%:(%d+)"
            local hours, minutes = myTime:match(pattern)
            return hours * 60 + minutes
        function makeTimeString(myMinutes) -- produce hh:mm from minutes
            if myMinutes < 0 then
            	myMinutes = myMinutes + 1440
                myMinutes = myMinutes % 1440
            local hours = dz.utils.leadingZeros(math.floor(myMinutes / 60),2)
            local minutes = dz.utils.leadingZeros(math.floor(myMinutes % 60),2)
            return hours .. ':' .. minutes
        local labels =
            ['D8G'] = '05:45',
            ['IEG'] = '06:45',
            ['8IG'] = '07:30',
        if selector.levelName == 'Uitgeschakeld' then
            wekker.set('00:00')
        elseif selector.levelName == 'Agenda' then
            wekker.set(labels[agenda.text])
            wekker.set(makeTimeString(makeMinutes(selector.levelName) - deltaTime))
dizzeenl
Post by dizzeenl »
Thanks for the fast reply. I understand in general how your solution works. i have not enough experience with tables, lodash and other codes you used but it's nice to be able to read how it works :D. The calulation with the delta time works like a charm. Many thanks 8-)
Converting the agenda string into a label gif still a nil as result.
"2020-05-05 12:26:21.584 Error: Error updating variable WEKKER: Not a valid time notation (HH:MM)"
2020-05-05 12:26:21.246 Status: User: Admin initiated a switch command (910/Wakeup selector/Set Level)
2020-05-05 12:26:21.355 Status: dzVents: Debug: Dumping domoticz data to /home/pi/Domoticz/scripts/dzVents/domoticzData.lua
2020-05-05 12:26:21.480 Status: dzVents: Debug: Processing device-adapter for Wakeup selector: Switch device adapter
2020-05-05 12:26:21.481 Status: dzVents: Debug: dzVents version: 3.0.4
2020-05-05 12:26:21.481 Status: dzVents: Debug: Event triggers:
2020-05-05 12:26:21.481 Status: dzVents: Debug: - Device: Wakeup selector
2020-05-05 12:26:21.556 Status: dzVents: Info: Handling events for: "Wakeup selector", value: "Agenda"
2020-05-05 12:26:21.557 Status: dzVents: Info: Wekker: ------ Start internal script: 02 WEKKER_HANDLER 2: Device: "Wakeup selector (VIRTUAL)", Index: 910
2020-05-05 12:26:21.560 Status: dzVents: Debug: Wekker: Processing device-adapter for Agenda: Text device
2020-05-05 12:26:21.561 Status: dzVents: Debug: Wekker: Agenda >> isDevice : true
2020-05-05 12:26:21.561 Status: dzVents: Debug: Wekker: Agenda >> baseType : device
2020-05-05 12:26:21.562 Status: dzVents: Debug: Wekker: Agenda >> timedOut : true
2020-05-05 12:26:21.562 Status: dzVents: Debug: Wekker: Agenda >> deviceType : General
2020-05-05 12:26:21.562 Status: dzVents: Debug: Wekker: Agenda >> hardwareTypeValue : 15
2020-05-05 12:26:21.562 Status: dzVents: Debug: Wekker: Agenda >> hardwareID : 7
2020-05-05 12:26:21.562 Status: dzVents: Debug: Wekker: Agenda >> rawData : (table)
2020-05-05 12:26:21.562 Status: dzVents: Debug: Wekker: Agenda >> isGroup : false
2020-05-05 12:26:21.562 Status: dzVents: Debug: Wekker: Agenda >> idx : 911
2020-05-05 12:26:21.562 Status: dzVents: Debug: Wekker: Agenda >> signalLevel : 12
2020-05-05 12:26:21.562 Status: dzVents: Debug: Wekker: Agenda >> switchTypeValue : 0
2020-05-05 12:26:21.562 Status: dzVents: Debug: Wekker: Agenda >> text : L8G
2020-05-05 12:26:21.563 Status: dzVents: Debug: Wekker: Agenda >> deviceSubType : Text
2020-05-05 12:26:21.563 Status: dzVents: Debug: Wekker: Agenda >> bState : false
2020-05-05 12:26:21.563 Status: dzVents: Debug: Wekker: Agenda >> id : 911
2020-05-05 12:26:21.563 Status: dzVents: Debug: Wekker: Agenda >> hardwareName : VIRTUAL
2020-05-05 12:26:21.563 Status: dzVents: Debug: Wekker: Agenda >> lastUpdate : (table)
2020-05-05 12:26:21.563 Status: dzVents: Debug: Wekker: Agenda >> _adapters : (table)
2020-05-05 12:26:21.563 Status: dzVents: Debug: Wekker: Agenda >> isTimer : false
2020-05-05 12:26:21.563 Status: dzVents: Debug: Wekker: Agenda >> name : Agenda
2020-05-05 12:26:21.563 Status: dzVents: Debug: Wekker: Agenda >> icon : text
2020-05-05 12:26:21.563 Status: dzVents: Debug: Wekker: Agenda >> isSecurity : false
2020-05-05 12:26:21.563 Status: dzVents: Debug: Wekker: Agenda >> _data : (table)
2020-05-05 12:26:21.564 Status: dzVents: Debug: Wekker: Agenda >> active : false
2020-05-05 12:26:21.564 Status: dzVents: Debug: Wekker: Agenda >> isHTTPResponse : false
2020-05-05 12:26:21.564 Status: dzVents: Debug: Wekker: Agenda >> hardwareId : 7
2020-05-05 12:26:21.564 Status: dzVents: Debug: Wekker: Agenda >> sValue : L8G
2020-05-05 12:26:21.564 Status: dzVents: Debug: Wekker: Agenda >> nValue : 0
2020-05-05 12:26:21.564 Status: dzVents: Debug: Wekker: Agenda >> _state : L8G
2020-05-05 12:26:21.564 Status: dzVents: Debug: Wekker: Agenda >> isScene : false
2020-05-05 12:26:21.564 Status: dzVents: Debug: Wekker: Agenda >> protected : false
2020-05-05 12:26:21.564 Status: dzVents: Debug: Wekker: Agenda >> unit : 1
2020-05-05 12:26:21.564 Status: dzVents: Debug: Wekker: Agenda >> deviceId : 00082911
2020-05-05 12:26:21.565 Status: dzVents: Debug: Wekker: Agenda >> changed : false
2020-05-05 12:26:21.565 Status: dzVents: Debug: Wekker: Agenda >> switchType : On/Off
2020-05-05 12:26:21.565 Status: dzVents: Debug: Wekker: Agenda >> description :
2020-05-05 12:26:21.565 Status: dzVents: Debug: Wekker: Agenda >> _nValue : 0
2020-05-05 12:26:21.565 Status: dzVents: Debug: Wekker: Agenda >> hardwareType : Dummy (Does nothing, use for virtual switches only)
2020-05-05 12:26:21.565 Status: dzVents: Debug: Wekker: Agenda >> isVariable : false
2020-05-05 12:26:21.565 Status: dzVents: Debug: Wekker: Agenda >> state : L8G
2020-05-05 12:26:21.565 Status: dzVents: Debug: Wekker: WEKKER >> isDevice : false
2020-05-05 12:26:21.565 Status: dzVents: Debug: Wekker: WEKKER >> isSystem : false
2020-05-05 12:26:21.565 Status: dzVents: Debug: Wekker: WEKKER >> baseType : variable
2020-05-05 12:26:21.565 Status: dzVents: Debug: Wekker: WEKKER >> isCustomEvent : false
2020-05-05 12:26:21.565 Status: dzVents: Debug: Wekker: WEKKER >> type : time
2020-05-05 12:26:21.565 Status: dzVents: Debug: Wekker: WEKKER >> value : 06:18
2020-05-05 12:26:21.566 Status: dzVents: Debug: Wekker: WEKKER >> isScene : false
2020-05-05 12:26:21.566 Status: dzVents: Debug: Wekker: WEKKER >> changed : false
2020-05-05 12:26:21.566 Status: dzVents: Debug: Wekker: WEKKER >> isHTTPResponse : false
2020-05-05 12:26:21.566 Status: dzVents: Debug: Wekker: WEKKER >> lastUpdate : (table)
2020-05-05 12:26:21.566 Status: dzVents: Debug: Wekker: WEKKER >> isHardware : false
2020-05-05 12:26:21.566 Status: dzVents: Debug: Wekker: WEKKER >> time : (table)
2020-05-05 12:26:21.566 Status: dzVents: Debug: Wekker: WEKKER >> isTimer : false
2020-05-05 12:26:21.566 Status: dzVents: Debug: Wekker: WEKKER >> isSecurity : false
2020-05-05 12:26:21.566 Status: dzVents: Debug: Wekker: WEKKER >> trigger : WEKKER
2020-05-05 12:26:21.566 Status: dzVents: Debug: Wekker: WEKKER >> name : WEKKER
2020-05-05 12:26:21.566 Status: dzVents: Debug: Wekker: WEKKER >> isGroup : false
2020-05-05 12:26:21.566 Status: dzVents: Debug: Wekker: WEKKER >> id : 8
2020-05-05 12:26:21.566 Status: dzVents: Debug: Wekker: WEKKER >> isVariable : true
2020-05-05 12:26:21.567 Status: dzVents: Info: Wekker: ------ Finished 02 WEKKER_HANDLER 2
2020-05-05 12:26:21.567 Status: dzVents: Debug: Commands sent to Domoticz:
2020-05-05 12:26:21.567 Status: dzVents: Debug: - Variable = {["_trigger"]=true, ["value"]="", ["idx"]=8}
2020-05-05 12:26:21.567 Status: dzVents: Debug: =====================================================
2020-05-05 12:26:21.568 Status: EventSystem: Script event triggered: /home/pi/Domoticz/dzVents/runtime/dzVents.lua
(i added L8G as a label)
If i print dz.log("2 "..labels[(agenda.text)],dz.LOG_DEBUG) i got nothing
if i print dz.log("1 "..agenda.text,dz.LOG_DEBUG) i get 1 L8G
Re: Wake-up alarm: Compare .text value (string)  [Solved]
dizzeenl wrote: Tuesday 05 May 2020 12:49 Converting the agenda string into a label gif still a nil as result.
Only thing I can think of is a space, tab or similar in the text.
Below (updated) script will recognize these and filter them out.
return
    active = true,
    on =
        devices =
            'Wakeup selector',
        timer =
            'at 04:00',
    logging =
        marker = 'Wekker',
        local deltaTime = 32
        local function makeMinutes(myTime)  -- produce minutes from hh:mm string
        local function makeTimeString(myMinutes) -- produce hh:mm from minutes
        local function sanitizeString(rawString)
            local sanitizedString = rawString
            if rawString:find('%s') then
                dz.log(rawString .. ' contains blank character(s) ', dz.LOG_DEBUG )
                sanitizedString = rawString:gsub('%s','')
            return sanitizedString
        -- agenda.text = 'D8G\t\r\n' -- test string
        local labels =
            ['D8G'] = '05:45',
            ['IEG'] = '06:45',
            ['8IG'] = '07:30',
            wekker.set('00:00')
            wekker.set(labels[sanitizeString(agenda.text)])
