Multiple zigate admin portals
ronaldbro
Post by ronaldbro »
Hi Pipiche,
I have now two zigates, so also two admin portals... I noticed that it's hard to see if I'm in the right portal. It would really help if we could name them and/or give the menu bar a different color.
Just an idea ;)
Regards Ronald
Geitje
Re: Multiple zigate admin portals
Post by Geitje »
The admin portals have different ports right?
What kind of name/color coding would you suggest? Would not make it much easier compared to the different ports in my opinion?
Zwave, Zigate, RFlink etc.
ronaldbro
Post by ronaldbro »
I do all my domoticz on my iPad and safari doesn't shop the port until you click on the address bar, so I don't see the difference.
There are many good solutions I think like:
- The name in the tab page could be the name of the plugin in domoticz. Now it shows "Dashboard" which has no meaning at all.
- The menu bar could have different background colors. Chosen from a color picker in de plugin settings or a choice from a few predefined colors or banners. Just like office365 does.
- Different themes per instance.
Personaly I like different colors of the menu bar. That way you don't have to look at something but you just see it right away.
pipiche
Post by pipiche »
you should check latest version on beta branch
ronaldbro
Post by ronaldbro »
Hi Pipiche,
I just updated, but don't see any difference. What should I see or do I need to change a setting somewhere?
ronaldbro
Post by ronaldbro »
Ah, now I see. The home button shows the plugin name now :)
Thanks this already helps a lot.
