2 identical scripts, one works on doesn't?  [Solved]
wouterlet
Post by wouterlet »
I'm still starting with DzVents, but I have a light script working:
		devices = {'Lux Zithoek', 'Motion Zithoek'
	execute = function(dz, item)
		if dz.devices('Motion Zithoek').active and
		   item.lux < 25 then
		   dz.devices('Light Wand Voor').setLevel(50)
		if dz.devices('Motion Zithoek') == Off or
            item.lux > 70 then
		   dz.devices('Light Wand Voor').switchOff()
So I copied it and only changed the devices names (Checked them on mistakes) but now it doesn't work:
		devices = {'Lux Bijkeuken', 'Motion Bijkeuken'
		if dz.devices('Motion Bijkeuken').active and
		   item.lux < 25 then
		   dz.devices('Light Bijkeuken').setLevel(50)
		if dz.devices('Motion Bijkeuken') == Off or
            item.lux > 70 then
		   dz.devices('Light Bijkeuken').switchOff()
I get the following error:
2020-05-03 07:27:24.027 Error: dzVents: Error: (3.0.2) An error occurred when calling event handler Licht Bijkeuken DzVents
2020-05-03 07:27:24.027 Error: dzVents: Error: (3.0.2) ...ts/dzVents/generated_scripts/Licht Bijkeuken DzVents.lua:13: attempt to compare number with nil
2020-05-03 07:27:24.125 Error: dzVents: Error: (3.0.2) An error occurred when calling event handler Licht Bijkeuken DzVents
2020-05-03 07:27:24.126 Error: dzVents: Error: (3.0.2) ...ts/dzVents/generated_scripts/Licht Bijkeuken DzVents.lua:9: attempt to compare nil with number
So the problem is in the lux comparation
I use the Neo Coolcam pir and the Fibaro Dimmer 2 on both settings.
What can the problem be?
I tried to put the value in a local,
    local LuxBijkeuken = dz.devices('Lux Bijkeuken')
		   LuxBijkeuken < 35 then
            LuxBijkeuken > 55 then
but then I get another error:
2020-05-03 08:01:13.621 Error: dzVents: Error: (3.0.2) An error occurred when calling event handler Licht Bijkeuken DzVents
2020-05-03 08:01:13.621 Error: dzVents: Error: (3.0.2) ...ts/dzVents/generated_scripts/Licht Bijkeuken DzVents.lua:13: attempt to compare number with table
2020-05-03 08:01:13.719 Error: dzVents: Error: (3.0.2) An error occurred when calling event handler Licht Bijkeuken DzVents
2020-05-03 08:01:13.719 Error: dzVents: Error: (3.0.2) ...ts/dzVents/generated_scripts/Licht Bijkeuken DzVents.lua:13: attempt to compare number with table
boum
Domoticz version: 4.10717
Re: 2 identical scripts, one works on doesn't?
Post by boum »
Please try:
        devices = {'Lux Bijkeuken', 'Motion Bijkeuken', },
        local MotionBijkeuken = dz.devices('Motion Bijkeuken')
        if MotionBijkeuken.active and LuxBijkeuken.lux < 35 then
        elseif MotionBijkeuken.state == 'Off' or LuxBijkeuken.lux > 55 then
dz.devices('bla") returns an object table. You must use a selector to test either the state (.state, .active) or the luminosity (.lux).
In your first change item can be either a lux sensor or a motion sensor. If it is the latest, it won't have a .lux selector.
wouterlet
Re: 2 identical scripts, one works on doesn't?  [Solved]
Post by wouterlet »
Ok, that was the hint!.
Only the Off should be 'Off' Else the light doesn't go off ;)
Thanks again!
