Python Plugin: Neato Botvac vacuum
Bob123bob
Post by Bob123bob »
I just created a Domoticz plugin to control my Neato Botvac D5 vacuum : https://github.com/gilmrt/Domoticz-Botvac-Plugin
I should work with all connected Botvac vacuum from Neato Robotics
This plugin uses the pybotvac library and provides: Status, Control and Schedule status devices
Installation
Before installation plugin check the python3, python3-dev, pip3 is installed for Domoticz plugin system:
sudo apt-get install python3 python3-dev python3-pip
sudo pip3 install pybotvac urllib3 requests
cd domoticz/plugins
git clone https://github.com/gilmrt/Domoticz-Botvac-Plugin.git
Then add and fill your details in the new Botvac vacuum hardware
More details at https://github.com/gilmrt/Domoticz-Botvac-Plugin
In case of issue seen in logs with "KeyError", remove Botvac Robot Vacuum icon in the custom icon section in Domoticz, then restart the plugin by disabling/enabling it
Rob67ert
Re: Python Plugin: Neato Botvac vacuum
Post by Rob67ert »
thank you for this plugin.
I run into a problem. When I start the cleaning, the robot starts and immediately stops cleaning.
When I use the https://github.com/stianaske/pybotvac plugin it works, but I don't like to make all the different buttons.
I use a neato botvac D7 and run Domoticz 2020.2 on a Raspbery Pi.
Gertschi
Post by Gertschi »
I would use this plugin for my Vorwerk VR200. I got it already working with this php script https://github.com/tomrosenback/botvac.
Is it possible to do this and what changes do I have to make?
