after switchOff: how long was that sensor on?
Posted: Saturday 02 May 2020 11:07
by renerene
After a device is switched off I would like to know what the total ON time was. Problem with the lastUpdate() method is, that it only goes back to the OFF event. What is an elegent way to program a .beforeLastUpdate method?
Time line:
[Sensor On] - time1 - [sensor Off] - time 2 - [script trigger] -> how to access time1?
Re: after switchOff: how long was that sensor on?
Posted: Saturday 02 May 2020 11:52
by waaren
renerene wrote: Saturday 02 May 2020 11:07 After a device is switched off I would like to know what the total ON time was. Problem with the lastUpdate() method is, that it only goes back to the OFF event. What is an elegent way to program a .beforeLastUpdate method?
Time line:
Something like this?
return
    on =
        devices =
            'myDevice',
            'myNextDevice',
            'myOtherDevice',
    logging =
        level = domoticz.LOG_DEBUG,  -- switch to LOG_ERROR when OK
        marker = 'time triggered temp reading',
    data =
        onTime =
            initial = {},
    execute = function(dz, item)
        if item.state == 'On' then
            dz.data.onTime[item.name] = dz.time.dDate
        elseif item.state == 'Off' and dz.data.onTime[item.name] and dz.data.onTime[item.name] > 0 then
            dz.log('Device ' .. item.name .. ' was on for ' .. ( dz.time.dDate - dz.data.onTime[item.name] ) .. ' seconds' ,dz.LOG_FORCE)
            dz.data.onTime[item.name] = -1
        elseif item.state == 'Off' and dz.data.onTime[item.name] == -1 then
            dz.log('Device ' .. item.name .. ' was olready switched off.',dz.LOG_FORCE)
        elseif item.state == 'Off' and dz.data.onTime[item.name] == nil then
            dz.log('Start time for device ' .. item.name .. ' is not registered yet',dz.LOG_FORCE)
Re: after switchOff: how long was that sensor on?  [Solved]
Posted: Saturday 02 May 2020 19:45
by renerene
Thank you very much!
Here is the final code. It's purpose it to log warm water usage and have the bathroom light flicker after 10 min shower:
	active = true,
	logging = {
		level = domoticz.LOG_DEBUG, -- comment to use the dzVents global logging setting
		marker = 'dzTapwaterCheck'
	    timer = {'every minute'},
	    devices = {'tapwater'},
	data = {
        onTime = {initial=nil}
	execute = function(dz, device, triggerInfo)
        if dz.devices('tapwater').active then
            if not dz.data.onTime then
                dz.data.onTime=dz.time.dDate
                local minuten=dz.utils.round((dz.time.dDate-dz.data.onTime)/60)
                if minuten==10 then
                    dz.helpers.managedNotify(dz, 'dzTapwaterCheck','Warm water is on for '..minuten..' minutes.', 0, 3, 0) --pushover
                if minuten==10 or minuten==15 or minuten>19 then
                    dz.helpers.managedNotify(dz, 'dzTapwaterCheck','Warm water is on for '..minuten..' minutes.', 0, 5, 0) --speak
                    if dz.devices('pirBadkamer').active then
                        if dz.devices('badkamerLed').active then
                            dz.devices('badkamerLed').switchOff().silent()
                            dz.devices('badkamerLed').switchOn().afterSec(3)
                            dz.devices('badkamerLed').switchOn().silent()
                            dz.devices('badkamerLed').switchOff().afterSec(3)
        elseif dz.data.onTime then --tapwater net uitgezet en onTime nog niet gebruikt in berekening?
            if minuten > 4 then
                dz.helpers.managedNotify(dz, 'dzTapwaterCheck','Warm water was turned off after '..minuten..' minutes.', -1, 3, 0) --pushover
            dz.devices('tapwaterTotaal').incrementCounter(dz.time.dDate-dz.data.onTime) --aantal seconden gebruik beschrijven in totaal
            dz.data.onTime=nil
