After a device is switched off I would like to know what the total ON time was. Problem with the lastUpdate() method is, that it only goes back to the OFF event. What is an elegent way to program a .beforeLastUpdate method?
Time line:
[Sensor On] - time1 - [sensor Off] - time 2 - [script trigger] -> how to access time1?
after switchOff: how long was that sensor on? [Solved]
- waaren
Re: after switchOff: how long was that sensor on?
Something like this?renerene wrote: Saturday 02 May 2020 11:07 After a device is switched off I would like to know what the total ON time was. Problem with the lastUpdate() method is, that it only goes back to the OFF event. What is an elegent way to program a .beforeLastUpdate method?
Time line:
return
on =
devices =
'myDevice',
'myNextDevice',
'myOtherDevice',
logging =
level = domoticz.LOG_DEBUG, -- switch to LOG_ERROR when OK
marker = 'time triggered temp reading',
data =
onTime =
initial = {},
execute = function(dz, item)
if item.state == 'On' then
dz.data.onTime[item.name] = dz.time.dDate
elseif item.state == 'Off' and dz.data.onTime[item.name] and dz.data.onTime[item.name] > 0 then
dz.log('Device ' .. item.name .. ' was on for ' .. ( dz.time.dDate - dz.data.onTime[item.name] ) .. ' seconds' ,dz.LOG_FORCE)
dz.data.onTime[item.name] = -1
elseif item.state == 'Off' and dz.data.onTime[item.name] == -1 then
dz.log('Device ' .. item.name .. ' was olready switched off.',dz.LOG_FORCE)
elseif item.state == 'Off' and dz.data.onTime[item.name] == nil then
dz.log('Start time for device ' .. item.name .. ' is not registered yet',dz.LOG_FORCE)
Re: after switchOff: how long was that sensor on? [Solved]
Thank you very much!
Here is the final code. It's purpose it to log warm water usage and have the bathroom light flicker after 10 min shower:
active = true,
logging = {
level = domoticz.LOG_DEBUG, -- comment to use the dzVents global logging setting
marker = 'dzTapwaterCheck'
timer = {'every minute'},
devices = {'tapwater'},
data = {
onTime = {initial=nil}
execute = function(dz, device, triggerInfo)
if dz.devices('tapwater').active then
if not dz.data.onTime then
dz.data.onTime=dz.time.dDate
local minuten=dz.utils.round((dz.time.dDate-dz.data.onTime)/60)
if minuten==10 then
dz.helpers.managedNotify(dz, 'dzTapwaterCheck','Warm water is on for '..minuten..' minutes.', 0, 3, 0) --pushover
if minuten==10 or minuten==15 or minuten>19 then
dz.helpers.managedNotify(dz, 'dzTapwaterCheck','Warm water is on for '..minuten..' minutes.', 0, 5, 0) --speak
if dz.devices('pirBadkamer').active then
if dz.devices('badkamerLed').active then
dz.devices('badkamerLed').switchOff().silent()
dz.devices('badkamerLed').switchOn().afterSec(3)
dz.devices('badkamerLed').switchOn().silent()
dz.devices('badkamerLed').switchOff().afterSec(3)
elseif dz.data.onTime then --tapwater net uitgezet en onTime nog niet gebruikt in berekening?
if minuten > 4 then
dz.helpers.managedNotify(dz, 'dzTapwaterCheck','Warm water was turned off after '..minuten..' minutes.', -1, 3, 0) --pushover
dz.devices('tapwaterTotaal').incrementCounter(dz.time.dDate-dz.data.onTime) --aantal seconden gebruik beschrijven in totaal
dz.data.onTime=nil
}Who is online
