Read Plex status from dummy device  [Solved]
DomoRies
Post by DomoRies »
i'm using this great script for reading my Plex status: https://www.domoticz.com/forum/viewtopi ... 72&t=31629
Now i would like to have my lighting respond to it so i have a separate script to read the Plex status from the dummy (Switch type: media player). Unfortunately I can't get it to respond. Does anyone have an idea what I'm doing wrong?
This is the script:
	    devices    = {642} -- dz_plex_player IDX number plex media player device
		logging = {	level = domoticz.LOG_DEBUG,
					marker = 'plexlivingroom',
	execute = function(domoticz, plexmedia)
	local playingtest = domoticz.devices(301) -- Dummy test switch playing
	local pausedtest = domoticz.devices(303) -- Dummy test switch paused
	-- when Plex is playing switch on device
	if (plexmedia.state == 7) then
	--if (plexmedia.state == 'playing') then
	--if (plexmedia.nValue == 7) then
		playingtest.switchOn()
	-- when Plex paused switch on device
	elseif (plexmedia.state == 2) then
	--elseif (plexmedia.state == 'paused') then
	--elseif (plexmedia.nValue == 2) then
		pausedtest.switchOn()
Re: Read Plex status from dummy device
DomoRies wrote: Thursday 30 April 2020 16:17 Now i would like to have my lighting respond to it so i have a separate script to read the Plex status from the dummy (Switch type: media player).
can you try this? It does show you the actual state and nValue and check for the states as string
        domoticz.log('plexmedia state: ' .. (plexmedia.state or ' no State?'), domoticz.LOG_DEBUG)
        domoticz.log('plexmedia nvalue: ' .. plexmedia.nValue, domoticz.LOG_DEBUG)
        if (plexmedia.state == '7' ) then
        elseif (plexmedia.state == '2' ) then
DomoRies
Post by DomoRies »
waaren wrote: Thursday 30 April 2020 16:44
Thanks for your reaction.
Strange, I played something in plex and paused but nothing happens in the log. The device is updated by the 'Plex status script'.
Re: Read Plex status from dummy device  [Solved]
DomoRies wrote: Thursday 30 April 2020 16:59 Strange, I played something in plex and paused but nothing happens in the log. The device is updated by the 'Plex status script'.
The posted Plex status script uses the option silent() if you have not removed that it will not trigger any subsequent scripts.
DomoRies
Post by DomoRies »
waaren wrote: Thursday 30 April 2020 17:07
Wow thank you very much! Never thought about that. It works now :D :D
