Washing machine cost after running a load  [Solved]
Ragdag
Post by Ragdag »
I've created a Washing Machine done DzVents script and with the help of waaren also got a beautiful PushOver notification when it's done running
The script senses that a load has started and sets a variable that the washing machine in use, when the power usage is below 6 Watt it will send a PushOver notification. So far so good :)
What I would like to add is a way to include the energie cost of that run but haven't figured out how to do that. I'm using a FIBARO System FGWPE/F Wall Plug Gen5+ to monitor power usage.
The idea is likely that I will need to capture the kWh when a load starts and the kWh when a load is finished and calculate the difference and the cost.
Any pointers would be really welcome, also any feedback on the current script is also welcome as I'm really novice in this.
Current script
local scriptVar = 'Wasmachine'
return
    on =
        timer =
            'every 1 minutes',
        httpResponses =
            scriptVar,
    logging =
        --level = domoticz.LOG_DEBUG,
        marker = scriptVar,
    data =
       WasmachineTimeout = { initial = 1 },
       WasmachineInUse = { initial = 0 },
        if item.isHTTPResponse then
            domoticz.log(item.data,domoticz.LOG_DEBUG)
            return
        local function pushover(PushoverUser, PushoverApp, title, message, priority, sound)
            domoticz.openURL({
                url = 'https://api.pushover.net/1/messages.json',
                method = 'POST',
                callback = scriptVar,
                postData =
                    token = PushoverApp.token,
                    user =  PushoverUser.key,
                    message = message,
                    title = title or 'Pushover from dzVents',
                    priority = priority or 0,
                    sound = sound or 'echo',
        local PushoverUsers =
            ['User1'] = { ['key'] = 'aaaaaaaaaaaaaaaaaaaaaaaaa' },
            ['User2'] = { ['key'] = 'bbbbbbbbbbbbbbbbbbbbbbbbbbb'},
            ['Familie'] = { ['key'] = 'ccccccccccccccccccccccccccccccc'},
        local PushoverApps =
            ['Domoticz'] = { ['token'] = 'dddddddddddddddddddddd' },
            ['Huis'] = { ['token'] = 'eeeeeeeeeeeeeeeeeeeeee' },
            ['Test'] = { ['token'] = 'ffffffffffffffffffffffffffff' },
            ['Was'] = { ['token'] = 'ggggggggggggggggggggggggg' },
        local WasmachineUsage = domoticz.devices(275)
        local WasmachineStandbyUsage = 6.0
        local WasmachineStartUsage = 10.0
        if (WasmachineUsage.actualWatt >= WasmachineStartUsage) and (domoticz.data.WasmachineInUse == 0) then
            domoticz.data.WasmachineInUse = 1
            domoticz.log("Setting Wasmachine in use to yes", domoticz.LOG_INFO)
            domoticz.log("Timeout = " .. domoticz.data.WasmachineTimeout, domoticz.LOG_DEBUG)
            domoticz.log("In use = " .. domoticz.data.WasmachineInUse, domoticz.LOG_DEBUG)
        if (WasmachineUsage.actualWatt >= WasmachineStandbyUsage) and (domoticz.data.WasmachineInUse == 1) and (domoticz.data.WasmachineTimeout == 0) then
            domoticz.data.WasmachineTimeout = 1
            domoticz.log("Reseting counter, not done yet.", domoticz.LOG_DEBUG)
        if (WasmachineUsage.actualWatt <= WasmachineStandbyUsage) and (domoticz.data.WasmachineInUse == 1) then
            if (domoticz.data.WasmachineTimeout > 0) then
                domoticz.data.WasmachineTimeout = domoticz.data.WasmachineTimeout - 1
                domoticz.log(WasmachineUsage.actualWatt .. ' Watt usage, below standby usage, timout minus 1', domoticz.LOG_DEBUG)
                domoticz.log('Timeout = ' .. domoticz.data.WasmachineTimeout, domoticz.LOG_DEBUG)
                domoticz.log('In use = ' .. domoticz.data.WasmachineInUse, domoticz.LOG_DEBUG)
            elseif (domoticz.data.WasmachineTimeout == 0) then
                domoticz.log(''.. WasmachineUsage.actualWatt .. ' Watt verbruik, dus is klaar', domoticz.LOG_INFO)
                domoticz.data.WasmachineInUse = 0
                pushover(PushoverUsers.Familie, PushoverApps.Was, 'Was', 'De was is klaar.', 0, 'magic' )
Re: Washing machine cost after running a load
Ragdag wrote: Thursday 30 April 2020 13:59 What I would like to add is a way to include the energie cost of that run but haven't figured out how to do that. I'm using a FIBARO System FGWPE/F Wall Plug Gen5+ to monitor power usage.
what is the devicetype / subtype of device 275 ? (as seen on the devices tab)
Ragdag
Re: Washing machine cost after running a load  [Solved]
Post by Ragdag »
waaren wrote: Thursday 30 April 2020 14:19
It is a kWh, Electricity (instant and counter)
https://www.domoticz.com/wiki/DzVents:_ ... counter.29
I think I figured it out already, I've added to persistent variables to the script:
    data =
       WasmachineStartkWh = { initial = 0 },
       wasmachineEndkWh = { initial = 0 },
Then when I register the washing machine in use I register the domoticz.data.WasmachineStartkWh = WasmachineUsage.WhTotal if it is finished I do the same but then for the domoticz.data.wasmachineEndkWh = WasmachineUsage.WhTotal
After that it is just a simple formula WasmachineCost = (wasmachineEndkWh - WasmachineStartkWh) * 0.21 which should give me the rough cost, I hope.
The total script will be this.
return
    on =
        timer =
            'every 1 minutes',
        httpResponses =
            scriptVar,
    logging =
        marker = scriptVar,
    data =
            return
            domoticz.openURL({
                method = 'POST',
                postData =
                    message = message,
            ['User1'] = { ['key'] = 'aa' },
            ['User2'] = { ['key'] = 'bb'},
            ['Familie'] = { ['key'] = 'cc'},
            ['Domoticz'] = { ['token'] = 'dd' },
            ['Huis'] = { ['token'] = 'ee' },
            ['Test'] = { ['token'] = 'ff' },
            ['Was'] = { ['token'] = 'gg' },
        local WasmachineCost
                WasmachineCost = (domoticz.data.wasmachineEndkWh - domoticz.data.WasmachineStartkWh) / 1000 * 0.2251
                pushover(PushoverUsers.Familie, PushoverApps.Was, 'Was', 'De was is klaar.\nKosten: €' .. domoticz.utils.round(WasmachineCost, 2), 0, 'magic' )
                domoticz.log('Start kWh = ' .. domoticz.data.WasmachineStartkWh, domoticz.LOG_DEBUG)
                domoticz.log('End kWh = ' .. domoticz.data.wasmachineEndkWh, domoticz.LOG_DEBUG)
                domoticz.log('Washing cost = €' .. domoticz.utils.round(WasmachineCost, 2), domoticz.LOG_DEBUG)
Ragdag
Post by Ragdag »
Right now I have hard coded the price of energie in in the formula, is there a way to get that out of the Domoticz Settings?
Ragdag wrote: Thursday 30 April 2020 15:49 Right now I have hard coded the price of energie in in the formula, is there a way to get that out of the Domoticz Settings?
Yes by calling your
http://<domoticz_ip:domoticz:port>/json.htm?type=settings
you will get a HTTPResponse (json) like below (left out settings not relevant for this question)
"AcceptNewHardware": 1,
"CostEnergy": "0.2149",
"CostEnergyR1": "0.0800",
"CostEnergyR2": "0.0800",
"CostEnergyT2": "0.2149",
"CostGas": "0.6218",
"CostWater": "1.6473",
"status": "OK",
"title": "settings"
Up to you if you want to get this cost this way. (Probably it only changes once a year tops)
Ragdag
Post by Ragdag »
Current script setup works as a charm.
waaren, thank you again for your support!
krizzz
Post by krizzz »
Can you post the whole script with the costs coming from the domoticz json call? Thanks!
Ragdag
Post by Ragdag »
krizzz wrote: Saturday 02 May 2020 9:16 Can you post the whole script with the costs coming from the domoticz json call? Thanks!
I did not integrate that yet.
This is the entire script, did change the utils.round to utils.numdecimals because otherwise 0.20 cents would be displayed as 0.2
return
    on =
        timer =
            'every 1 minutes',
        httpResponses =
            scriptVar,
    logging =
        marker = scriptVar,
    data =
            return
            domoticz.openURL({
                method = 'POST',
                postData =
                    message = message,
            ['User1'] = { ['key'] = 'aaa' },
            ['User2'] = { ['key'] = 'bbb'},
            ['Familie'] = { ['key'] = 'ccc'},
            ['Domoticz'] = { ['token'] = 'ddd' },
            ['Huis'] = { ['token'] = 'eee' },
            ['Test'] = { ['token'] = 'fff' },
            ['Was'] = { ['token'] = 'ggg' },
                pushover(PushoverUsers.Familie, PushoverApps.Was, 'Was', 'De was is klaar. 😘\nKosten: €' .. domoticz.utils.numDecimals(WasmachineCost, 2, 2), 0, 'magic' )
                domoticz.log('Washing cost = €' .. domoticz.utils.numDecimals(WasmachineCost, 2, 2), domoticz.LOG_DEBUG)
swejmansson
Post by swejmansson »
Found this topic and it was kind of what I was looking for. I re-used it, changed and updated it with some more features to fit my needs.
Thanks for sharing Ragdag :)
I posted my script here: viewtopic.php?f=72&t=37844
