Blocky to DzVents Thermo valve  [Solved]
wouterlet
Post by wouterlet »
Hi Guys,
I'm turning my Blocky events to DzVents since these seem more reliable. I attached my Blocky, I translated it to this DzVents:
		devices = {'Thermo Level*'}
	execute = function(dz, item)
	    if item.state ~= 'Off' then
	    dz.devices('CV Switch 2').switchOn()
		dz.log('CV klep boven open')
	elseif item.state == 'Off'.forEach("Thermo Level*") then
        dz.devices('CV Switch 2').switchOff()
Now the log says:
2020-04-30 08:06:33.563 ...s/dzVents/generated_scripts/Thermostaat Klep DzVents.lua:9: 'then' expected near '.'
So I should delete my forEach Should I then write all devices out? Or could I do this on another way?
And maybe have a look if the rest of my script looks fine?
Best regards,
Wouter Lettinga
Thermo valve.png (34.37 KiB) Viewed 850 times
boum
Domoticz version: 4.10717
Re: Blocky to DzVents Thermo valve
Post by boum »
You've got the first part right. If any device triggers the script and the state is not Off, you activate your switch.
If one device triggers and is Off, you'll have to iterate over all devices to check the status. There are several methods to do that in dzVents.
I propose (not tested, sorry):
            local foundDeviceOn = dz.devices().find(function(device)
              -- look for a device with a name starting with "Thermo Level" and state not Off
              return (device.name:find("^Thermo Level") == 1) and (device.state ~= 'Off')
            end)
            if not foundDeviceOn then
              -- all Thermo Level devices are Off
Look at https://www.domoticz.com/wiki/DzVents:_ ... _iterators for documentation
wouterlet
Re: Blocky to DzVents Thermo valve  [Solved]
Post by wouterlet »
Thanks it works great now. I have to look in to it to see how it really works. But it's always nice to learn!
