Battery status of Kerui D026
Posted: Monday 20 April 2020 23:01
by gschmidt
I have 2 Kerui D026 sensors controlled by an RFXtrx433 USB device.
In the Domoticz "Devices" list there is a battery level column which shows a battery symbol for this sensor device.
Is it possible to create a send a "low battery" notification to Telegram script with dzVents?
Re: Battery status of Kerui D026
Posted: Monday 20 April 2020 23:57
by waaren
gschmidt wrote: Monday 20 April 2020 23:01
Below script check all devices with battery levels twice a day and send notification to telegram (if configured in domoticz settings) if batteryLevel is less then 20%
return
on =
timer =
'at 7:07',
'at 19:07',
logging =
level = domoticz.LOG_ERROR,
marker = batteryLevels,
execute = function(dz)
dz.devices().forEach(function(dv)
if dv.batteryLevel and dv.batteryLevel < 20 then
dz.notify('Lowbatteries','Battery level of ' .. dv.name .. ' is ' .. dv.batteryLevel, dz.PRIORITY_NORMAL,'','',dz.NSS_TELEGRAM)
end)
Posted: Tuesday 21 April 2020 23:28
by gschmidt
waaren wrote: Monday 20 April 2020 23:57
Thanx!
Is this a double foreach method, like foreach device do foreach function?
Posted: Tuesday 21 April 2020 23:41
by waaren
gschmidt wrote: Tuesday 21 April 2020 23:28
Ehhhmm ?
dz.devices() -- the collection of all devices in domoticz
foreach(function(dv) ) -- pass every device from above collection to the nameless function as parm dv
Posted: Wednesday 22 April 2020 0:44
by gschmidt
waaren wrote: Tuesday 21 April 2020 23:41
Ehhhmm ?
Okay got it, thanx!
Re: Battery status of Kerui D026 [Solved]
Posted: Wednesday 29 April 2020 18:46
by HvdW
I adapted the script @waaren created for more general use.
local THRESHOLD = 20 -- battery level
return
on =
timer =
--'every minute',
'at sunset',
if dv.batteryLevel and dv.batteryLevel < THRESHOLD then
dz.notify('Lowbatteries','Battery level of ' .. dv.name .. ' is ' .. dv.batteryLevel, dz.PRIORITY_NORMAL)
dz.log('Battery level of ' .. dv.name .. ' is ' .. dv.batteryLevel, dz.LOG_INFO)
elseif dv.batteryLevel and dv.batteryLevel >= THRESHOLD then
end)
The 'every minute is for testing, just like the elseif which displays full batteries in the logs.
Notify can be used for push messages, mail and other.
