Battery status of Kerui D026  [Solved]
gschmidt
Post by gschmidt »
I have 2 Kerui D026 sensors controlled by an RFXtrx433 USB device.
In the Domoticz "Devices" list there is a battery level column which shows a battery symbol for this sensor device.
Is it possible to create a send a "low battery" notification to Telegram script with dzVents?
Re: Battery status of Kerui D026
gschmidt wrote: Monday 20 April 2020 23:01 Is it possible to create a send a "low battery" notification to Telegram script with dzVents?
Below script check all devices with battery levels twice a day and send notification to telegram (if configured in domoticz settings) if batteryLevel is less then 20%
return
    on =
        timer =
            'at 7:07',
            'at 19:07',
    logging =
        level = domoticz.LOG_ERROR,
        marker = batteryLevels,
    execute = function(dz)
        dz.devices().forEach(function(dv)
            if dv.batteryLevel and dv.batteryLevel < 20 then
                dz.notify('Lowbatteries','Battery level of ' .. dv.name .. ' is ' .. dv.batteryLevel, dz.PRIORITY_NORMAL,'','',dz.NSS_TELEGRAM)
        end)
gschmidt
Post by gschmidt »
waaren wrote: Monday 20 April 2020 23:57 Below script check all devices with battery levels twice a day and send notification to telegram (if configured in domoticz settings) if batteryLevel is less then 20%
Thanx!
Is this a double foreach method, like foreach device do foreach function?
gschmidt wrote: Tuesday 21 April 2020 23:28 Is this a double foreach method, like foreach device do foreach function?
Ehhhmm ?
dz.devices() -- the collection of all devices in domoticz
foreach(function(dv) ) -- pass every device from above collection to the nameless function as parm dv
gschmidt
Post by gschmidt »
waaren wrote: Tuesday 21 April 2020 23:41
Ehhhmm ?
Okay got it, thanx!
HvdW
Domoticz version: 2023.2
Re: Battery status of Kerui D026  [Solved]
Post by HvdW »
I adapted the script @waaren created for more general use.
local THRESHOLD = 20  -- battery level
return
    on =
        timer =
            --'every minute',
            'at sunset',
            if dv.batteryLevel and dv.batteryLevel < THRESHOLD then
                dz.notify('Lowbatteries','Battery level of ' .. dv.name .. ' is ' .. dv.batteryLevel, dz.PRIORITY_NORMAL)
                dz.log('Battery level of ' .. dv.name .. ' is ' .. dv.batteryLevel, dz.LOG_INFO)
            elseif dv.batteryLevel and dv.batteryLevel >= THRESHOLD then
        end)
The 'every minute is for testing, just like the elseif which displays full batteries in the logs.
Notify can be used for push messages, mail and other.
Bugs bug me.
