Zigate and Xiaomi light sensor
Posted: Friday 17 April 2020 19:24
by ronaldbro
Hi Pipiche,
I bought a few Xiaomi light sensors (
http://s.aliexpress.com/MJNfMFbI) and successfully added it to domoticz using the latest stable version of the plugin and firmware 3.1a. But I don't get any value updates, lux stays on 0.
Do you know if there are still some issues with this sensor?
The sensor is pretty new and I noticed it is one of the newest sensors added to the zigate plugin. Maybe I should switch to beta for this sensor.
Any advice would be very welcome.
Thanks Ronald
Re: Zigate and Xiaomi light sensor
Posted: Friday 17 April 2020 19:37
by pipiche
ronaldbro wrote: Friday 17 April 2020 19:24
Hi Pipiche,
Thanks Ronald
It is a bit hard to answer.
Could you provide and export of the "Plugin Devices raw (json)" that you can find on the Web Admin Page ?
We have recently added a Lumi Lux sensor on the beta branche, but I need to check if that is the same
Posted: Friday 17 April 2020 19:54
by ronaldbro
Sure, see attached.
Thanks for your help
Posted: Friday 17 April 2020 20:29
by pipiche
Please do update to the laresr version of the plugin (just posted now
Then
1- restart the plugin
2- Remove the Widget created for this device
3- Redo the pairing
The fix was available on beta. I just push it towards stable
Posted: Friday 17 April 2020 20:42
by ronaldbro
Works perfectly
Thanks Pipiche
Posted: Saturday 18 April 2020 10:59
by ronaldbro
Hi Pipiche,
The sensor works perfect and very fast, really like them.
But I noticed that I don't receive the battery state, is this still work in progress? Hopefully I don't need to know the battery state for some time, but they send a lot of updates so I don't expect the battery to last a year. (Hopefully I'm wrong and that would make them absolutely perfect)
Thanks for your good work.
Posted: Sunday 03 May 2020 18:57
by ronaldbro
Hi Pipiche,
Now that I've switched to beta I can confirm that the beta als doesn't report battery status.
Hope it is on your todo list
Regards Ronald
Posted: Sunday 03 May 2020 19:24
by pipiche
It is not on my todo as it works fine on my end. Could you clarify what version of Domoticz you are using ?
Posted: Sunday 03 May 2020 19:29
by ronaldbro
I use 2020.2 stable. I did create the widget using the stable plugin. Should I try to remove the widget and rebind?
Posted: Sunday 03 May 2020 19:44
by ronaldbro
Also the plugin doesn't show the battery percentage and the sensors are in the network for 2 weeks now.
Posted: Sunday 03 May 2020 20:02
by pipiche
could you please provide the export of Plugin Raw Device (JSON) ?
Posted: Sunday 03 May 2020 20:06
by ronaldbro
Sure, see attached
Posted: Sunday 03 May 2020 20:39
by pipiche
SO iI guess we are talking about the new Lux sensor. Please do update the beta branch. This should work now
Posted: Sunday 03 May 2020 20:43
by ronaldbro
Yep. Thanks.
I'll let you know the result
Posted: Sunday 03 May 2020 20:48
by ronaldbro
Great, it works. First one has a reported battery percentage, I'm sure the other two will follow.
Thanks again.
