Bluetooth Beacon Presence issue
alarm_guy1
Post by alarm_guy1 »
Hi guys,
I was running a Beta of Domoticz, and had been for many versions and had Bluetooth Beacon Presence running for a good while and it was working brilliantly.
I had an own fault system crash and since then Bluetooth Beacon Presence wont detect my devices, I have since setup a brand new installation on a Pi4 running 2020.1
This is my log:
2020-04-16 11:17:24.552 (Bluetooth Beacon Presence) Pushing 'onHeartbeatCallback' on to queue
2020-04-16 11:17:24.564 (Bluetooth Beacon Presence) Processing 'onHeartbeatCallback' message
2020-04-16 11:17:24.564 (Bluetooth Beacon Presence) Calling message handler 'onHeartbeat'.
2020-04-16 11:17:26.552 (Bluetooth Beacon Presence) Pushing 'onHeartbeatCallback' on to queue
2020-04-16 11:17:26.568 (Bluetooth Beacon Presence) Processing 'onHeartbeatCallback' message
2020-04-16 11:17:26.568 (Bluetooth Beacon Presence) Calling message handler 'onHeartbeat'.
2020-04-16 11:17:28.553 (Bluetooth Beacon Presence) Pushing 'onHeartbeatCallback' on to queue
2020-04-16 11:17:28.572 (Bluetooth Beacon Presence) Processing 'onHeartbeatCallback' message
2020-04-16 11:17:28.572 (Bluetooth Beacon Presence) Calling message handler 'onHeartbeat'.
2020-04-16 11:17:30.553 (Bluetooth Beacon Presence) Pushing 'onHeartbeatCallback' on to queue
2020-04-16 11:17:30.576 (Bluetooth Beacon Presence) Processing 'onHeartbeatCallback' message
2020-04-16 11:17:30.576 (Bluetooth Beacon Presence) Calling message handler 'onHeartbeat'.
My config.ini is setup like this
[Settings]
; Use different scanner_name if you have several instances for better debugging
scanner_name=Living room
; By default hci0 in RPI3, but you can check with "hciconfig" command
bt_interface=hci0
; Domoticz IP and UDP port where plugin runs
server_ip=xxx.xxx.xxx.xxx
server_port=2221
; Check battery if signal strength >= setting
; Connection will not be established if signal is very low
battery_check_rssi_threshold=-75
; Time to check battery. 24h. Interval check_time + 30min
battery_check_time=03:00
; Attempts to check in time interval when beacon available
battery_check_attempts=2
; Beacon MAC address
[FF:FF:40:01:83:7E]
; For better debug
label=key tag
; Supports battery check for nut3 and miband2
; Can be empty (battery check disabled)
;battery_service_type=nut3
; Signal strength threshold,
; When signal lower the setting -> beacon info will not send to the plugin
; Can be empty (threshold disabled)
rssi_threshold=
[FF:FF:F0:01:2A:CD]
label=Van Nut2
rssi_threshold=
[FF:FF:80:02:F3:1E]
label=Pug Nut2
rssi_threshold=
[FF:FF:40:01:83:7E]
label=Jo Nut2
rssi_threshold=
Image attached of my plugin setup.
I followed the instructions and when installing (I think :-( )
attached is my hcitool scan too
I have tried
sudo hciconfig hci0 down
sudo hciconfig hci0 up
I have no idea where to go from here, any help appreciated, it has got to be something silly i bet
Cheers
