add Hikvision doorbel as camera Topic is solved
Basssment
Domoticz version: 4.9700
Post by Basssment »
I've been struggeling with my doorbel (hikvision ds-6003-wip) and adding it to domoticz.
I can't seem to find the right url to connect to it.
I use it with the hikconnect app now but also have the doorbell connected to my synology nas.
Next step woul be adding it to domoticz.
Does someone have any experience with this or other hikvision cams and adding them to domoticz.
I only seem to get connected via rtsp and bij logging in via http
Help would realy be appriciated :)
Bas
beont
Re: add Hikvision doorbel as camera
Post by beont »
I have the same doorbell series from hikvision and added it to domoticz.
In my case:
Protocol: http
Port: 80
ImageURL: ISAPI/Streaming/channels/101/picture
Works the same as other hikvision camera's.
Basssment
Post by Basssment »
beont,
You are my hero!!
Been searching correct url for almost a year. :o
It works thank you!
kniazio
Domoticz version: 3.7243
Post by kniazio »
Maybe someone also knows the url for Eken
Basssment
Post by Basssment »
beont wrote: Saturday 18 April 2020 14:19 Hi,
In my case:
Protocol: http
Port: 80
@beont
Was hoping you also know how to put the livestream to dashticz?
I can create a button with a snapshot url now
But when i open the stream it does not show it.
It keeps loading
I used :
http://USER:[email protected]:80/IS ... 01/picture
hoeby
Domoticz version: V2022.1
Post by hoeby »
Basssment wrote: Wednesday 22 April 2020 17:12
@beont
It keeps loading
I used :
Try :
ISAPI/Streaming/channels/102/httppreview
You need to setup your second video stream to mjpeg in your hikvision camera. This stream will be maximum 640x480
You could test first in chrome/firefox if the string Works, before adding it to dashticz.
Don't use edge or internet Explorer. They don't show the stream but going do download the stream to your harddrive
Hikvision document with url information
https://www.google.com/url?sa=t&source= ... _c4xjnnQCX
beont
Post by beont »
I'm a bit disappointed in the doorbell though, i did a lot of research to find the value when somebody presses the doorbell button, but i couldn't find a way. (isapi documentation) If someone has more information, please share :-)
Basssment
Post by Basssment »
hoeby wrote: Wednesday 22 April 2020 19:24
@beont
It keeps loading
I used :
Try :
Unfortunatly i cant set the second stream to mjpeg. Only Option is H264 :(
hoeby
Post by hoeby »
Basssment wrote: Sunday 26 April 2020 8:43Unfortunatly i cant set the second stream to mjpeg. Only Option is H264 :(
Sorry i don't have a hikvision doorbell, to search for options. What i have written works on a hikvision camera.
H264 isn't going to work with domoticz. That is a rtsp stream. Domoticz can't work with that kind of streams
ssk17051980
Domoticz version: 2023.2
Post by ssk17051980 »
i have this intercom : DS-KV8113-WME1(B)
i try to "mount" the camera in domoticz, but no succes
ISAPI/Streaming/channels/102/httppreview - no working
ISAPI/Streaming/channels/101/picture - no working
ssk17051980 wrote: Wednesday 18 October 2023 8:33 i have this intercom : DS-KV8113-WME1(B)
A quick google led me to https://www.use-ip.co.uk/forum/threads/ ... -url.7231/
Support capture device image through ISAPI protocol.
/ISAPI/Streaming/channels/1/picture?snapShotImageType=JPEG&videoResolutionWidth=1280&videoResolutionHeight=720&imageQuality=better
ssk17051980
thx
i already try this, no results
I just hope that someone has a solution that is not yet published on the net
Did you update the firmware? As it seems to be released only recently.
