Program to backup DZ database with DB version in name
erem
Domoticz version: 2021.1
Post by erem »
L.S.,
i run various versions of domoticz, and it seems every version has a different database format.
there is a database version in the domoticz database table preferences, but i did not want to open every database
to inspect the version number.
so i wrote attached program extract-dz-db-version to return the version number of the database.
you could use it like this.
#!/bin/bash
# purpose: show usage of extract-dz-db-version
# Version	Date		Reason
# 0.0.1		2020-04-05	initial release
STRING="$( ./extract-dz-db-version  /home/pi/domoticz/domoticz.db)"
echo Domoticz Database version is $STRING
# example usage
# /usr/bin/curl -s http://127.0.0.1:8080/backupdatabase.php >/path/to/domoticz.db.$STRING
i hope others have a use for this, so i share the code in the hope somebody will benefit from it.
extract-dz-db-version.c
(4.22 KiB) Downloaded 29 times
Regards,
Rob
Mooms
Domoticz version: 2023.01
Re: Program to backup DZ database with DB version in name
Post by Mooms »
Thank you Rob this is very helpful !
erem wrote: Tuesday 14 April 2020 19:22 L.S.,
Or have a look here
erem
Post by erem »
@waaren,
that is indeed a very useful table.
i see
Version Commit DB
11649 3aa55f248 139
however, with the new versioning scheme i have a hard time relating the version number 2020.1 to version 11649.
the previous scheme would show Version 4.10717 (which is not in the table) for the stable release, where you need to assume the db version is 134
thanks for the link, much appreciated.
Regards,
Rob
