Mounting a network folder
marmachine
Domoticz version: 3.4834
Post by marmachine »
Hi guys,
As i installed RaspiBackup, i'd like to mount a specific folder from my (Synology) NAS as a local folder
Found anough to read about that on Google, it shows that many experience issues with setting up, and so do i, but my answer isn't there :?
What i did:
created a backup folder
sudo mkdir /backup
commandline test seems succesfull
sudo mount -t cifs //192.168.2.250/backup/RaspiBackup_save /backup -o username="user",pass="login",vers=1.0
now to make sure it mounts after boot
sudo nano /etc/fstab
added the following to fstab
//192.168.2.250/backup/RaspiBackup_save /backup cifs comment=systemd.automount,defaults,rw, username="user",pass="login",vers=1.0,uid=1000, gid=46 0 0
After boot i can navigate to the backup folder, but it doesn't show the files. :(
With the manual command it works... what's wrong here?
freijn
Domoticz version: Stable
Re: Mounting a network folder
Post by freijn »
is there no logifle from the autobackup? Something must have failed , I suspect user rights...
EddyG
Post by EddyG »
Isn't there anything in /var/log/syslog and/or dmesg that gives a hint?
Doler
Post by Doler »
Execute following to grant access:
sudo systemctl daemon-reload
sudo systemctl restart remote-fs.target
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Trixie - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
erem
Domoticz version: 2021.1
Post by erem »
if the manual mount works, then the issue must be in your fstab entry.
try
sudo mount -av
that should spit out an error
Regards,
Rob
EddyG
Post by EddyG »
B.t.w. What I do in every 'backup' or other script that I use is:
1. mount remote
2. do stuff
3. unmount remote
For every script I use a different mountpoint, so they can run independently.
This way you can check for problems on the remote and act accordingly.
And after some years of using cifs and nfs next to each other, I choose only to use nfs.
This is what man mount state for the -a option:
Note that it is a bad practice to use mount -a for fstab checking. The recommended solution is findmnt
