Qubino mini dimmer representation mode bug?
Posted: Sunday 12 April 2020 10:03
I'm having an issue with the Qubino Mini dimmer where it's always represented as a switch, rather than a dimmer. This makes it appear as a switch, without slider. The setup is as follows:
- dz version 2020.1
- aeotec OpenZWave USB version: 1.6-1033-g3661f170
I've tried the following:
- exclude and include the node
- set index 5 (working mode) to dimmer prior to adding the device to 'used devices', dunno how to call it otherwise, you know: turning the green arrow in a blue one..
- setting index 5 to switch and dimmer again afterwards
None of these had effect. The device shows all to be expected parameters in dz, so I it's recognized (properly?). Settings I change actually change behavior of the device (such as dimming range). I can also manually dim the bulb by holding the pyhisical switch. So to me it seems a domoticz issue. Any help is greatly appreciated!
- dz version 2020.1
