Qubino mini dimmer representation mode bug?
Ph0tonblast
Post by Ph0tonblast »
I'm having an issue with the Qubino Mini dimmer where it's always represented as a switch, rather than a dimmer. This makes it appear as a switch, without slider. The setup is as follows:
- dz version 2020.1
- aeotec OpenZWave USB version: 1.6-1033-g3661f170
I've tried the following:
- exclude and include the node
- set index 5 (working mode) to dimmer prior to adding the device to 'used devices', dunno how to call it otherwise, you know: turning the green arrow in a blue one..
- setting index 5 to switch and dimmer again afterwards
None of these had effect. The device shows all to be expected parameters in dz, so I it's recognized (properly?). Settings I change actually change behavior of the device (such as dimming range). I can also manually dim the bulb by holding the pyhisical switch. So to me it seems a domoticz issue. Any help is greatly appreciated!
hvoorend
Domoticz version: 2024.2
Re: Qubino mini dimmer representation mode bug?
Post by hvoorend »
Add the device as normal (will be switch type at first instance). Then open the "Switches" tab, look for the switch you just added and chose 'update' (not sure if its is called that way since I use the Dutch domoticz version). On the next screen use the 'Switch type' pull down to change the type to 'dimmer'.
Raspberry Pi 2
Raspbian Bookworm
Aeon zStick Gen5 fw 1.0
RFXCOM USB
Domoticz 2024.2
hvoorend
Post by hvoorend »
Changed language to check for you: On the 'Switches' tab choose 'Edit' on your device (not called 'Update')
Raspberry Pi 2
Raspbian Bookworm
RFXCOM USB
Domoticz 2024.2
