Version: 4.10717
Build Hash: b38b49e5
Compile Date: 2019-05-09 13:04:08
dzVents Version: 2.4.19
Python Version: 3.7.3 (default, Dec 20 2019, 18:57:59) [GCC 8.3.0]
After some efforts to get Domoticz 2020.1 with OpenZwave 1.6 running, which did not succeed.
OpenZwave gave a lot of errors that cannot / couldnot be solved, so I switched back to 4.10717 (stable)
Previous that 'old' stable work perfectly. Now after some days I noticed that some of NeoCoolcam plugs give some problems.
The plugs are switching good as expected, but the extra Info like Current, Voltage, Wattage and kWh Meter is NOT transfered to Domoticz anymore.
This is in the Domoticz log.
2020-04-11 13:38:51.381 Status: OpenZWave: Received timeout notification from HomeID: 4094017987, NodeID: 31 (0x1f)
2020-04-11 13:38:53.209 OpenZWave: Value_Added: Node: 31 (0x1f), CommandClass: METER, Label: Unknown, Instance: 1
I tried pulling the plug from mains and put in back in again.
The plug it self switched normally but the error with "CommandClass: METER, Label: Unknown" remains and the other info is not updated.
When I do a heal of the node, I get after some seconds a timeout notification, but the plug still responds fine to On and Off.
When I look into the zwcfg????.xml file I see some distinct differances.
Would it me possible to stop Domoticz, edit the zwcfg file, and start Domoticz, and then the problem is solved.
I have the same type plug as node 30, So if I make the setting from 30 to 31 in zwcfg file, could that solve the problem?
Anyone any idea???
