Docker image for Domoticz 2020.1
Posted: Friday 10 April 2020 16:19
by Bikey
Does anybody know how to get a working docker image for Domoticz 2020.1?
All the Domoticz images on Docker hub are outdated and won't run, due to the fact that they don't use a Linux version with GLIBC_2.28 or higher.
Re: Docker image for Domoticz 2020.1
Posted: Saturday 18 April 2020 17:55
by DanielHoPe
I am just playing around with it but I have built a couple of images.
https://hub.docker.com/r/danielhoperez/domoticz-builder
I use this image to build domoticz (to avoid bloating the actual domoticz image)
and just 10 minutes ago I've created
which has not been properly tested, it works for my purposes but I am sure that there might be some missing pieces.
Posted: Saturday 18 April 2020 17:58
by sancla
Cool!!!
Posted: Saturday 18 April 2020 21:09
by Bikey
Thanks! Can you also share your Dockerfile?
The image is for amd64 but I would like to build it for a Raspberry Pi 2B so it must be Arm32V7
Posted: Saturday 18 April 2020 23:58
by DanielHoPe
sure
https://github.com/danielhoperez/domoticz-docker
it is still very precarious, and not yet connected with docker hub
Posted: Tuesday 21 April 2020 23:58
by DAVIZINHO
hello
i use the linuxserver image, but i dont know why this docker was not update in the last month
Posted: Wednesday 29 April 2020 11:37
by DAVIZINHO
hello again.
Its posible to migrate a docker of domoticz (linuxserver) to another docker and keep all the config, scripts, etc... ???
Posted: Wednesday 29 April 2020 17:16
by Bikey
Sure, look at the description at:
If you run it with these volume mappings, you can put the data you want to transfer there.
docker run --restart unless-stopped --device /dev/ttyACM1:/dev/ttyACM1 --name=domoticz -e TZ=Europe/Amsterdam -p 6144:6144 -p 1443:1443 -p 8081:8081 -v [DATA_DIR]:/data -v [BACKUPS_DIR]:/opt/domoticz/backups -v [PLUGINS_DIR]:/opt/domoticz/plugins -v [DZSCRIPTS_DIR]:/opt/domoticz/scripts/dzVents
