Docker image for Domoticz 2020.1
Bikey
Domoticz version: 2020.x
Post by Bikey »
Does anybody know how to get a working docker image for Domoticz 2020.1?
All the Domoticz images on Docker hub are outdated and won't run, due to the fact that they don't use a Linux version with GLIBC_2.28 or higher.
DanielHoPe
Re: Docker image for Domoticz 2020.1
Post by DanielHoPe »
I am just playing around with it but I have built a couple of images.
https://hub.docker.com/r/danielhoperez/domoticz-builder
I use this image to build domoticz (to avoid bloating the actual domoticz image)
and just 10 minutes ago I've created
which has not been properly tested, it works for my purposes but I am sure that there might be some missing pieces.
sancla
Post by sancla »
Cool!!!
Check these howto's: https://sancla.com
Bikey
Post by Bikey »
DanielHoPe wrote: Saturday 18 April 2020 17:55 I am just playing around with it but I have built a couple of images.
Thanks! Can you also share your Dockerfile?
The image is for amd64 but I would like to build it for a Raspberry Pi 2B so it must be Arm32V7
DanielHoPe
sure
https://github.com/danielhoperez/domoticz-docker
it is still very precarious, and not yet connected with docker hub
DAVIZINHO
Post by DAVIZINHO »
hello
i use the linuxserver image, but i dont know why this docker was not update in the last month :-(
DAVIZINHO
Post by DAVIZINHO »
hello again.
Its posible to migrate a docker of domoticz (linuxserver) to another docker and keep all the config, scripts, etc... ???
Bikey
Post by Bikey »
Sure, look at the description at:https://hub.docker.com/r/danielhoperez/domoticz
If you run it with these volume mappings, you can put the data you want to transfer there.
docker run --restart unless-stopped --device /dev/ttyACM1:/dev/ttyACM1 --name=domoticz -e TZ=Europe/Amsterdam -p 6144:6144 -p 1443:1443 -p 8081:8081 -v [DATA_DIR]:/data -v [BACKUPS_DIR]:/opt/domoticz/backups -v [PLUGINS_DIR]:/opt/domoticz/plugins -v [DZSCRIPTS_DIR]:/opt/domoticz/scripts/dzVents
