problem when install domoticz on a debian buster
Damien4465
Post by Damien4465 »
Hello !
I have a problem when i would intall domoticz with the "sudo curl -sSL install.domoticz,...."
I validate the choices http/htps the port numbers, the install directory...
And the script abort with an 404 error just after connecting to releases.domoticz.com..
Do you have any idea ?
Damien S.
PS excuse-me for my bad english ! I'm french ;)
sancla
Re: problem when install domoticz on a debian buster
Post by sancla »
Hi Damien,
Try to follow thise guide:
https://sancla.com/domoticz/domoticz-on ... e-vsphere/
I have tested it several days ago and should work for you. Let me know if you need any help...
Check these howto's: https://sancla.com
Damien4465
It is le guide i followed.
My problem is not resolved...
Thank you ! and ave a good weekend.
Damien S.
sancla
Post by sancla »
Could it be a network (or DNS) issue?
Damien4465
I don't think so ! No problem to access to install.domoticz.com just before in the script.
Damien4465
I have an idea ;(
Is it possible that my problem becomes from my 32 bits intel processor ( Celeron N280) ?
Thank you...
Damien
FireWizard
Post by FireWizard »
The Linux download is 64 bits, so will not run on 32 bits processors.
The only 32 bit version available is for Raspberry Pi, etc.
You can try to compile it yourself. See: https://www.domoticz.com/wiki/Build_Dom ... rom_source
