How to send notifications with a delay  [Solved]
gschmidt
Post by gschmidt »
I am trying to create a dzVents script which sends notifications to telegram/Domoticz Log after a Switch is turned ON/OFF.
There must be 4 posibilities:
1. Switch ON -->Notification send (this works)
2. Switch ON -->Notification send 15 minutes after switch is turned ON (not working yet)
2. Switch ON -->Notification send 60 minutes after switch is turned ON (not working yet)
4. Switch OFF -->Notification send (this works)
Here is what I have sofar:
-- Frietpan dzVents script
return
   on = { devices = {'Test'}},
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'Test Schakelaar',
    execute = function(dz, item)
        local token = "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"
        local chatid = XXXXXXXXXXXXXXX
        local msgAan = 'De frietpan is aangezet!'
        local msgKlaar = 'De frietpan is klaar om te frituren!'
        local msgWordt = 'De frietpan staat nog aan en wordt nu uitgezet!'
        local msgUit = 'De frietpan is uitgezet!'
        if (item.state == 'On') then
            os.execute('curl --data chat_id='..chatid..' --data-urlencode "text='..msgAan..'"  "https://api.telegram.org/bot'..token..'/sendMessage" ')
            dz.log(msgAan,dz.LOG_DEBUG)
        elseif (item.state == 'On' and "time is 15 minutes later after switch is turned ON") then
            os.execute('curl --data chat_id='..chatid..' --data-urlencode "text='..msgKlaar..'"  "https://api.telegram.org/bot'..token..'/sendMessage" ')
            dz.log(msgKlaar,dz.LOG_DEBUG)
        elseif (item.state == 'On' and "time is 60 minutes later  after switch is turned ON") then
            item.switchOff();
            os.execute('curl --data chat_id='..chatid..' --data-urlencode "text='..msgWordt..'"  "https://api.telegram.org/bot'..token..'/sendMessage" ')
            dz.log(msgWordt,dz.LOG_DEBUG)
        elseif (item.state == 'Off') then
            os.execute('curl --data chat_id='..chatid..' --data-urlencode "text='..msgUit..'"  "https://api.telegram.org/bot'..token..'/sendMessage" ')
            dz.log(msgUit,dz.LOG_DEBUG)
For the 1st and 2nd ELSEIF I need a value which is a certain amount of time after the Switch is turned ON.
How does this work in dzVents?
Re: How to send notifications with a delay
gschmidt wrote: Tuesday 07 April 2020 11:45
There must be 4 possibilities:
You could use the newly introduced customEvent for this.
Any reason why you don't use the native dz.notify ?
local myDevice =  'Test'
local myEvent = 'Friet'
return
    on =
        devices =
            myDevice,
        customEvent =
            myEvent,
    logging =
        myDevice = dz.devices(myDevice)
        local klaarDelay = 15
        local OffDelay = 60 - klaarDelay
        local function sendMessage(message, emitMinutes)
            -- Native dzVents / domoticz method
            dz.notify(dz.moduleLabel, message, dz.PRIORITY_MODERATE, nil, nil, dz.NSS_TELEGRAM)
            -- OS approach
            -- os.execute('curl --data chat_id='..chatid..' --data-urlencode "text='..msgAan..'"  "https://api.telegram.org/bot'..token..'/sendMessage"  &')
            dz.log(messsage,dz.LOG_DEBUG)
            if emitMinutes ~= nil then dz.emitEvent(myEvent, emitMinutes).afterMin(emitMinutes) end
            --  if emitMinutes ~= nil then dz.emitEvent(myEvent, emitMinutes).afterSec(emitMinutes) end -- for test use seconds
        if item.isDevice and item.state == 'On' then
            sendMessage(msgAan, klaarDelay)
        elseif item.isCustomEvent and myDevice.state == 'On' and tonumber(item.data) == klaarDelay then
            sendMessage(msgKlaar, OffDelay)
        elseif item.isCustomEvent and myDevice.state == 'On' and tonumber(item.data) == OffDelay then
            myDevice.switchOff().silent()
            sendMessage(msgWordt)
            sendMessage(msgUit)
gschmidt
Post by gschmidt »
waaren wrote: Tuesday 07 April 2020 13:06 You could use the newly introduced customEvent for this.
Thanx man, I will study and test the script.
Where can I find the documentation for dzVents customEvent?
waaren wrote: Tuesday 07 April 2020 13:06 Any reason why you don't use the native dz.notify ?
I didn't know that dz.notify existed...just looked for an example and the first one I got was the os.execute example
I guess dz.notify is using the credentials I set for Telegram at the domoticz settings page?
gschmidt
Post by gschmidt »
return
    on =
        devices =
            myDevice,
        customEvent =
            myEvent,
    logging =
            -- OS approach
            sendMessage(msgUit)
I get the following error:
2020-04-07 15:24:27.463 Error: dzVents: Error: (3.0.1) error loading module 'Script #2' from file '/home/pi/domoticz/scripts/dzVents/generated_scripts/Script #2.lua':
2020-04-07 15:24:27.463 ...domoticz/scripts/dzVents/generated_scripts/Script #2.lua:20: '}' expected (to close '{' at line 7) near 'logging'
gschmidt
Post by gschmidt »
I think it was the "on =" closing brace },
After fixing this I got the next error:
2020-04-07 15:29:22.866 Error: dzVents: Error: (3.0.1) Test Schakelaar: An error occurred when calling event handler Script #2
2020-04-07 15:29:22.866 Error: dzVents: Error: (3.0.1) Test Schakelaar: /home/pi/domoticz/dzVents/runtime/Domoticz.lua:115: attempt to concatenate a nil value (local 'subject')
gschmidt wrote: Tuesday 07 April 2020 15:33 I think it was the "on =" closing brace },
I missed an 's' in customEvents :oops:
return
    on =
        devices =
            myDevice,
        customEvents =
            myEvent,
    logging =
        level = domoticz.LOG_DEBUG,  -- change to LOG_ERROR when ok
            -- OS approach
            dz.log(message,dz.LOG_DEBUG)
            -- if emitMinutes ~= nil then dz.emitEvent(myEvent, emitMinutes).afterSec(emitMinutes) end -- for test only
            sendMessage(msgUit)
gschmidt
Post by gschmidt »
But also dzNotify has an error...
when I used the os.execute instead, I got a telegram notification
local token = "xxxxxxxxxxxxxxxxxxxxxxxxxxx"
local chatid = xxxxxxxxxxxxxxx
os.execute('curl --data chat_id='..chatid..' --data-urlencode "text='..message..'"  "https://api.telegram.org/bot'..token..'/sendMessage"  &')
gschmidt
Post by gschmidt »
Your last script has the following error:
2020-04-07 16:03:38.701 Error: dzVents: Error: (3.0.1) Test Schakelaar: An error occurred when calling event handler Script #2
2020-04-07 16:03:38.701 Error: dzVents: Error: (3.0.1) Test Schakelaar: /home/pi/domoticz/dzVents/runtime/Domoticz.lua:115: attempt to concatenate a nil value (local 'subject')
I think it has to do with dz.notify, because when I switched back to the os.execute method, the error was gone and I received a telegram notification
gschmidt
Post by gschmidt »
Script is working, I tested it with 1 and 3 minutes, and this works!
Only dz.notify gives an error and no notifications but with the os.execute it all works fine
What happens if I have turned on the Switch by accident and then turn it OFF, is the "sendMessage(msgAan, klaarDelay)" still send to telegram?
gschmidt wrote: Tuesday 07 April 2020 16:25 Script is working, I tested it with 1 and 3 minutes, and this works!
the dz.notify error is probably related to the use of dz.moduleLabel
This is available in latest Beta's (>= build 11899) If you are on lower build or Stable , you should change that to 'frietpan' (with the quotes)
If you switch it on and within the 15 minutes to off the message klaarDelay will not be send.
gschmidt
Post by gschmidt »
waaren wrote: Tuesday 07 April 2020 18:24
Updated to the latest beta version.
dz.notify is working.....however the message in my telegrambot is “2”, also when switch is turned off
gschmidt
Post by gschmidt »
Changing dz.moduleLabel with ‘frietpan’ is working...
But this way there is no notification sound in telegram...with os.execute there is! Strange :shock:
gschmidt wrote: Tuesday 07 April 2020 22:02 Updated to the latest beta version.
:D Funny bug this is !
What happens is that your script was probably named something like 'script #2'
The domoticz notify function use the # character as separator for the various fields (subject, message, priority, etc.)
internally it is converted to "subject#message#prio#etc"
so you messages was translated into
"script #2#frietpan klaar#2#" with 2 being the message..
I will modify the dzVents function to prevent this behavior.
gschmidt
Post by gschmidt »
waaren wrote: Tuesday 07 April 2020 22:30
Yes, it is called script #2....because it is in testing phase :D :D :D
And are you familiar with the “no sound” notification in telegram, when using dz.notify?
gschmidt wrote: Tuesday 07 April 2020 22:46 And are you familiar with the “no sound” notification in telegram, when using dz.notify?
Some small changes..
I don't know how to force telegram to produce sound. I use other notification subsystems and always without sound.
Do you use the same chatid and token in domoticz settings for telegram as in the os execute ?
local myDevicename = 'Test'
return
    on =
        devices =
            myDevicename,
        customEvents =
            myEvent,
    logging =
        local myDevice = dz.devices(myDevicename)
            local subject = (dz.moduleLabel or 'frietpan'):gsub('#','')
            dz.notify(subject, message, dz.PRIORITY_MODERATE, dz.SOUND_PERSISTENT, nil, dz.NSS_TELEGRAM)
            -- OS approach
        elseif item.isDevice and item.state == 'Off' then
            sendMessage(msgUit)
gschmidt
Post by gschmidt »
I think it is the other way around, by default most communication apps (also Telegram) produce notification sounds. You can modify them to their own needs. But in this case it looks like dz.notify forces Telegram not to produce a notification sound.
Yes I use the same credentials.
gschmidt wrote: Wednesday 08 April 2020 7:54 I think it is the other way around, by default most communication apps (also Telegram) produce notification sounds.
The absence of sound is because of the notification priority. In the script it is set to moderate.
If you change in the script to a higher level you will get sound.
possible levels are
dz.PRIORITY_EMERGENCY
dz.PRIORITY_HIGH
dz.PRIORITY_NORMAL
dz.PRIORITY_MODERATE -- no sound
dz.PRIORITY_LOW -- no sound
gschmidt
Post by gschmidt »
waaren wrote: Wednesday 08 April 2020 9:18
possible levels are
dz.PRIORITY_HIGH
dz.PRIORITY_NORMAL
Your last script is working properly now.
I have played with the levels, and this is working.
So now I can set the level of a notification, based on priority.
Thanx!
gschmidt
Post by gschmidt »
I have another question, maybe you have an answer.
I also use node-red-contrib-cast nodes to send audio notifications for the "Frietpan" Switch to my google home speakers.
Now this is working when I turn the "Frietpan" switch ON or OFF, but the 2 delay notifications I have a problem with:
the Switch ON/OFF message is published through the MQTT node: domoticz/out into the node-red flow, but is it also possible to publish a "domoticz" log message to the MQTT node? Then I could use the domoticz "frietpan" delay messages to send the audio messages parallel
gschmidt wrote: Wednesday 08 April 2020 21:19 I have another question, maybe you have an answer.
using os.execute dzVents can send any MQTT message to any topic. Only thing needed is installed mosquitto on the domoticz system.
Just let me know what you want to send to which topic and when and I will have a look.
