mqtt domoticz/in with blinds percentage
bend94
Post by bend94 »
Hope everything is good for you !
Just a question, i have blinds percentage devices.
How to update the level with a mqtt publish command ?
i tried that to open my blind to 35%
sudo mosquitto_pub -h localhost -m '{ "idx" : "35", "Set Level" : "35" }' -t "domoticz/in"
but i catch this error in domoticz
Error: MQTT: Invalid data received!
please help
Thx
FireWizard
Re: mqtt domoticz/in with blinds percentage
Post by FireWizard »
I assume you want to send the "Set Level" as a string to Domoticz.
Change
into:
sudo mosquitto_pub -h localhost -m '{ "idx" : "35", "svalue" : "35" }' -t "domoticz/in"
bend94
Post by bend94 »
hi FireWizard
Thanks for your reply
in fact this is not a string, as it is a Blind percentage, see below , i want to update the level with MQTT (10%, 20%,...)
Thanks for your help
FireWizard
Is the selector switch an option?
To trigger it, see: https://www.domoticz.com/forum/viewtopic.php?t=20906 (last post)
bend94 wrote: Monday 06 April 2020 16:18 in fact this is not a string, as it is a Blind percentage, see below , i want to update the level with MQTT (10%, 20%,...)
mosquitto_pub -m '{"command" : "switchlight", "idx": 35, "switchcmd": "Set Level" , "level": 35 }' -t domoticz/in
bend94
Post by bend94 »
hi
thanks for your help
it is ok now with that command
just one additionnal info (in case someone is looking for the same cmd)
sudo mosquitto_pub -h localhost -m '{"command": "switchlight","idx": 35,"switchcmd": "Set Level","level" : 1 }' -t "domoticz/in"
level seems to be between 0 and 15, that is to say 0 = 0% and 15 = 100%
best regards
bend94 wrote:hi
best regards
I tested this on a blind percentage device and there it is a one to one relation. So sending 65 results in the blind to be set at 65%.
Verstuurd vanaf mijn ONEPLUS A6003 met Tapatalk
