Time triggers and hard-coding times
pmniemiDomFor
Domoticz version: 2020.1
Post by pmniemiDomFor »
Say you have a dzVents script for switching lights and you have several triggers for both switching them on and switching off. In the execution part of the script, how do you know which trigger was actually triggered? Do you have to do a manual check with hard-coded values that was it the trigger e.g. for switchig the lights off at 09:00?
For now I have done like this:
		timer = {
			'at sunrise',
			'at 05:30',
	execute = function(domoticz, triggeredItem, info)
	    local gardenLights = domoticz.devices(122)
	    local Time = require('Time')
	    local currentTime = Time()
    	    if (currentTime.matchesRule('at 05:30')) then
    	        gardenLights.switchOn()
    	    elseif (currentTime.matchesRule('at sunrise')) then
    	        gardenLights.switchOff()
It feels like bad coding having to hard-code the trigger values and do a lot of checking in the script. There surely must be a better pattern? Can you e.g. have variables and use them both as trigger values and in the script?
Regards,
Peik
Domoticz 2020.1, Raspberry Pi, Buster, Z-wave, Aeotec Z-stick GEN5
Re: Time triggers and hard-coding times
pmniemiDomFor wrote: Sunday 05 April 2020 13:18
local  gardenLightsOn = 'at sunrise'
local  gardenLightsOff = 'at 05:30'
		timer =
			gardenLightsOn,
			gardenLightsOff,
	execute = function(dz)
		if dz.time.matchesRule(gardenLightsOn) then
pmniemiDomFor
Oh, you can do like that? I thought the "locals" must be in the execute function!
Thanks for your advice.
-Peik
amaiorov41
Post by amaiorov41 »
Hello! I work on a moving chart, trying to find a solution how to activate the scene on a timer every 4 days, but I get a global Domoticz error, can anyone help?)
amaiorov41 wrote: Tuesday 07 April 2020 6:53 Hello! I work on a moving chart, trying to find a solution how to activate the scene on a timer every 4 days, but I get a global Domoticz error, can anyone help?)
What do you mean with "a global domoticz error" ?
Check this topic for a dzVents solution to trigger every nth day.
amaiorov41
Thanks, I'll try
