Wrong timeofday daytime,nighttime,...
PVuser
Domoticz version: 2021.1
Post by PVuser »
What's wrong in my mind? How to use it?
I have set the right location in settings and get the right times at the dashboard and with json:
/json.htm?type=command&param=getSunRiseSet
AstrTwilightEnd	"21:42"
AstrTwilightStart	"04:51"
CivTwilightEnd	"20:21"
CivTwilightStart	"06:12"
DayLength	"13:03"
NautTwilightEnd	"21:00"
NautTwilightStart	"05:33"
ServerTime	"2020-04-03 08:26:40"
SunAtSouth	"13:17"
Sunrise	"06:45"
Sunset	"19:48"
status	"OK"
title	"getSunRiseSet"
But if I try to use it in lua:
        print(timeofday['Daytime'])
        print('SunriseInMinutes '..timeofday['SunriseInMinutes'] )
i get wrong times:
 2020-04-03 08:29:39.444 Status: LUA: Nighttime
2020-04-03 08:29:39.444 Status: LUA: SunriseInMinutes 405
...and the SunRiseInMinutes doesn't change the value!?
What I want is to run a script only when it is bright outside
Re: Wrong timeofday daytime,nighttime,...
PVuser wrote: Friday 03 April 2020 8:42 What's wrong in my mind? How to use it?
Sunrise "06:45"
SunriseInMinutes 405 = 6 hours * 60 + 45 is 6:45
This variable will only change once a day at midnight. It contains todays sunrisetime converted to minutes.
If you want to compute with it you also need the current time in minutes which is changed every minute.
PVuser
Post by PVuser »
Now I understand and it works - Many thanks :-)
