Pairing issue konke motion sensor
Posted: Thursday 02 April 2020 10:39
by soulearth
I have receive two konke motion sensor. This model :
https://zigate.fr/produits-konke-compat ... ionsensor/
https://www.amazon.com/Konke-Smart-Auto ... B07QVXNDBS
Normaly, this sensor is compatible with zigate.
I have a problem. The pairing phase no detect the sensor. I have nothing in domoticz log. As if nothing was happening.
I press 10s with a paper clip on the sensor button.
The sensor flashes/blink.
But there is no reaction in domoticz or web GUI Zigate.
The sensor is not seen and there is nothing in the logs in domoticz.
I test with a water sensor xiaomi and i have no pairing issue with this other sensor.
I use domoticz beta last version, zigate plugin beta last version and zigate firmware 3.1c.
Could you help me ? I am available to perform all possible tests.
Best regards,
Soulearth
Re: Pairing issue konke motion sensor
Posted: Thursday 02 April 2020 11:49
by pipiche
soulearth wrote: Thursday 02 April 2020 10:39
Best regards,
Soulearth
I suspect that you are not on Channel 15 as Konke required to be on Channel 15
Posted: Thursday 02 April 2020 11:54
by pipiche
Be ware that moving to a new channel, will required you to re-pair all existing devices to the new channel.
To move to a new channel, you have to use the Plugin Web Admin interface
-> In settings you need to set Channel to 15
-> Go Admin -> Zigate -> Restart Zigate
Posted: Thursday 02 April 2020 12:02
by soulearth
Yes. I am in channel 0 ....
it's a huge constraint. Especially if I have another device that requires another channel.
In any case, thank you for the answer.
Posted: Thursday 02 April 2020 12:58
by pipiche
0 is leaving the Zigate to select the channel. You need to check on whcih channel the Zigate is really (most-likely 11), You can get this information from the Logs, from the Notification Widget in Domoticz (Utility) or via the Web Admin interface -> Tools -> Zigate Infos
What you can try is the following:
- Switch to channel 15 and Reset Zigate
from now, the existing devices are not paired
- do the pairing of the Konke devices
- check that they work
- Switch back to Channel to the previous channel (not 0, but the real one)
- Do a reset again, then the ZIgate will be on the previous channel and your devices should rework
Most-likely, the Konke will switch to this channel also. (at least I have seen that working with 11)
Posted: Thursday 02 April 2020 13:23
by soulearth
Ok I understand. Just a question.
Wich us the method for "reset" zigate ?
Posted: Thursday 02 April 2020 13:25
by pipiche
To reset the Zigate
You have to through the Plugin Web Admin Page -> Admin -> Zigate
- Screenshot 2020-04-02 at 13.24.56.png (142.94 KiB) Viewed 1136 times
Posted: Thursday 02 April 2020 13:47
by soulearth
Ok. Thanks you very much. I never do this procedure...
I have a last question. There is really a chance that konke sensor change of canal ? Why reason sensor will change canal if zigate change?
During the first change in canal 15, my actual sensor will no change...
Posted: Thursday 02 April 2020 14:22
by pipiche
I'm just sharing what I did experienced. Looks like the Konke has such capabilities at least to swicth to Channel 11 (this is what I saw). I have seen few other devices ( Heiman for instance), but also quiet a large number not following the change like Ikea, Xiaomi ....
Posted: Thursday 02 April 2020 14:39
by soulearth
Ok thanks you. I will test.
Posted: Thursday 02 April 2020 16:42
by soulearth
Yes, It Works! I will never found alone.
Thank you !!!
Soulearth
Posted: Thursday 02 April 2020 16:53
by pipiche
Excellent ! Enjoy
