Philips LivingColors 1st gen
Posted: Friday 22 August 2014 15:21
by sebasdomoticz
Experts,
As a noob I would like to connect a Philips LivingColors 1st generation to my RPi running domoticz. Currently I only have 2 hardware devices, the Aeonlabs Z-wave stick and the RFXcom RFXtrx433ext.
On this website http://www.knutsel.org/nl/2009/01/01/li ... generatie/ it is said that the lamp is controlled over the 2,4 Ghz wave. That is probably the reason it is not found in the log file.
Is it possible to connect this lamp to my domoticz. If yes, how?
thnx.
Re: Philips LivingColors 1st gen
Posted: Friday 22 August 2014 16:20
by Derik
Is there a Api?
Posted: Saturday 23 August 2014 11:02
by sebasdomoticz
I have no idea. When a device operates over the 2,4 Ghz channel, can I still use it with domoticz using another antenna?
Posted: Saturday 23 August 2014 14:09
by Derik
sebasdomoticz wrote:I have no idea. When a device operates over the 2,4 Ghz channel, can I still use it with domoticz using another antenna?
No way... Not that simple....
Look voor the api of this thing...
I do have a Hue set working...
http://www.domoticz.com/forum/viewtopic ... hue#p19317
Posted: Monday 25 August 2014 15:50
by Thice
It seems someone designed a way to interface the LivingColors 1st gen over USB by using an Arduino and a custom shield:
http://www.knutsel.org/2010/04/11/assem ... no-shield/
http://www.knutsel.org/2010/01/08/hello-world/
http://www.knutsel.org/2012/09/04/livin ... -in-stock/
It looks like this might be the best way to go. But I guess you will need to write your own hookup to Domoticz.
Posted: Tuesday 09 February 2016 12:18
by daandamhuis
I'm sorry to revive this thread, but did someone manage to get this working? I've bought the shield and added my lamps in the Arduino code and I can control the lights through a serial connection.
Does someone have a Python script that can talk to Arduino through USB Serial Connection of the Raspberry Pi?
Posted: Thursday 14 July 2016 11:32
by mentalTheo
Daan, did you figure out a way to get it working?
Posted: Wednesday 07 September 2016 3:02
by TokTias
Hi !
I have posted my solution of controlling a gen 1 LivingColors lamp using MySensors and Domoticz here : https://forum.mysensors.org/topic/4638/ ... ensor-node
I then also found out that there's another solution here : https://forum.mysensors.org/topic/3080/ ... olors-lamp
Enjoy !
/T
Posted: Saturday 25 November 2017 10:02
by Deboer132
Myloweslife, lowes portal, and so on and also the https://my-loweslife.co Only when you click that; will certainly you be taken.
Posted: Saturday 27 January 2018 12:57
by Allint367
Any of the mass. It features a couple of ergonomic Know More The device's light weight aluminum motor housing.
Posted: Wednesday 14 February 2018 6:29
by Dorothy96
Simply flat-out failed to remember an account password could mymenards which is essential to staff members overall as well as.
