forSec option does not work any more on blind devices
Posted: Tuesday 31 March 2020 19:36
by dlube
Hi All
All is inside the subject.
I managed to open my garage door during 3 sec with the previous stable version of dzVents.
dz.devices("Garage door").switchOff().forSec(3)
With the latest version 3.0.1 I can use open() instead of switchOff but forSec has no effect.
dz.devices("Garage door").open().forSec(3)
Is there another way to open my garage door for 3 seconds?
Re: forSec option does not work any more on blind devices
Posted: Tuesday 31 March 2020 21:31
by waaren
dlube wrote: Tuesday 31 March 2020 19:36
Does the old command
still work ?
My preference is to use this sequence of commands.
garageDoor = dz.devices("Garage door")
garageDoor.cancelQueuedCommands()
garageDoor.open()
garageDoor.stop().afterSec(3) -- or garageDoor.close().afterSec(3) -- if that's what you want.
Posted: Tuesday 31 March 2020 22:47
by dlube
Old code does not work any more.
The door opens and stop when the door is fully opened (20sec after)
I will try yours tomorow.
Thank you
Posted: Wednesday 01 April 2020 18:58
by dlube
Does not work too
I think that this is a regression introduced with the update of the action on blind devices.
Here is the log file
2020-04-01 19:20:21.553 (ENOCEAN PI) Lighting 2 (Cde1 Bouton 3)
2020-04-01 19:20:21.636 Status: dzVents: Debug: Dumping domoticz data to /home/pi/domoticz/scripts/dzVents/domoticzData.lua
2020-04-01 19:20:21.691 Status: dzVents: Debug: Processing device-adapter for Cde1 Bouton 3: Switch device adapter
2020-04-01 19:20:21.691 Status: dzVents: Debug: dzVents version: 3.0.1
2020-04-01 19:20:21.691 Status: dzVents: Debug: Event triggers:
2020-04-01 19:20:21.691 Status: dzVents: Debug: - Device: Cde1 Bouton 3
2020-04-01 19:20:21.738 Status: dzVents: Info: Handling events for: "Cde1 Bouton 3", value: "On"
2020-04-01 19:20:21.738 Status: dzVents: Info: Télécommande Garage: ------ Start internal script: Telecommande: Device: "Cde1 Bouton 3 (ENOCEAN PI)", Index: 232
2020-04-01 19:20:21.743 Status: dzVents: Info: Télécommande Garage: ------ Finished Telecommande
2020-04-01 19:20:21.744 Status: dzVents: Debug: Commands sent to Domoticz:
2020-04-01 19:20:21.744 Status: dzVents: Debug: - Cancel = {["idx"]=203, ["type"]="device"}
2020-04-01 19:20:21.744 Status: dzVents: Debug: - Garage = Off
2020-04-01 19:20:21.744 Status: dzVents: Debug: - Garage = Stop AFTER 3 SECONDS
Posted: Friday 03 April 2020 19:33
by dlube
I found a workaround
door.open()
door.stop().at(os.date("%H:%M:%S",os.time()+3))
How to report it to the developement team?
Posted: Friday 03 April 2020 21:47
by waaren
dlube wrote: Friday 03 April 2020 19:33
How to report it to the development team?
Good that you got it working !
I am co-developer of dzVents and the creator of the .at() method in dzVents. What it does is computing the amount of seconds from now and use that computed value in an afterSec() method. So you can imagine why I am surprised that the
.at(os.date("%H:%M:%S",os.time()+3)) method -- 3 seconds from now
works and the
.afterSec(3) -- 3 seconds from now
does not.
I am very much interested in the log output of both methods. If there is something unexpected I might be able to fix it.
Posted: Saturday 04 April 2020 11:31
by dlube
Sorry, was my mistake
I did a lot of modifications for my tests and the type of the device was not the same.
"Blind inverted" device
The code below is working well:
myDevice.open()
myDevice.stop().afterSec(3)
myDevice.switchOn()
The code below is not working:
"Blind" device
None of the code below is working:
myDevice.open()
myDevice.switchOff()
Hope it help
Posted: Monday 06 April 2020 15:43
by waaren
dlube wrote: Saturday 04 April 2020 11:31
Checked this on all recent Beta's but cannot replicate this. The forSec() is ignored for open() or close() as there is no way dzVents can know what to do when the delay is over. This has been the way it worked from the moment forSec() became available in dzVents.
All other methods work as designed.
Re: forSec option does not work any more on blind devices [SOLVED]
Posted: Monday 06 April 2020 18:52
by dlube
It was working with switchOff().forSec(3) previously.
The problem raized after the update.
For me, open().forSec(x) mean that you would like to open the door during x seconds and stop.
This is usefull with a door which do not accept percentage.
A good way to introduce it should be to create something like this myBlind.open().stopIn(3)
My solution is the following:
I create a switch and manage the state of this switch.
if mySwitch.state == 'On' then
door.open()
door.stop()
and the command to open the door for 3 s
Not very clean but it works.
Thank you for your support.
