forSec option does not work any more on blind devices  [SOLVED]
dlube
Post by dlube »
Hi All
All is inside the subject. ;)
I managed to open my garage door during 3 sec with the previous stable version of dzVents.
dz.devices("Garage door").switchOff().forSec(3)
With the latest version 3.0.1 I can use open() instead of switchOff but forSec has no effect.
dz.devices("Garage door").open().forSec(3)
Is there another way to open my garage door for 3 seconds?
Raspbian Buster on Raspberry pi 3 B+ Domoticz Version: 2023.2 (build 15474)
Re: forSec option does not work any more on blind devices
dlube wrote: Tuesday 31 March 2020 19:36 I managed to open my garage door during 3 sec with the previous stable version of dzVents.
Does the old command
still work ?
My preference is to use this sequence of commands.
garageDoor = dz.devices("Garage door")
garageDoor.cancelQueuedCommands()
garageDoor.open()
garageDoor.stop().afterSec(3)  -- or garageDoor.close().afterSec(3) -- if that's what you want.
dlube
Post by dlube »
Old code does not work any more.
The door opens and stop when the door is fully opened (20sec after) :D
I will try yours tomorow.
Thank you
dlube
Post by dlube »
Does not work too :(
I think that this is a regression introduced with the update of the action on blind devices.
Here is the log file
2020-04-01 19:20:21.553  (ENOCEAN PI) Lighting 2 (Cde1 Bouton 3)
2020-04-01 19:20:21.636  Status: dzVents: Debug: Dumping domoticz data to /home/pi/domoticz/scripts/dzVents/domoticzData.lua
2020-04-01 19:20:21.691  Status: dzVents: Debug: Processing device-adapter for Cde1 Bouton 3: Switch device adapter
2020-04-01 19:20:21.691  Status: dzVents: Debug: dzVents version: 3.0.1
2020-04-01 19:20:21.691  Status: dzVents: Debug: Event triggers:
2020-04-01 19:20:21.691  Status: dzVents: Debug: - Device: Cde1 Bouton 3
2020-04-01 19:20:21.738  Status: dzVents: Info: Handling events for: "Cde1 Bouton 3", value: "On"
2020-04-01 19:20:21.738  Status: dzVents: Info: Télécommande Garage: ------ Start internal script: Telecommande: Device: "Cde1 Bouton 3 (ENOCEAN PI)", Index: 232
2020-04-01 19:20:21.743  Status: dzVents: Info: Télécommande Garage: ------ Finished Telecommande
2020-04-01 19:20:21.744  Status: dzVents: Debug: Commands sent to Domoticz:
2020-04-01 19:20:21.744  Status: dzVents: Debug: - Cancel = {["idx"]=203, ["type"]="device"}
2020-04-01 19:20:21.744  Status: dzVents: Debug: - Garage = Off
2020-04-01 19:20:21.744  Status: dzVents: Debug: - Garage = Stop AFTER 3 SECONDS
dlube
Post by dlube »
I found a workaround
door.open()
door.stop().at(os.date("%H:%M:%S",os.time()+3))
How to report it to the developement team?
dlube wrote: Friday 03 April 2020 19:33 How to report it to the development team?
Good that you got it working !
I am co-developer of dzVents and the creator of the .at() method in dzVents. What it does is computing the amount of seconds from now and use that computed value in an afterSec() method. So you can imagine why I am surprised that the
.at(os.date("%H:%M:%S",os.time()+3)) method -- 3 seconds from now
works and the
.afterSec(3) -- 3 seconds from now
does not.
I am very much interested in the log output of both methods. If there is something unexpected I might be able to fix it.
dlube
Post by dlube »
Sorry, was my mistake :(
I did a lot of modifications for my tests and the type of the device was not the same.
"Blind inverted" device
The code below is working well:
myDevice.open()
myDevice.stop().afterSec(3)
myDevice.switchOn()
The code below is not working:
myDevice.open().forSec(3)
myDevice.switchOn().forSec(3)
"Blind" device
None of the code below is working:
myDevice.open()
myDevice.switchOff().forSec(3)
Hope it help :)
dlube wrote: Saturday 04 April 2020 11:31 I did a lot of modifications for my tests and the type of the device was not the same.
Checked this on all recent Beta's but cannot replicate this. The forSec() is ignored for open() or close() as there is no way dzVents can know what to do when the delay is over. This has been the way it worked from the moment forSec() became available in dzVents.
All other methods work as designed.
dlube
Re: forSec option does not work any more on blind devices  [SOLVED]
Post by dlube »
It was working with switchOff().forSec(3) previously.
The problem raized after the update.
For me, open().forSec(x) mean that you would like to open the door during x seconds and stop.
This is usefull with a door which do not accept percentage.
A good way to introduce it should be to create something like this myBlind.open().stopIn(3)
My solution is the following:
I create a switch and manage the state of this switch.
     if mySwitch.state == 'On' then
          door.open()
          door.stop()
and the command to open the door for 3 s
	mySwitch.switchOn().forSec(3)
Not very clean but it works.
Thank you for your support.
