I've installed two Xiaomi Mi Flora sensors via Python Plugin Manager.
Per Mi Flora I have now 4 devices.
The moisture device is in 'cb' with the correct value.
When I add the device to Dashticz it appears as 'AAN' with a bulb icon.
The conductivity device is presented right in Dashticz.
What can I do to present the right value.
Running Domoticz 2020.1 and Dashticz V3.3.3.1
Xiaomi Mi Flora
Re: Xiaomi Mi Flora
Can you post the json response of the device data?
http://<domoticz ip>/json.htm?type=devices&rid=IDX
Replace IDX with the Domoticz device id of your sensor.
- Domoticz version: 2020beta
Re: Xiaomi Mi Flora
Here is the json output
"ActTime" : 1585676721,
"AstrTwilightEnd" : "22:08",
"AstrTwilightStart" : "05:12",
"CivTwilightEnd" : "20:43",
"CivTwilightStart" : "06:38",
"DayLength" : "12:57",
"NautTwilightEnd" : "21:24",
"NautTwilightStart" : "05:56",
"ServerTime" : "2020-03-31 19:45:21",
"SunAtSouth" : "13:40",
"Sunrise" : "07:12",
"Sunset" : "20:09",
"app_version" : "2020.1 (build 11839)",
"result" :
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 99,
"CustomImage" : 0,
"Data" : "44 cb",
"Desc" : "irrigation advise",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 16,
"HardwareName" : "MiFlowerMate",
"HardwareType" : "Xiaomi Mi Flower Mate",
"HardwareTypeVal" : 94,
"HaveTimeout" : false,
"ID" : "00100002",
"LastUpdate" : "2020-03-31 18:00:17",
"Name" : "MiFlowerMate - #0 Moisture",
"Notifications" : "true",
"PlanID" : "0",
"PlanIDs" :
0
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"SubType" : "Soil Moisture",
"SwitchTypeVal" : 0,
"Timers" : "false",
"Type" : "General",
"TypeImg" : "moisture",
"Unit" : 2,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "223"
"status" : "OK",
"title" : "Devices"
Re: Xiaomi Mi Flora
sensorName = sensorBaseName + "Moisture"
Domoticz.Debug("Creating first sensor, #"+str(sensorNumber))
Domoticz.Debug("Creating first sensor, name: "+str(sensorName))
Domoticz.Device(Name=sensorName, Unit=sensorNumber, TypeName="Soil Moisture", Used=1).Create()
Domoticz.Log("Created device: "+Devices[sensorNumber].Name)
Soil Moisture should be "percentage" in the plugin code
Just change this part in the plugin code plugin.py
Domoticz.Device(Name=sensorName, Unit=sensorNumber, TypeName="Percentage", Used=1).Create()
then delete the plugin and update the plugin
Moisture will then be the right label %
Re: Xiaomi Mi Flora
Thanks, i will look at it tomorrow
