own certificate overruled?
maceddy
Domoticz version: 12723
Post by maceddy »
I got myself a new raspberry pi.
Installed domoticz, restored the database. Everything without issues.
Only thing is I cannot get my ssl certificate to work.
Whatever I do it still checks as *.domoticz.com instead of my own, which had always worked on my previous raspberry.
When I replace the file with a file with just a few ## it errors on starting domoticz on https so it is pointing to the right file.
I even tried to add a different certificate path in the domoticz.sh file in /etc/init.d
Even then it keeps on serving the original domoticz.com certificate...
I am 100% sure my certificate is right. I tried a paid one as well as a letsencrypt (new installation, so I thought i'd give it a try with LE).
I am out of options.. Any ideas?
sancla
Re: own certificate overruled?
Post by sancla »
Wait, hold on...
So you currently serve a ssl certificate for domoticz.com?
That can't be right. *.domoticz.com is probably not your own Domoticz installation but part of the public Domoticz website.
Check these howto's: https://sancla.com
maceddy
Post by maceddy »
No I am not.
That's just the default server_cert.pem
Default certificate
Default certificate
