ZiGate, wrong widget for HUE RGBW bulb
Posted: Saturday 28 March 2020 15:24
by ronaldbro
Hi Pipiche,
I got a new Zigate after the problems I had with the old one. Now the Wifi version so I'm more flexible with the position.
Just started to migrate my devices to the Zigate, but now I get a wrong widget for a Color Hue bulb. It gives me a Level control widget but it is a RGBW bulb.
With the Hue bridge a RGBWWZ widget was created.
Can you please help?
I'm on the latest stable at the moment.
See the log file below and device json attached.
2020-03-28 15:05:59.183 Status: (Zigate) Device Announcement Addr: 963f, IEEE: 0017880104e0af53 Join Flag: 0x00 - join a network through association RSSI: 0
2020-03-28 15:05:59.287 Status: (Zigate) [-] NEW OBJECT: 963f Active Endpoint Response Ep: 0b RSSI: 150
2020-03-28 15:05:59.287 Status: (Zigate) [-] NEW OBJECT: 963f Active Endpoint Response Ep: f2 RSSI: 150
2020-03-28 15:05:59.287 Status: (Zigate) [-] NEW OBJECT: 963f Request Simple Descriptor for Ep: 0b
2020-03-28 15:05:59.288 Status: (Zigate) [-] NEW OBJECT: 963f Request Simple Descriptor for Ep: f2
2020-03-28 15:05:59.390 Status: (Zigate) [-] NEW OBJECT: 963f Simple Descriptor Response EP: 0x0b RSSI: 150
2020-03-28 15:05:59.390 Status: (Zigate) [-] NEW OBJECT: 963f ProfileID c05e
2020-03-28 15:05:59.390 Status: (Zigate) [-] NEW OBJECT: 963f ZDeviceID 0210
2020-03-28 15:05:59.390 Status: (Zigate) [-] NEW OBJECT: 963f Application Version 0000
2020-03-28 15:05:59.390 Status: (Zigate) [-] NEW OBJECT: 963f Cluster IN Count: 09
2020-03-28 15:05:59.391 Status: (Zigate) [-] NEW OBJECT: 963f Cluster In 1: 0000 (Basic)
2020-03-28 15:05:59.391 Status: (Zigate) [-] NEW OBJECT: 963f Cluster In 2: 0003 (Identify)
2020-03-28 15:05:59.391 Status: (Zigate) [-] NEW OBJECT: 963f Cluster In 3: 0004 (Groups)
2020-03-28 15:05:59.391 Status: (Zigate) [-] NEW OBJECT: 963f Cluster In 4: 0005 (Scenes)
2020-03-28 15:05:59.391 Status: (Zigate) [-] NEW OBJECT: 963f Cluster In 5: 0006 (On/Off)
2020-03-28 15:05:59.391 Status: (Zigate) [-] NEW OBJECT: 963f Cluster In 6: 0008 (Level Control)
2020-03-28 15:05:59.391 Status: (Zigate) [-] NEW OBJECT: 963f Cluster In 7: 1000 (Touchlink)
2020-03-28 15:05:59.391 Status: (Zigate) [-] NEW OBJECT: 963f Cluster In 8: 0300 (Colour Control)
2020-03-28 15:05:59.392 Status: (Zigate) [-] NEW OBJECT: 963f Cluster In 9: fc01
2020-03-28 15:05:59.392 Status: (Zigate) [-] NEW OBJECT: 963f Cluster OUT Count: 01
2020-03-28 15:05:59.392 Status: (Zigate) [-] NEW OBJECT: 963f Cluster Out 1: 0019 (Over-the-Air Upgrade)
2020-03-28 15:05:59.443 Status: (Zigate) [-] NEW OBJECT: 963f Simple Descriptor Response EP: 0xf2 RSSI: 150
2020-03-28 15:05:59.443 Status: (Zigate) [-] NEW OBJECT: 963f ProfileID a1e0
2020-03-28 15:05:59.443 Status: (Zigate) [-] NEW OBJECT: 963f ZDeviceID 0061
2020-03-28 15:05:59.443 Status: (Zigate) [-] NEW OBJECT: 963f Application Version 0000
2020-03-28 15:05:59.444 Status: (Zigate) [-] NEW OBJECT: 963f Cluster IN Count: 01
2020-03-28 15:05:59.444 Status: (Zigate) [-] NEW OBJECT: 963f Cluster In 1: 0021
2020-03-28 15:05:59.444 Status: (Zigate) [-] NEW OBJECT: 963f Cluster OUT Count: 01
2020-03-28 15:05:59.444 Status: (Zigate) [-] NEW OBJECT: 963f Cluster Out 1: 0021
2020-03-28 15:06:01.149 Status: (Zigate) [0] NEW OBJECT: 963f Request Node Descriptor
2020-03-28 15:06:01.150 Status: (Zigate) [0] NEW OBJECT: 963f Request Attribute for Cluster 0x0300 to get ColorMode
2020-03-28 15:06:06.185 Status: (Zigate) [1] NEW OBJECT: 963f Model Name: LCT015
2020-03-28 15:06:11.159 Status: (Zigate) [2] NEW OBJECT: 963f Model Name: LCT015
Re: ZiGate, wrong widget for HUE RGBW bulb
Posted: Saturday 28 March 2020 16:06
by pipiche
Please do install the attached file to Domoticz-Zigate/Conf/Certified/Philips (or you can also switch on the beta branch)
Then restart the plugin, remove the previous Widget, and redo the pairing
LCT015.json.zip
(761 Bytes) Downloaded 37 times
Posted: Saturday 28 March 2020 17:09
by ronaldbro
Thanks Pipiche,
It's now created as a RGBWW device (and not RGBWWZ as with the hue bridge). But this is good enough for me :)
Posted: Saturday 28 March 2020 17:55
by pipiche
ronaldbro wrote: Saturday 28 March 2020 17:09 Thanks Pipiche,
try with that one
LCT015.json.zip
(759 Bytes) Downloaded 40 times
Posted: Saturday 28 March 2020 18:58
by ronaldbro
Yep, now it is a RGBWWZ. Thanks Pipiche
