ZiGate, wrong widget for HUE RGBW bulb
ronaldbro
Post by ronaldbro »
Hi Pipiche,
I got a new Zigate after the problems I had with the old one. Now the Wifi version so I'm more flexible with the position.
Just started to migrate my devices to the Zigate, but now I get a wrong widget for a Color Hue bulb. It gives me a Level control widget but it is a RGBW bulb.
With the Hue bridge a RGBWWZ widget was created.
Can you please help?
I'm on the latest stable at the moment.
See the log file below and device json attached.
2020-03-28 15:05:59.183 Status: (Zigate) Device Announcement Addr: 963f, IEEE: 0017880104e0af53 Join Flag: 0x00 - join a network through association RSSI: 0
2020-03-28 15:05:59.287 Status: (Zigate) [-] NEW OBJECT: 963f Active Endpoint Response Ep: 0b RSSI: 150
2020-03-28 15:05:59.287 Status: (Zigate) [-] NEW OBJECT: 963f Active Endpoint Response Ep: f2 RSSI: 150
2020-03-28 15:05:59.287 Status: (Zigate) [-] NEW OBJECT: 963f Request Simple Descriptor for Ep: 0b
2020-03-28 15:05:59.288 Status: (Zigate) [-] NEW OBJECT: 963f Request Simple Descriptor for Ep: f2
2020-03-28 15:05:59.390 Status: (Zigate) [-] NEW OBJECT: 963f Simple Descriptor Response EP: 0x0b RSSI: 150
2020-03-28 15:05:59.390 Status: (Zigate) [-] NEW OBJECT: 963f ProfileID c05e
2020-03-28 15:05:59.390 Status: (Zigate) [-] NEW OBJECT: 963f ZDeviceID 0210
2020-03-28 15:05:59.390 Status: (Zigate) [-] NEW OBJECT: 963f Application Version 0000
2020-03-28 15:05:59.390 Status: (Zigate) [-] NEW OBJECT: 963f Cluster IN Count: 09
2020-03-28 15:05:59.391 Status: (Zigate) [-] NEW OBJECT: 963f Cluster In 1: 0000 (Basic)
2020-03-28 15:05:59.391 Status: (Zigate) [-] NEW OBJECT: 963f Cluster In 2: 0003 (Identify)
2020-03-28 15:05:59.391 Status: (Zigate) [-] NEW OBJECT: 963f Cluster In 3: 0004 (Groups)
2020-03-28 15:05:59.391 Status: (Zigate) [-] NEW OBJECT: 963f Cluster In 4: 0005 (Scenes)
2020-03-28 15:05:59.391 Status: (Zigate) [-] NEW OBJECT: 963f Cluster In 5: 0006 (On/Off)
2020-03-28 15:05:59.391 Status: (Zigate) [-] NEW OBJECT: 963f Cluster In 6: 0008 (Level Control)
2020-03-28 15:05:59.391 Status: (Zigate) [-] NEW OBJECT: 963f Cluster In 7: 1000 (Touchlink)
2020-03-28 15:05:59.391 Status: (Zigate) [-] NEW OBJECT: 963f Cluster In 8: 0300 (Colour Control)
2020-03-28 15:05:59.392 Status: (Zigate) [-] NEW OBJECT: 963f Cluster In 9: fc01
2020-03-28 15:05:59.392 Status: (Zigate) [-] NEW OBJECT: 963f Cluster OUT Count: 01
2020-03-28 15:05:59.392 Status: (Zigate) [-] NEW OBJECT: 963f Cluster Out 1: 0019 (Over-the-Air Upgrade)
2020-03-28 15:05:59.443 Status: (Zigate) [-] NEW OBJECT: 963f Simple Descriptor Response EP: 0xf2 RSSI: 150
2020-03-28 15:05:59.443 Status: (Zigate) [-] NEW OBJECT: 963f ProfileID a1e0
2020-03-28 15:05:59.443 Status: (Zigate) [-] NEW OBJECT: 963f ZDeviceID 0061
2020-03-28 15:05:59.443 Status: (Zigate) [-] NEW OBJECT: 963f Application Version 0000
2020-03-28 15:05:59.444 Status: (Zigate) [-] NEW OBJECT: 963f Cluster IN Count: 01
2020-03-28 15:05:59.444 Status: (Zigate) [-] NEW OBJECT: 963f Cluster In 1: 0021
2020-03-28 15:05:59.444 Status: (Zigate) [-] NEW OBJECT: 963f Cluster OUT Count: 01
2020-03-28 15:05:59.444 Status: (Zigate) [-] NEW OBJECT: 963f Cluster Out 1: 0021
2020-03-28 15:06:01.149 Status: (Zigate) [0] NEW OBJECT: 963f Request Node Descriptor
2020-03-28 15:06:01.150 Status: (Zigate) [0] NEW OBJECT: 963f Request Attribute for Cluster 0x0300 to get ColorMode
2020-03-28 15:06:06.185 Status: (Zigate) [1] NEW OBJECT: 963f Model Name: LCT015
2020-03-28 15:06:11.159 Status: (Zigate) [2] NEW OBJECT: 963f Model Name: LCT015
export.json (2).txt
(5.55 KiB) Downloaded 18 times
pipiche
Re: ZiGate, wrong widget for HUE RGBW bulb
Post by pipiche »
Please do install the attached file to Domoticz-Zigate/Conf/Certified/Philips (or you can also switch on the beta branch)
Then restart the plugin, remove the previous Widget, and redo the pairing
LCT015.json.zip
(761 Bytes) Downloaded 19 times
ronaldbro
Post by ronaldbro »
Thanks Pipiche,
It's now created as a RGBWW device (and not RGBWWZ as with the hue bridge). But this is good enough for me :)
pipiche
Post by pipiche »
ronaldbro wrote: Saturday 28 March 2020 17:09 Thanks Pipiche,
try with that one
LCT015.json.zip
(759 Bytes) Downloaded 19 times
ronaldbro
Post by ronaldbro »
Yep, now it is a RGBWWZ. Thanks Pipiche
