Page 1 of 2
Native Buienradar Hardware options
Posted: Thursday 26 March 2020 18:33
by Brutus
I recently installed the new stable version of Domoticz. The first thing I noticed is the implementation of the native Buienradar hardware in Domoticz.
I now use the plugin version (Buienradar.nl (Weather Lookup)):
https://www.domoticz.com/forum/viewtopi ... buienradar
and would like to use the native version now.
The great thing about the plugin version is you get some options to choose if you want the temperature and humidity sensor separated in two devices or just one.
See the hardware tab here:
The native plugin has only these options:
Difference between the sensors:
For the reading in LUA and so on its easier to have separated sensors. I know as you can see in the plugin thread some people like all the information in one and others like me like the separated sensors. So if there would be an option to make the choice your selves we could server everybody.
Hope to hear something.
Greetings Brutus.
Re: Native Buienradar Hardware options
Posted: Thursday 26 March 2020 21:13
by Peut
It would be a pleasure if al the sensors could be separated. At the moment I use a dZvents script to split the Temp+Hum+Baro sensor, for example. It would be more convenient to make separate sensors in the native Buienradar Hardware.
Hope this could be implemented.
Posted: Thursday 26 March 2020 23:58
by Copitano
I totally agree with that. The plugin version is even smart enough to supplement a missing sensor with the same sensor type from De Bilt station, although I would like to choose the station for de missing sensor myself. For example, Lelystad is much closer to me.
Posted: Thursday 16 April 2020 2:59
by ILoveIOT
Maybe the location (Latitude and Longitude) settings like in other plugin's (WU/Darksky) ?
Now the plugin is not working because 1400km seems too much for the closest location.
Posted: Monday 04 May 2020 7:17
by akamming
on request of "Brutus" i made a small code change allowing to split the temperature, humidity and baro sensors.
https://github.com/akamming/domoticz/tr ... rs_ability
can someone test?
You can build it using the instructions which can be found here : https://www.domoticz.com/wiki/Build_Dom ... rom_source
Just make sure, you checkout the right branch by replacing this line of the instruction on the wiki
git clone https://github.com/domoticz/domoticz.git dev-domoticz
with these 2 lines
git clone https://github.com/akamming/domoticz.git dev-domoticz
git checkout split_buienradar_sensors_ability
by akamming
ILoveIOT wrote: Thursday 16 April 2020 2:59 Maybe the location (Latitude and Longitude) settings like in other plugin's (WU/Darksky) ?
This functionality is already available in the beta channel
Posted: Monday 04 May 2020 8:44
by Brutus
akamming wrote: Monday 04 May 2020 7:17 on request of "Brutus" i made a small code change allowing to split the temperature, humidity and baro sensors.
can someone test?
with these 2 lines
Thnx Akamming!, I've also put a request on Tweakers.net so hopefully someone could test this.
Greetings.
Posted: Monday 04 May 2020 15:34
by ILoveIOT
Thank you, updated to 2020.2 and there its also available, thank you dev team !!!
I noticed that the polling is maybe too quick resulting in a error, plugin is working fine, fine for me just wanna lett some know;
2020-05-04 15:29:20.228 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 09:02:50.422 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 09:08:05.189 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 09:13:25.913 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 09:18:40.981 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 09:24:01.333 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 09:29:16.420 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 09:34:36.776 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 09:39:51.506 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 09:45:11.762 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 09:50:26.475 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 09:55:46.861 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 10:01:01.867 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 10:06:22.488 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 10:11:37.329 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 10:16:57.929 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 10:22:13.014 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 10:27:33.172 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 10:32:47.964 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 10:38:08.236 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 10:43:22.852 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 10:48:43.447 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 10:53:58.582 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 10:59:18.820 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 11:04:33.757 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 11:09:54.013 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 11:15:08.996 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 11:20:29.257 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 11:25:44.229 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 11:31:04.325 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 11:36:19.261 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 11:41:39.534 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 11:46:54.432 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 11:52:14.640 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 11:57:29.671 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 12:02:50.044 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 12:08:04.913 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 12:13:25.230 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 12:18:40.240 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 12:24:00.510 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 12:29:15.475 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 12:34:35.750 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 12:39:50.590 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 12:45:15.546 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 12:46:24.043 Error: AccuWeather: Error getting http data!
2020-05-04 12:50:30.497 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 12:55:51.058 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 13:01:06.109 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 13:06:26.402 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 13:11:41.144 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 13:17:02.164 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 13:22:16.975 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 13:27:37.399 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 13:32:52.230 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 13:38:12.689 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 13:43:27.516 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 13:48:47.987 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 13:54:02.862 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 13:59:22.959 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 14:04:38.219 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 14:09:58.783 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 14:15:13.629 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 14:20:33.977 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 14:25:48.728 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 14:31:08.925 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 14:36:23.782 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 14:41:44.553 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 14:46:59.359 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 14:52:19.982 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 14:57:34.849 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 15:02:55.320 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 15:08:10.128 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 15:13:30.267 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 15:18:45.171 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-04 15:24:05.333 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
Posted: Tuesday 12 May 2020 20:01
by akamming
ILoveIOT wrote: Monday 04 May 2020 15:34 I noticed that the polling is maybe too quick resulting in a error, plugin is working fine, fine for me just wanna lett some know;
this is not a polling issue, but an issue on buienradar api side. This error is caused when there is some serverside error or unavailability
Posted: Tuesday 12 May 2020 20:19
by akamming
Brutus wrote: Monday 04 May 2020 8:44
Greetings.
it's been working on my system quite ok for serveral days now. I made the PR (https://github.com/domoticz/domoticz/pull/4158)
Posted: Tuesday 12 May 2020 20:30
by ILoveIOT
Looks more like a protection from buienradar, to avoid unnecessary client requests, seems they allow every 10min (what is allot I guess) and kill any connection sooner then 10 min, resulting in a error for us.
Here you can see the plugin works, but after 4 sec there is another new connection, 5 min later again, I believe they have a limit for the client on polling.
2020-05-12 19:53:48.606 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-12 19:58:53.549 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-12 20:03:54.263 (Buienradar) Temp + Humidity + Baro (Volkel)
2020-05-12 20:03:54.273 (Buienradar) Temp (Volkel Grond 10cm)
2020-05-12 20:03:54.283 (Buienradar) Temp (Volkel gevoel)
2020-05-12 20:03:54.292 (Buienradar) Wind (Volkel Wind)
2020-05-12 20:03:54.296 (Buienradar) General/Visibility (Zichtbaar Volkel)
2020-05-12 20:03:54.305 (Buienradar) General/Custom Sensor (Volkel Watt/M2)
2020-05-12 20:03:54.318 (Buienradar) Rain (Volkel Regen)
2020-05-12 20:03:58.860 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-12 20:09:03.898 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
So my server is trying them every 5min, guess we should change it to 10-15min ;)
Posted: Tuesday 12 May 2020 20:49
by waaren
ILoveIOT wrote: Tuesday 12 May 2020 20:30 Looks more like a protection from buienradar, to avoid unnecessary client requests, seems they allow every 10min (what is allot I guess) and kill any connection sooner then 10 min, resulting in a error for us.
No that is not what is happening. I poll Buienradar continuously much more frequent than this because of test / development / production and android and comparing dzVents scripts vs Python plugins and native Buienradar hardware module. All from the same IP.
Still only seeing the Problem message a couple of times a day.
Posted: Tuesday 12 May 2020 20:55
by ILoveIOT
Oh ok,...typical,..I see them all the day every day.
Is there a polling time somewhere in a file that I could change for testing ?
Maybe I'am just guessing now, I got restrictions on my ipadress, Hungary IP address, not dutch
Posted: Tuesday 12 May 2020 21:09
by waaren
ILoveIOT wrote: Tuesday 12 May 2020 20:55 Is there a polling time somewhere in a file that I could change for testing ?
The polling times are in the source file around line 177.
Set at every 10 minutes to get the meter details and every 5 minutes to get rain prediction.
Posted: Tuesday 12 May 2020 21:20
by ILoveIOT
Nice,..thank you,..I guess that's it for me, many thanks.
Posted: Tuesday 12 May 2020 22:08
by Brutus
akamming wrote: Tuesday 12 May 2020 20:19
Greetings.
Thnx Akamming! I have not found anyone who could test it for me. But thank you for changing and testing. When it's available is will test and use this in Windows.
Posted: Wednesday 13 May 2020 14:21
by akamming
ILoveIOT wrote: Tuesday 12 May 2020 20:55 Oh ok,...typical,..I see them all the day every day.
Since i did some development of the plugin, i also did testing with several locations and station id's. I got a lot more errors on some locations/stationid's then on other locations. so i think it is not load dependent, but station dependent...
Posted: Wednesday 13 May 2020 14:25
by akamming
Brutus wrote: Tuesday 12 May 2020 22:08 Thnx Akamming! I have not found anyone who could test it for me. But thank you for changing and testing. When it's available is will test and use this in Windows.
Gizmocus rejected the PR. I understand his reasoning (consistensy with the other weather plugins). i think he's right, for maintainability it is better to change the lua scripts...
Posted: Wednesday 13 May 2020 14:45
by Brutus
akamming wrote: Wednesday 13 May 2020 14:25
Don't understand this.. Buienradar is like no other plugins. :?
So when I want things seperated I need to extract the data from the sensor and send it in a seprated virtual sensor. Keeping things easy.
Posted: Wednesday 13 May 2020 17:26
by ILoveIOT
Hi akamming, many thanks for the advise, I tried 6 at least, for me no luck (see spoiler), If I'am not the only one, maybe a future request, where we can (maybe fixed times 5-10-15-30) change the polling time in the hardware/plugin section. If could change the time, the error would go away I guess, now its fine for me, excluded the error from the syslog, shows only in Domoticz now. (I was thinking to build Domoticz from source, but its just a error, plugin is working fine)
Thanks, happy days !! :D
2020-05-13 16:35:45.399 Status: BuienRadar: Worker stopped...
2020-05-13 16:35:45.400 Status: BuienRadar: Worker started...
2020-05-13 16:35:52.889 Status: BuienRadar: using Configured location settings (51.4546816, 5.3797601)
2020-05-13 16:35:52.890 Status: BuienRadar: Nearest Station: Meetstation Eindhoven (Eindhoven), Distance: 2.8 km, ID: 6370, Lat/Lon: 51.45,5.42
2020-05-13 16:35:53.228 (Buienradar) Temp + Humidity + Baro (Volkel)
2020-05-13 16:35:53.234 (Buienradar) Temp (Volkel Grond 10cm)
2020-05-13 16:35:53.238 (Buienradar) Temp (Volkel gevoel)
2020-05-13 16:35:53.241 (Buienradar) Wind (Volkel Wind)
2020-05-13 16:35:53.247 (Buienradar) General/Visibility (Zichtbaar Volkel)
2020-05-13 16:35:53.251 (Buienradar) General/Custom Sensor (Volkel Watt/M2)
2020-05-13 16:35:53.262 (Buienradar) Rain (Volkel Regen)
2020-05-13 16:35:58.048 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 16:41:02.885 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 16:44:50.334 Status: BuienRadar: Worker stopped...
2020-05-13 16:44:50.335 Status: BuienRadar: Worker started...
2020-05-13 16:44:57.841 Status: BuienRadar: using Configured location settings (52.0036478, 5.815807)
2020-05-13 16:44:57.842 Status: BuienRadar: Nearest Station: Meetstation Arnhem (Arnhem), Distance: 8.6 km, ID: 6275, Lat/Lon: 52.07,5.88
2020-05-13 16:44:58.238 (Buienradar) Temp + Humidity + Baro (Volkel)
2020-05-13 16:44:58.244 (Buienradar) Temp (Volkel Grond 10cm)
2020-05-13 16:44:58.249 (Buienradar) Temp (Volkel gevoel)
2020-05-13 16:44:58.255 (Buienradar) Wind (Volkel Wind)
2020-05-13 16:44:58.259 (Buienradar) General/Visibility (Zichtbaar Volkel)
2020-05-13 16:44:58.265 (Buienradar) General/Custom Sensor (Volkel Watt/M2)
2020-05-13 16:44:58.277 (Buienradar) Rain (Volkel Regen)
2020-05-13 16:45:02.958 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 16:50:07.886 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 16:51:36.990 Status: BuienRadar: Worker stopped...
2020-05-13 16:51:36.992 Status: BuienRadar: Worker started...
2020-05-13 16:51:44.890 (Buienradar) Temp + Humidity + Baro (Volkel)
2020-05-13 16:51:44.896 (Buienradar) Temp (Volkel Grond 10cm)
2020-05-13 16:51:44.901 (Buienradar) Temp (Volkel gevoel)
2020-05-13 16:51:44.909 (Buienradar) Wind (Volkel Wind)
2020-05-13 16:51:44.911 (Buienradar) General/Visibility (Zichtbaar Volkel)
2020-05-13 16:51:44.917 (Buienradar) General/Custom Sensor (Volkel Watt/M2)
2020-05-13 16:56:54.563 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 17:01:59.862 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 17:07:04.781 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 17:07:30.129 Status: BuienRadar: Worker stopped...
2020-05-13 17:07:30.131 Status: BuienRadar: Worker started...
2020-05-13 17:07:37.693 Status: BuienRadar: using Configured location settings (51.6949647, 5.0345487)
2020-05-13 17:07:37.694 Status: BuienRadar: Nearest Station: Meetstation Gilze Rijen (Gilze Rijen), Distance: 15.7 km, ID: 6350, Lat/Lon: 51.57,4.93 2020-05-13 17:07:38.026 (Buienradar) Temp + Humidity + Baro (Volkel)
2020-05-13 17:07:38.033 (Buienradar) Temp (Volkel Grond 10cm)
2020-05-13 17:07:38.037 (Buienradar) Temp (Volkel gevoel)
2020-05-13 17:07:38.044 (Buienradar) Wind (Volkel Wind)
2020-05-13 17:07:38.048 (Buienradar) General/Visibility (Zichtbaar Volkel)
2020-05-13 17:07:38.054 (Buienradar) General/Custom Sensor (Volkel Watt/M2)
2020-05-13 17:07:38.064 (Buienradar) Rain (Volkel Regen)
2020-05-13 17:12:47.987 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 16:51:44.930 (Buienradar) Rain (Volkel Regen)
2020-05-13 16:51:44.587 Status: BuienRadar: using Configured location settings (52.1010991, 5.1714657)
2020-05-13 16:51:44.588 Status: BuienRadar: Nearest Station: Meetstation De Bilt (Utrecht), Distance: 0.6 km, ID: 6260, Lat/Lon: 52.1,5.18
2020-05-13 16:51:49.629 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 17:01:55.180 (Buienradar) Temp + Humidity + Baro (Volkel)
2020-05-13 17:01:55.189 (Buienradar) Temp (Volkel Grond 10cm)
2020-05-13 17:01:55.197 (Buienradar) Temp (Volkel gevoel)
2020-05-13 17:01:55.200 (Buienradar) Wind (Volkel Wind)
2020-05-13 17:01:55.208 (Buienradar) General/Visibility (Zichtbaar Volkel)
2020-05-13 17:01:55.215 (Buienradar) General/Custom Sensor (Volkel Watt/M2)
2020-05-13 17:01:55.225 (Buienradar) Rain (Volkel Regen)
2020-05-13 09:00:48.891 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 09:05:53.858 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 09:10:59.190 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 09:16:04.104 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 09:21:09.341 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 09:26:14.350 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 09:31:19.508 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 09:36:24.479 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 09:41:29.568 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 09:46:34.382 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 09:51:39.549 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 09:56:44.413 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 10:01:49.588 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 10:06:54.515 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 10:11:59.740 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 10:17:04.599 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 10:22:09.786 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 10:27:14.790 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 10:32:20.031 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 10:37:25.030 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 10:42:30.438 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 10:47:35.297 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 10:52:40.617 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 10:57:45.427 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 11:02:50.643 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 11:07:55.615 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 11:13:00.872 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 11:18:05.859 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 11:23:10.872 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 11:28:15.782 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 11:33:20.996 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 11:38:26.028 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 11:43:31.360 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 11:48:36.195 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 11:53:41.335 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 11:58:46.195 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 12:03:51.518 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 12:08:56.486 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 12:14:01.855 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 12:19:06.648 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 12:24:11.839 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 12:29:16.804 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 12:34:21.894 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 12:39:26.841 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 12:44:31.856 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 12:49:36.708 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 12:54:41.900 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 12:59:46.809 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 13:04:52.026 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 13:09:56.893 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 13:15:01.996 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 13:20:06.847 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 13:25:12.083 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 13:30:17.145 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 13:35:22.292 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 13:40:27.205 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 13:45:32.304 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 13:50:37.136 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 13:55:42.545 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 14:00:47.463 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 14:05:53.168 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 14:10:58.134 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 14:16:03.347 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 14:21:08.218 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 14:26:13.365 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 14:31:18.352 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 14:36:23.612 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 14:41:28.519 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 14:46:33.627 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 14:51:38.447 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 14:56:43.667 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 15:01:48.832 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 15:06:53.897 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 15:11:58.822 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 15:17:04.091 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 15:22:09.061 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 15:27:14.058 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 15:32:18.913 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 15:37:24.293 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 15:42:29.213 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 15:47:34.496 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 15:52:39.391 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 15:57:44.866 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 16:02:49.667 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 16:07:54.871 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 16:12:59.747 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 16:18:04.974 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 16:23:09.907 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 16:28:15.230 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 16:33:20.187 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 16:35:20.323 Error: BuienRadar: Configured StationID (51) not found at Buienradar site (or does not contain a temperature sensor), please check Hardware setup!
2020-05-13 17:07:42.745 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-05-13 17:17:53.277 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
