Page 1 of 3
Lua version problem domoticz
Posted: Monday 23 March 2020 16:54
by sjoemie1985
Good afternoon,
i am using domoticz on a raspberry pi 4 with rasbian 10 (buster) installed/ upgraded on it.
my domoticz is giving a lua version problem in the logging.
see the following code
i tried installing lua and reinstalling it but somehow he can't find the location of those files.
it looks like that domoticz want to use version 5.3 while my raspberry pi sees version 5.2 as default or so.
Can someone help me out?
2020-03-23 16:50:30.006 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_calculate_consumption.lua: ...ticz/scripts/lua/script_device_calculate_consumption.lua:21: module 'socket.http' not found:
2020-03-23 16:50:30.006 no field package.preload['socket.http']
2020-03-23 16:50:30.006 no file '/usr/local/share/lua/5.3/socket/http.lua'
2020-03-23 16:50:30.006 no file '/usr/local/share/lua/5.3/socket/http/init.lua'
2020-03-23 16:50:30.006 no file '/usr/local/lib/lua/5.3/socket/http.lua'
2020-03-23 16:50:30.006 no file '/usr/local/lib/lua/5.3/socket/http/init.lua'
2020-03-23 16:50:30.006 no file './socket/http.lua'
2020-03-23 16:50:30.006 no file './socket/http/init.lua'
2020-03-23 16:50:30.006 no file '/usr/local/lib/lua/5.3/socket/http.so'
2020-03-23 16:50:30.006 no file '/usr/local/lib/lua/5.3/loadall.so'
2020-03-23 16:50:30.006 no file './socket/http.so'
2020-03-23 16:50:30.006 no file '/usr/local/lib/lua/5.3/socket.so'
2020-03-23 16:50:30.006 no file './socket.so'
Re: Lua version problem domoticz
Posted: Monday 23 March 2020 17:02
by waaren
sjoemie1985 wrote: Monday 23 March 2020 16:54
Can you try
sudo apt-get install lua5.3 liblua5.3
Posted: Monday 23 March 2020 17:13
by sjoemie1985
waaren wrote: Monday 23 March 2020 17:02
Can you try
done that and gives thist result
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'liblua5.3-dev' for regex 'liblua5.3'
Note, selecting 'liblua5.3-0-dbg' for regex 'liblua5.3'
Note, selecting 'liblua5.3-0' for regex 'liblua5.3'
liblua5.3-0 is already the newest version (5.3.3-1.1).
liblua5.3-0-dbg is already the newest version (5.3.3-1.1).
liblua5.3-dev is already the newest version (5.3.3-1.1).
lua5.3 is already the newest version (5.3.3-1.1).
0 upgraded, 0 newly installed, 0 to remove and 27 not upgraded.
Posted: Monday 23 March 2020 17:25
by waaren
sjoemie1985 wrote: Monday 23 March 2020 17:13
What do you see when you give
sudo update-alternatives --config lua-interpreter
Posted: Tuesday 24 March 2020 9:35
by sjoemie1985
waaren wrote: Monday 23 March 2020 17:25
than i see this:
There are 3 choices for the alternative lua-interpreter (providing /usr/bin/lua).
Selection Path Priority Status
* 0 /usr/bin/lua5.2 120 auto mode
1 /usr/bin/lua5.1 110 manual mode
2 /usr/bin/lua5.2 120 manual mode
3 /usr/bin/lua5.3 120 manual mode
Press <enter> to keep the current choice[*], or type selection number:
Posted: Tuesday 24 March 2020 9:44
by waaren
sjoemie1985 wrote: Tuesday 24 March 2020 9:35
Now do the same and choose option 3
Posted: Tuesday 24 March 2020 12:47
by sjoemie1985
waaren wrote: Tuesday 24 March 2020 9:44
done that and now the star is at option 3
but in the domoticz log i still see this
2020-03-24 12:46:24.359 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_calculate_consumption.lua: ...ticz/scripts/lua/script_device_calculate_consumption.lua:21: module 'socket.http' not found:
2020-03-24 12:46:24.359 no field package.preload['socket.http']
2020-03-24 12:46:24.359 no file '/usr/local/share/lua/5.3/socket/http.lua'
2020-03-24 12:46:24.359 no file '/usr/local/share/lua/5.3/socket/http/init.lua'
2020-03-24 12:46:24.359 no file '/usr/local/lib/lua/5.3/socket/http.lua'
2020-03-24 12:46:24.359 no file '/usr/local/lib/lua/5.3/socket/http/init.lua'
2020-03-24 12:46:24.359 no file './socket/http.lua'
2020-03-24 12:46:24.359 no file './socket/http/init.lua'
2020-03-24 12:46:24.359 no file '/usr/local/lib/lua/5.3/socket/http.so'
2020-03-24 12:46:24.359 no file '/usr/local/lib/lua/5.3/loadall.so'
2020-03-24 12:46:24.359 no file './socket/http.so'
2020-03-24 12:46:24.359 no file '/usr/local/lib/lua/5.3/socket.so'
2020-03-24 12:46:24.359 no file './socket.so'
when trying to find files with lua5.3 is only see this
Posted: Tuesday 24 March 2020 12:50
by waaren
sjoemie1985 wrote: Tuesday 24 March 2020 12:47
Can you share the script ?
and what do you see when you give
sudo find / -name socket.* | grep lua
Posted: Tuesday 24 March 2020 13:15
by sjoemie1985
waaren wrote: Tuesday 24 March 2020 12:50
-- /home/pi/domoticz/scripts/lua/script_device_calculate_consumption.lua
-- This script collects the values below from Domoticz
-- * The Power and energy values (import and export) from a smartmeter
-- * The Power and energy values from a Solar power inverter
-- It then calculates the consumed power and energy from the values above with the formula's
-- * EnergyConsumption = EnergyGeneration + EnergyImport - EnergyExport
-- * PowerConsumption = PowerGeneration + PowerImport - PowerExport
-- It then updates a virtual device which displays the consumed power and energy in Domoticz
-- Domoticz IDX and names of the needed devices
local GenerationDeviceName = "Power" -- Device name of the Generated energy
local EnergyDeviceName = "Power" -- Name of the energy device that shows imported and exported energy
local ConsumptionIDX = 61 -- IDX of the energy device that shows calculated Consumption
local ConsumptionDeviceName = "ConsumptionDevice" -- Name of the energy device that shows calculated Consumption
-- Require parameters
local http = require("socket.http")
-- Script parameters
if (EnergyImportLow==nil) then
EnergyImportLow = 0 -- in Watt hours
EnergyImportHigh = 0 -- in Watt hours
EnergyExportLow = 0 -- in Watt hours
EnergyExportHigh = 0 -- in Watt hours
EnergyGeneration = 0 -- in Watt hours
PowerGeneration = 0 -- in Watts
EnergyImport = 0 -- in Watt hours
PowerImport = 0 -- in Watts
EnergyConsumption = 0 -- in Watt hours
PowerConsumption = 0 -- in Watts
Debug = "YES" -- Turn debugging on ("YES") or off ("NO")
-- Lua Functions
function update(device, id, power, energy, index)
commandArray[index] = {['UpdateDevice'] = id .. "|0|" .. power .. ";" .. energy}
-- CommandArray
-- Generated
PowerGeneration, EnergyGeneration = otherdevices_svalues[GenerationDeviceName]:match("([^;]+);([^;]+)")
if Debug=="YES" then
print(" ----- PowerGeneration = " .. PowerGeneration .. " W");
print(" ----- EnergyGeneration = " .. EnergyGeneration .. " Wh");
EnergyImportLow, EnergyImportHigh, EnergyExportLow, EnergyExportHigh, PowerImport, PowerExport = otherdevices_svalues[EnergyDeviceName]:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)")
EnergyImport = EnergyImportLow + EnergyImportHigh
EnergyExport = EnergyExportLow + EnergyExportHigh
print(" ----- PowerImport = " .. PowerImport .. " W");
print(" ----- EnergyImportLow = " .. EnergyImportLow .. " Wh");
print(" ----- EnergyImportHigh = " .. EnergyImportHigh .. " Wh");
print(" ----- EnergyImport = " .. EnergyImport .. " Wh");
print(" ----- PowerExport = " .. PowerExport .. " W");
print(" ----- EnergyExportLow = " .. EnergyExportLow .. " Wh");
print(" ----- EnergyExportHigh = " .. EnergyExportHigh .. " Wh");
print(" ----- EnergyExport = " .. EnergyExport .. " Wh");
-- Calculate consumption
print(" ----- PowerConsumption = " .. PowerConsumption .. " W");
print(" ----- EnergyConsumption = " .. EnergyConsumption .. " Wh");
-- Update comsumption device in Domoticz
if devicechanged[EnergyDeviceName] then
update(ConsumptionDeviceName, ConsumptionIDX, PowerConsumption, EnergyConsumption, 1)
Posted: Tuesday 24 March 2020 16:57
by waaren
sjoemie1985 wrote: Tuesday 24 March 2020 13:15
You can change this to
-- local http = require("socket.http")
it is not used in the script
Posted: Tuesday 24 March 2020 18:41
by hansonexperience
I have the same problem and error messages after upgrading to the new version.
I have:
Posted: Tuesday 24 March 2020 19:06
by hansonexperience
I skipped the ---local http = require("socket.http") line and I thought it was working now. I did not get the error of the socket
But I have this error now:
EventSystem: in /home/pi/domoticz/scripts/lua/script_time_upload_to_PVoutput.lua: .../domoticz/scripts/lua/script_time_upload_to_PVoutput.lua:39: attempt to index a nil value (global 'http')
How can I solve that?
Posted: Wednesday 25 March 2020 9:21
by waaren
hansonexperience wrote: Tuesday 24 March 2020 19:06
If you compile locally you can cmake with
cmake -DCMAKE_BUILD_TYPE=Release CMakeLists.txt -DUSE_OPENSSL_STATIC="NO" -DUSE_BUILTIN_LUA="NO"
Forcing the Lua engine in domoticz to use external libraries
If you use the pre build binaries then I suggest to move to the
dzVents version of the PVoutput script.
Posted: Wednesday 25 March 2020 11:45
by hansonexperience
waaren wrote: Wednesday 25 March 2020 9:21
Thx for your reply. I am a kind of newbie, how can I check if I complile locallly or use the pre build binaries?
Posted: Wednesday 25 March 2020 12:41
by waaren
hansonexperience wrote: Wednesday 25 March 2020 11:45
If you don't' know, you are using pre builds
Posted: Thursday 26 March 2020 9:55
by sjoemie1985
waaren wrote: Tuesday 24 March 2020 16:57
thanks i indeed tried that and that helped solving it for that script.
but i have an other script where it is used i think. in my domomticz log i see the same error as at the other script.
any idea? or is it also an unnecessary part of the script.
-- /home/pi/domoticz/scripts/lua/script_time_upload_to_PVoutput.lua
-- * The Power generation, energy generation and voltage from a Solar power inverter
-- * The temperature from a outside temperature sensor
-- * The Power consumption and energy consumption which is calculated in another Lua script
-- And uploads all of the values to a PVoutput account.
-- For more information about PVoutput, see their user documentation on http://www.pvoutput.org/help.html
-- Domoticz IDX of devices
local GenerationDeviceName = "PowerOutput" -- Device name of the Generated energy
local VoltageDeviceName = "VoltageOutput" -- Name of the voltage device that shows voltage of the inverter
local TemperatureDeviceName = "THB" -- Name of the temperature device that shows outside temperature
-- PVoutput parameters
local PVoutputApi = "xxxxxxx" -- Your PVoutput api key
local PVoutputSystemID = "xxxxx" -- Your PVoutput System ID
local PVoutputPostInterval = 5 -- The number of minutes between posts to PVoutput (normal is 5 but when in donation mode it's max 1)
local PVoutputURL = '://pvoutput.org/service/r2/addstatus.jsp?key=' -- The URL to the PVoutput Service
EnergyGeneration = 0 -- v1 in Watt hours
PowerGeneration = 0 -- v2 in Watts
EnergyConsumption = 0 -- v3 in Watt hours
PowerConsumption = 0 -- v4 in Watts
CurrentTemp = 0 -- v5 in celcius
Voltage = 0 -- v6 in volts
c1 = 1 -- c1 = 0 when v1 is today's energy. c1 = 1 when v1 is lifetime energy.
-- Lua Functions
function UploadToPVoutput(self)
b, c, h = http.request("http" .. PVoutputURL .. PVoutputApi .. "&sid=".. PVoutputSystemID .. "&d=" .. os.date("%Y%m%d") .. "&t=" .. os.date("%H:%M") ..
"&v1=" .. EnergyGeneration .. "&v2=" .. PowerGeneration .. "&v3=" .. EnergyConsumption .. "&v4=" .. PowerConsumption .. "&v5=" .. CurrentTemp .. "&v6=" .. Voltage .. "&c1=" .. c1 )
if b=="OK 200: Added Status" then
print(" -- Current status successfully uploaded to PVoutput.org")
print(" -- " ..b)
print(" --Energy generation (v1) = ".. EnergyGeneration .. " Wh")
print(" --Power generation (v2) = " .. PowerGeneration .. " W")
print(" --Energy consumption (v3) = " .. EnergyConsumption .. " Wh")
print(" --Power consumption (v4) = " .. PowerConsumption .. " W")
print(" --Current temperature (v5) = " .. CurrentTemp .. " C")
print(" --Voltage (v6) = " .. Voltage .. "V")
print(" --Cumulative Flag (c1) = " .. c1 .. "")
-- CommandArray
time = os.date("*t")
if PVoutputPostInterval > 1 then
TimeToGo = PVoutputPostInterval - (time.min % PVoutputPostInterval)
print('Time to go before upload to PVoutput: ' ..TimeToGo.. " minutes")
if((time.min % PVoutputPostInterval)==0)then
-- Generated
print(" ---- The total generated energy is " .. EnergyGeneration .. " Wh");
print(" ---- The current generated power is " .. PowerGeneration .. " W");
-- Voltage
Voltage = otherdevices_svalues[VoltageDeviceName] :match("([^;]+)")
print(" ---- The voltage of the inverter is " .. Voltage .. " V");
-- Temperature
CurrentTemp = otherdevices_svalues[TemperatureDeviceName]:match("([^;]+)")
print(" ---- The outside temperature is " .. CurrentTemp .. " C.");
--EnergyGeneration = "0"
--PowerGeneration = "0"
-- PowerConsumption
EnergyConsumption, PowerConsumption = otherdevices_svalues[ConsumptionDeviceName]:match("([^;]+);([^;]+)")
print(" ---- The total consumed energy is " .. EnergyConsumption .. " Wh");
print(" ---- The current consumed power is " .. PowerConsumption .. " W");
-- Upload data to PVoutput
UploadToPVoutput()
Posted: Thursday 26 March 2020 11:20
by waaren
sjoemie1985 wrote: Thursday 26 March 2020 9:55
I have an other script where it is used i think. in my domomticz log i see the same error as at the other script.
No it is used in this script.
The issue is reported in github but I don't know when / if it can be solved. If you cannot compile locally I suggest to move to the
dzVents version of this PVoutput script.
Posted: Thursday 26 March 2020 11:23
by sjoemie1985
waaren wrote: Thursday 26 March 2020 11:20
okay thanks for the help sofar
Posted: Friday 27 March 2020 15:22
by sjoemie1985
i am now using the pvout with an dzVents script and looks to work pretty good.
but i get one little error
2020-03-27 15:18:22.666 Error: dzVents: Error: (3.0.1) Eigen verbruik: An error occurred when calling event handler script_time_upload_to_PVoutput
2020-03-27 15:18:22.666 Error: dzVents: Error: (3.0.1) Eigen verbruik: ...ripts/dzVents/scripts/script_time_upload_to_PVoutput.lua:38: attempt to perform arithmetic on a string value (local 'PowerGeneration')
this is my script:
could it be the marker name?
some one that knows the solution about what is going wrong?
devices = {
21, -- Slimme meter youless (youless or P1)
61, -- Zonnepanelen
logging = {
level = domoticz.LOG_INFO,
-- level = domoticz.LOG_ERROR,
marker = "Eigen verbruik"
local Smartmeter = domoticz.devices(21) -- Slimme meter (youless or P1)
local Generation = domoticz.devices(30) -- Zonnepanelen
local Consumption = domoticz.devices(61) -- Eigen verbruik / calculated value / dummy Elekta kWh + counter
-- Smartmeter
local EnergyImportLow = Smartmeter.rawData[1]
local EnergyImportHigh = Smartmeter.rawData[2]
local EnergyExportLow = Smartmeter.rawData[3]
local EnergyExportHigh = Smartmeter.rawData[4]
local PowerImport = Smartmeter.rawData[5]
local PowerExport = Smartmeter.rawData[6]
-- Generation
local EnergyGeneration = Generation.rawData[2]
local PowerGeneration = Generation.rawData[1]
--Calculate
local EnergyImport = EnergyImportLow + EnergyImportHigh
local EnergyExport = EnergyExportLow + EnergyExportHigh
local EnergyConsumption = EnergyGeneration + EnergyImport - EnergyExport
local PowerConsumption = PowerGeneration + PowerImport - PowerExport
domoticz.log('EnergyImportLow ' .. EnergyImportLow .. ' Wh ', domoticz.LOG_INFO)
domoticz.log('EnergyImportHigh ' .. EnergyImportHigh .. ' Wh ', domoticz.LOG_INFO)
domoticz.log('EnergyExportLow ' .. EnergyExportLow .. ' Wh ', domoticz.LOG_INFO)
domoticz.log('EnergyExportHigh ' .. EnergyExportHigh .. ' Wh ', domoticz.LOG_INFO)
domoticz.log('PowerImport ' .. PowerImport .. ' W ', domoticz.LOG_INFO)
domoticz.log('PowerExport ' .. PowerExport .. ' W ', domoticz.LOG_INFO)
domoticz.log('EnergyGeneration ' .. EnergyGeneration .. ' Wh ', domoticz.LOG_INFO)
domoticz.log('PowerGeneration ' .. PowerGeneration .. ' W ', domoticz.LOG_INFO)
domoticz.log('EnergyConsumption ' .. EnergyConsumption .. ' Wh ', domoticz.LOG_INFO)
domoticz.log('PowerConsumption: ' .. PowerConsumption .. ' W ', domoticz.LOG_INFO)
domoticz.openURL('http://127.0.0.1:8080/json.htm?type=command¶m=udevice&idx=21'..'&nvalue=0&svalue='..PowerConsumption..';'..EnergyConsumption)
--vul zelf hier idx in van dummy Consumption (83) en domoticz port (8095)
Posted: Friday 27 March 2020 17:55
by waaren
sjoemie1985 wrote: Friday 27 March 2020 15:22
No, the error tells you are trying to calculate with a string. You first have to convert the string to a number.
You can also use the dzVents attribute names where known / available. See below.
devices = {
61, -- Zonnepanelen
logging = {
-- Smartmeter
local EnergyImportLow = Smartmeter.usage2
local EnergyImportHigh = Smartmeter.usage1
local EnergyExportLow = Smartmeter.return2
local EnergyExportHigh = Smartmeter.return1
local PowerImport = Smartmeter.usage
local PowerExport = Smartmeter.usageDelivered
-- Generation
local EnergyGeneration = tonumber(Generation.rawData[2])
local PowerGeneration = tonumber(Generation.rawData[1])
--Calculate
