Lua version problem domoticz
sjoemie1985
Post by sjoemie1985 »
Good afternoon,
i am using domoticz on a raspberry pi 4 with rasbian 10 (buster) installed/ upgraded on it.
my domoticz is giving a lua version problem in the logging.
see the following code
i tried installing lua and reinstalling it but somehow he can't find the location of those files.
it looks like that domoticz want to use version 5.3 while my raspberry pi sees version 5.2 as default or so.
Can someone help me out?
2020-03-23 16:50:30.006 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_calculate_consumption.lua: ...ticz/scripts/lua/script_device_calculate_consumption.lua:21: module 'socket.http' not found:
2020-03-23 16:50:30.006 no field package.preload['socket.http']
2020-03-23 16:50:30.006 no file '/usr/local/share/lua/5.3/socket/http.lua'
2020-03-23 16:50:30.006 no file '/usr/local/share/lua/5.3/socket/http/init.lua'
2020-03-23 16:50:30.006 no file '/usr/local/lib/lua/5.3/socket/http.lua'
2020-03-23 16:50:30.006 no file '/usr/local/lib/lua/5.3/socket/http/init.lua'
2020-03-23 16:50:30.006 no file './socket/http.lua'
2020-03-23 16:50:30.006 no file './socket/http/init.lua'
2020-03-23 16:50:30.006 no file '/usr/local/lib/lua/5.3/socket/http.so'
2020-03-23 16:50:30.006 no file '/usr/local/lib/lua/5.3/loadall.so'
2020-03-23 16:50:30.006 no file './socket/http.so'
2020-03-23 16:50:30.006 no file '/usr/local/lib/lua/5.3/socket.so'
2020-03-23 16:50:30.006 no file './socket.so'
Re: Lua version problem domoticz
sjoemie1985 wrote: Monday 23 March 2020 16:54 my domoticz is giving a lua version problem in the logging.
Can you try
sudo apt-get install lua5.3 liblua5.3
sjoemie1985
waaren wrote: Monday 23 March 2020 17:02
Can you try
done that and gives thist result
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'liblua5.3-dev' for regex 'liblua5.3'
Note, selecting 'liblua5.3-0-dbg' for regex 'liblua5.3'
Note, selecting 'liblua5.3-0' for regex 'liblua5.3'
liblua5.3-0 is already the newest version (5.3.3-1.1).
liblua5.3-0-dbg is already the newest version (5.3.3-1.1).
liblua5.3-dev is already the newest version (5.3.3-1.1).
lua5.3 is already the newest version (5.3.3-1.1).
0 upgraded, 0 newly installed, 0 to remove and 27 not upgraded.
sjoemie1985 wrote: Monday 23 March 2020 17:13 lua5.3 is already the newest version (5.3.3-1.1).
What do you see when you give
sudo update-alternatives --config lua-interpreter
sjoemie1985
waaren wrote: Monday 23 March 2020 17:25
than i see this:
There are 3 choices for the alternative lua-interpreter (providing /usr/bin/lua).
  Selection    Path             Priority   Status
* 0            /usr/bin/lua5.2   120       auto mode
  1            /usr/bin/lua5.1   110       manual mode
  2            /usr/bin/lua5.2   120       manual mode
  3            /usr/bin/lua5.3   120       manual mode
Press <enter> to keep the current choice[*], or type selection number:
sjoemie1985 wrote: Tuesday 24 March 2020 9:35
Now do the same and choose option 3
sjoemie1985
waaren wrote: Tuesday 24 March 2020 9:44
done that and now the star is at option 3
but in the domoticz log i still see this :(
2020-03-24 12:46:24.359 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_calculate_consumption.lua: ...ticz/scripts/lua/script_device_calculate_consumption.lua:21: module 'socket.http' not found:
2020-03-24 12:46:24.359 no field package.preload['socket.http']
2020-03-24 12:46:24.359 no file '/usr/local/share/lua/5.3/socket/http.lua'
2020-03-24 12:46:24.359 no file '/usr/local/share/lua/5.3/socket/http/init.lua'
2020-03-24 12:46:24.359 no file '/usr/local/lib/lua/5.3/socket/http.lua'
2020-03-24 12:46:24.359 no file '/usr/local/lib/lua/5.3/socket/http/init.lua'
2020-03-24 12:46:24.359 no file './socket/http.lua'
2020-03-24 12:46:24.359 no file './socket/http/init.lua'
2020-03-24 12:46:24.359 no file '/usr/local/lib/lua/5.3/socket/http.so'
2020-03-24 12:46:24.359 no file '/usr/local/lib/lua/5.3/loadall.so'
2020-03-24 12:46:24.359 no file './socket/http.so'
2020-03-24 12:46:24.359 no file '/usr/local/lib/lua/5.3/socket.so'
2020-03-24 12:46:24.359 no file './socket.so'
when trying to find files with lua5.3 is only see this
sjoemie1985 wrote: Tuesday 24 March 2020 12:47 done that and now the star is at option 3
Can you share the script ?
and what do you see when you give
sudo find / -name socket.* | grep lua
sjoemie1985
waaren wrote: Tuesday 24 March 2020 12:50
-- /home/pi/domoticz/scripts/lua/script_device_calculate_consumption.lua
-- This script collects the values below from Domoticz
--   * The Power and energy values (import and export) from a smartmeter
--   * The Power and energy values from a Solar power inverter
-- It then calculates the consumed power and energy from the values above with the formula's
--   * EnergyConsumption = EnergyGeneration + EnergyImport - EnergyExport
--   * PowerConsumption = PowerGeneration + PowerImport - PowerExport
-- It then updates a virtual device which displays the consumed power and energy in Domoticz
-- Domoticz IDX and names of the needed devices
local GenerationDeviceName = "Power" 		-- Device name of the Generated energy
local EnergyDeviceName = "Power" 		-- Name of the energy device that shows imported and exported energy
local ConsumptionIDX = 61  			-- IDX of the energy device that shows calculated Consumption
local ConsumptionDeviceName = "ConsumptionDevice" 		-- Name of the energy device that shows calculated Consumption
-- Require parameters
local http = require("socket.http")
-- Script parameters
if (EnergyImportLow==nil) then
EnergyImportLow = 0	-- in Watt hours
EnergyImportHigh = 0	-- in Watt hours
EnergyExportLow = 0	-- in Watt hours
EnergyExportHigh = 0	-- in Watt hours
EnergyGeneration = 0 	-- in Watt hours
PowerGeneration = 0 	-- in Watts
EnergyImport = 0	-- in Watt hours
PowerImport = 0		-- in Watts
EnergyConsumption = 0 	-- in Watt hours
PowerConsumption = 0 	-- in Watts
Debug = "YES" 		-- Turn debugging on ("YES") or off ("NO")
-- Lua Functions
function update(device, id, power, energy, index)
	commandArray[index] = {['UpdateDevice'] = id .. "|0|" .. power .. ";" .. energy}
-- CommandArray
	-- Generated
	PowerGeneration, EnergyGeneration = otherdevices_svalues[GenerationDeviceName]:match("([^;]+);([^;]+)")
	if Debug=="YES" then
		print("  ----- PowerGeneration = " .. PowerGeneration .. " W");
		print("  ----- EnergyGeneration = " .. EnergyGeneration .. " Wh");
	EnergyImportLow, EnergyImportHigh, EnergyExportLow, EnergyExportHigh, PowerImport, PowerExport = otherdevices_svalues[EnergyDeviceName]:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)")
	EnergyImport = EnergyImportLow + EnergyImportHigh
	EnergyExport = EnergyExportLow + EnergyExportHigh
		print("  ----- PowerImport = " .. PowerImport .. " W");
		print("  ----- EnergyImportLow = " .. EnergyImportLow .. " Wh");
		print("  ----- EnergyImportHigh = " .. EnergyImportHigh .. " Wh");
		print("  ----- EnergyImport = " .. EnergyImport .. " Wh");
		print("  ----- PowerExport = " .. PowerExport .. " W");
		print("  ----- EnergyExportLow = " .. EnergyExportLow .. " Wh");
		print("  ----- EnergyExportHigh = " .. EnergyExportHigh .. " Wh");
		print("  ----- EnergyExport = " .. EnergyExport .. " Wh");
	-- Calculate consumption
		print("  ----- PowerConsumption = " .. PowerConsumption .. " W");
		print("  ----- EnergyConsumption = " .. EnergyConsumption .. " Wh");
	-- Update comsumption device in Domoticz
	if devicechanged[EnergyDeviceName] then
		update(ConsumptionDeviceName, ConsumptionIDX, PowerConsumption, EnergyConsumption, 1)
sjoemie1985 wrote: Tuesday 24 March 2020 13:15
You can change this to
-- local http = require("socket.http")
it is not used in the script :)
hansonexperience
Domoticz version: 2020.1
Post by hansonexperience »
I have the same problem and error messages after upgrading to the new version.
I have:
Solar: pvoutput, solarman, JFY inverter, enelogic, slimmemeterportal, Greenchoice
Weather: Davis VUE ISS, meteobridge wunderground, Asus WL -330N3G, leuven template
Website: http://www.hansonexperience.com / http://www.mooiweerboxtel.nl
hansonexperience
I skipped the ---local http = require("socket.http") line and I thought it was working now. I did not get the error of the socket
But I have this error now:
EventSystem: in /home/pi/domoticz/scripts/lua/script_time_upload_to_PVoutput.lua: .../domoticz/scripts/lua/script_time_upload_to_PVoutput.lua:39: attempt to index a nil value (global 'http')
How can I solve that?
hansonexperience wrote: Tuesday 24 March 2020 19:06 I skipped the ---local http = require("socket.http") line and I thought it was working now. I did not get the error of the socket
If you compile locally you can cmake with
cmake -DCMAKE_BUILD_TYPE=Release CMakeLists.txt -DUSE_OPENSSL_STATIC="NO" -DUSE_BUILTIN_LUA="NO"
Forcing the Lua engine in domoticz to use external libraries
If you use the pre build binaries then I suggest to move to the dzVents version of the PVoutput script.
hansonexperience
waaren wrote: Wednesday 25 March 2020 9:21
Thx for your reply. I am a kind of newbie, how can I check if I complile locallly or use the pre build binaries?
hansonexperience wrote: Wednesday 25 March 2020 11:45 Thx for your reply. I am a kind of newbie, how can I check if I complile locallly or use the pre build binaries?
If you don't' know, you are using pre builds
sjoemie1985
waaren wrote: Tuesday 24 March 2020 16:57
thanks i indeed tried that and that helped solving it for that script.
but i have an other script where it is used i think. in my domomticz log i see the same error as at the other script. :(
any idea? or is it also an unnecessary part of the script.
-- /home/pi/domoticz/scripts/lua/script_time_upload_to_PVoutput.lua
--   * The Power generation, energy generation and voltage from a Solar power inverter
--   * The temperature from a outside temperature sensor
--   * The Power consumption and energy consumption which is calculated in another Lua script
-- And uploads all of the values to a PVoutput account.
-- For more information about PVoutput, see their user documentation on http://www.pvoutput.org/help.html
-- Domoticz IDX of devices
local GenerationDeviceName = "PowerOutput"	-- Device name of the Generated energy
local VoltageDeviceName = "VoltageOutput"	-- Name of the voltage device that shows voltage of the inverter
local TemperatureDeviceName = "THB" -- Name of the temperature device that shows outside temperature
-- PVoutput parameters
local PVoutputApi = "xxxxxxx"		-- Your PVoutput api key
local PVoutputSystemID = "xxxxx" 					-- Your PVoutput System ID
local PVoutputPostInterval = 5  					-- The number of minutes between posts to PVoutput (normal is 5 but when in donation mode it's max 1)
local PVoutputURL = '://pvoutput.org/service/r2/addstatus.jsp?key='	-- The URL to the PVoutput Service
EnergyGeneration = 0 	-- v1 in Watt hours
PowerGeneration = 0 	-- v2 in Watts
EnergyConsumption = 0 	-- v3 in Watt hours
PowerConsumption = 0 	-- v4 in Watts
CurrentTemp = 0 	-- v5 in celcius
Voltage = 0 		-- v6 in volts
c1 = 1 			-- c1 = 0 when v1 is today's energy. c1 = 1 when v1 is lifetime energy.
-- Lua Functions
function UploadToPVoutput(self)
	b, c, h = http.request("http" .. PVoutputURL .. PVoutputApi .. "&sid=".. PVoutputSystemID .. "&d=" .. os.date("%Y%m%d") .. "&t=" .. os.date("%H:%M") ..
	"&v1=" .. EnergyGeneration .. "&v2=" .. PowerGeneration .. "&v3=" .. EnergyConsumption .. "&v4=" .. PowerConsumption .. "&v5=" .. CurrentTemp .. "&v6=" .. Voltage .. "&c1=" .. c1 )
	if b=="OK 200: Added Status" then
		print(" -- Current status successfully uploaded to PVoutput.org")
		print(" -- " ..b)
	print("  --Energy generation (v1) = ".. EnergyGeneration .. " Wh")
	print("  --Power generation (v2) = " .. PowerGeneration .. " W")
	print("  --Energy consumption (v3) = " .. EnergyConsumption .. " Wh")
	print("  --Power consumption (v4) = " .. PowerConsumption .. " W")
	print("  --Current temperature (v5) = " .. CurrentTemp .. " C")
	print("  --Voltage (v6) = " .. Voltage .. "V")
	print("  --Cumulative Flag (c1) = " .. c1 .. "")
-- CommandArray
	time = os.date("*t")
	if PVoutputPostInterval > 1 then
		TimeToGo = PVoutputPostInterval - (time.min % PVoutputPostInterval)
		print('Time to go before upload to PVoutput: ' ..TimeToGo.. " minutes")
	if((time.min % PVoutputPostInterval)==0)then
		-- Generated
			print(" ---- The total generated energy is " .. EnergyGeneration .. " Wh");
			print(" ---- The current generated power is " .. PowerGeneration .. " W");
		-- Voltage
		Voltage = otherdevices_svalues[VoltageDeviceName] :match("([^;]+)")
			print(" ---- The voltage of the inverter is " .. Voltage .. " V");
		-- Temperature
		CurrentTemp = otherdevices_svalues[TemperatureDeviceName]:match("([^;]+)")
			print(" ---- The outside temperature is " .. CurrentTemp .. " C.");
		--EnergyGeneration = "0"
		--PowerGeneration = "0"
		-- PowerConsumption
		EnergyConsumption, PowerConsumption = otherdevices_svalues[ConsumptionDeviceName]:match("([^;]+);([^;]+)")
			print(" ---- The total consumed energy is " .. EnergyConsumption .. " Wh");
			print(" ---- The current consumed power is " .. PowerConsumption .. " W");
		-- Upload data to PVoutput
		UploadToPVoutput()
sjoemie1985 wrote: Thursday 26 March 2020 9:55 I have an other script where it is used i think. in my domomticz log i see the same error as at the other script. :(
No it is used in this script.
The issue is reported in github but I don't know when / if it can be solved. If you cannot compile locally I suggest to move to the dzVents version of this PVoutput script.
sjoemie1985
waaren wrote: Thursday 26 March 2020 11:20
okay thanks for the help sofar :)
sjoemie1985
i am now using the pvout with an dzVents script and looks to work pretty good.
but i get one little error
2020-03-27 15:18:22.666 Error: dzVents: Error: (3.0.1) Eigen verbruik: An error occurred when calling event handler script_time_upload_to_PVoutput
2020-03-27 15:18:22.666 Error: dzVents: Error: (3.0.1) Eigen verbruik: ...ripts/dzVents/scripts/script_time_upload_to_PVoutput.lua:38: attempt to perform arithmetic on a string value (local 'PowerGeneration')
this is my script:
could it be the marker name?
some one that knows the solution about what is going wrong?
        devices = {
                    21, -- Slimme meter youless (youless or P1)
                    61, -- Zonnepanelen
    logging = {
        level = domoticz.LOG_INFO,
--        level = domoticz.LOG_ERROR,
        marker = "Eigen verbruik"
        local Smartmeter = domoticz.devices(21)   -- Slimme meter (youless or P1)
        local Generation = domoticz.devices(30)   -- Zonnepanelen
        local Consumption = domoticz.devices(61)  -- Eigen verbruik / calculated value / dummy Elekta kWh + counter
        -- Smartmeter
        local EnergyImportLow = Smartmeter.rawData[1]
        local EnergyImportHigh = Smartmeter.rawData[2]
        local EnergyExportLow = Smartmeter.rawData[3]
        local EnergyExportHigh = Smartmeter.rawData[4]
        local PowerImport = Smartmeter.rawData[5]
        local PowerExport = Smartmeter.rawData[6]
        -- Generation
        local EnergyGeneration = Generation.rawData[2]
        local PowerGeneration = Generation.rawData[1]
        --Calculate
        local EnergyImport = EnergyImportLow + EnergyImportHigh
        local EnergyExport = EnergyExportLow + EnergyExportHigh
        local EnergyConsumption = EnergyGeneration + EnergyImport - EnergyExport
        local PowerConsumption = PowerGeneration + PowerImport - PowerExport
        domoticz.log('EnergyImportLow ' .. EnergyImportLow .. ' Wh ', domoticz.LOG_INFO)
        domoticz.log('EnergyImportHigh ' .. EnergyImportHigh .. ' Wh ', domoticz.LOG_INFO)
        domoticz.log('EnergyExportLow ' .. EnergyExportLow .. ' Wh ', domoticz.LOG_INFO)
        domoticz.log('EnergyExportHigh ' .. EnergyExportHigh .. ' Wh ', domoticz.LOG_INFO)
        domoticz.log('PowerImport ' .. PowerImport .. ' W ', domoticz.LOG_INFO)
        domoticz.log('PowerExport ' .. PowerExport .. ' W ', domoticz.LOG_INFO)
        domoticz.log('EnergyGeneration ' .. EnergyGeneration .. ' Wh ', domoticz.LOG_INFO)
        domoticz.log('PowerGeneration ' .. PowerGeneration .. ' W ', domoticz.LOG_INFO)
        domoticz.log('EnergyConsumption ' .. EnergyConsumption .. ' Wh ', domoticz.LOG_INFO)
        domoticz.log('PowerConsumption: ' .. PowerConsumption .. ' W ', domoticz.LOG_INFO)
        domoticz.openURL('http://127.0.0.1:8080/json.htm?type=command&param=udevice&idx=21'..'&nvalue=0&svalue='..PowerConsumption..';'..EnergyConsumption)
        --vul zelf hier idx in van dummy Consumption (83) en domoticz port (8095)
sjoemie1985 wrote: Friday 27 March 2020 15:22 but i get one little error
No, the error tells you are trying to calculate with a string. You first have to convert the string to a number.
You can also use the dzVents attribute names where known / available. See below.
        devices = {
                    61, -- Zonnepanelen
    logging = {
		-- Smartmeter
        local EnergyImportLow = Smartmeter.usage2
        local EnergyImportHigh = Smartmeter.usage1
        local EnergyExportLow = Smartmeter.return2
        local EnergyExportHigh = Smartmeter.return1
        local PowerImport = Smartmeter.usage
        local PowerExport = Smartmeter.usageDelivered
        -- Generation
        local EnergyGeneration = tonumber(Generation.rawData[2])
        local PowerGeneration = tonumber(Generation.rawData[1])
        --Calculate
Users browsing this forum: niki_lauda and 1 guest
