Problem darsky script NO JSON
Ghislain
Post by Ghislain »
I have a problem with a script for DarkSky, I got that of hestia which is here but after configuration the logs show me that it does not find JSON.
 2020-03-20 11:30:00.403 Status: dzVents: Info: ------ Start internal script: Darksky:, trigger: every 1 minutes between 50 minutes before sunrise and 50 minutes after sunset
2020-03-20 11:30:00.403 Status: dzVents: url: https://api.darksky.net/forecast/XXXxxxXXX/49.199,5.5744?lang=fr&units=si&exclude=minutely,daily
2020-03-20 11:30:00.404 Status: dzVents: Info: ------ Finished Darksky
2020-03-20 11:30:00.405 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-03-20 11:30:01.032 Status: dzVents: Info: Handling httpResponse-events for: "getDarkSkyForecast
2020-03-20 11:30:01.032 Status: dzVents: Info: ------ Start internal script: Darksky: HTTPResponse: "getDarkSkyForecast"
2020-03-20 11:30:01.033 Status: dzVents: triggerObject ok
2020-03-20 11:30:01.033 Status: dzVents: trigger: getDarkSkyForecast
2020-03-20 11:30:01.033 Status: dzVents: callback: getDarkSkyForecast
2020-03-20 11:30:01.033 Status: dzVents: statusCode: 200
2020-03-20 11:30:01.033 Status: dzVents: Error (2.4.19): NO JSON ???
2020-03-20 11:30:01.033 Status: dzVents: Info: ------ Finished Darksky
I did a lot of research and so I tried that of papoo here, which works perfectly!
The only difference I find is the data file which is created in /domoticz/script/dzvents/data
When I run the hestia script the file is created but does not fill in the information whereas with that of papoo it fills up perfectly.
At first glance I therefore have no configuration problem because otherwise neither of them will work. I'm on Buster and Domoticz 4.10717 freshly installed
Have you ever encountered this problem?
