Page 1 of 2
Help needed get Data from Weatherstation Lua to dzvents
Posted: Thursday 19 March 2020 12:06
by sailmich
Rpi 2
Z-Stick 5
Fine Offset weatherstation
Hi, I tried to change a lua script, to fetch data from my personal weatherstation, into dzvents.
Lua works
- Spoiler: show
time = os.date("*t")
if ((time.min % 10)==0) then
os.execute('sudo wget http://192.xxx.xxx.xx/weewx_pws.xml -O /path to/weewx_pws.xml')
local filename = "path to/weewx_pws.xml"
local line = ''
local temperature = 0
local tempdevice = ''
for line in io.lines(filename) do
if string.find(line,"\"temp\"") then
temperature=tonumber(string.match(line, "%-?%d+.?%d*"))
-- Update virtual device idx
tempdevice='idx|1|'..temperature..';0'
--print(tempdevice))
commandArray['UpdateDevice'] = tempdevice
dzvents need help
- Spoiler: show
timer = {'every 1 minutes'}
--,devices = {'triggerhulp'}
execute = function(domoticz)
-- check time of the day
if domoticz.time.isDayTime then
os.execute('sudo wget http://xxx.xxx.xxx.xx/weewx_pws.xml -O /path to/weewx_pws.xml')
local filename = "/path to/weewx_pws.xml"
local line = ''
--Update virtual device id , nval(0) sval (temp)
--tempdevice='208|1|'..temperature..';0'
tempdevice = domoticz.devices('WetterAußen')
till os.execute('sudo wget
http://xxx.xxx.xxx.xx/weewx_pws.xml -O /path to/weewx_pws.xml') It's running.
I don't know how to get data from xml file and update my Temperature sensor.
THX for any help
Re: Help needed get Data from Weatherstation Lua to dzvents
Posted: Thursday 19 March 2020 12:54
by waaren
sailmich wrote: Thursday 19 March 2020 12:06
THX for any help
This script will get the data from the weatherstation. If you can execute it once and share the loglines I can continue from there.
Also please state what version of domoticz / dzVents you use.
local url = 'http://xxx.xxx.xxx.xxx/weewx_pws.xml'
local scriptVar = 'getXML'
return
on =
timer =
'every minute at daytime',
devices =
'triggerhulp',
httpResponses =
scriptVar,
logging =
level = domoticz.LOG_DEBUG,
marker = scriptVar,
execute = function(dz, item)
if item.isHTTPResponse then
if item.ok then
dz.log(item,dz.LOG_DEBUG)
dz.log('There was a problem handling the request', dz.LOG_ERROR)
dz.log(item, dz.LOG_ERROR)
return
-- tempdevice = domoticz.devices('WetterAußen')
dz.openURL(
url = url,
method = 'GET',
callback = scriptVar,
Posted: Thursday 19 March 2020 13:02
by sailmich
Thanks for your quick reply!
I use newest domoticz beta 11.796 and dzvents 3.0.1.
I will check the script in a couple of minutes!
Posted: Thursday 19 March 2020 13:39
by sailmich
This is my domoticz log.
- Spoiler: show
- 2020-03-19 13:33:00.638 Status: dzVents: Debug: Commands sent to Domoticz:
2020-03-19 13:33:00.638 Status: dzVents: Debug: - OpenURL = {["URL"]="http://xxx.xxx.xxx.xx/weewx_pws.xml", ["_trigger"]="getXML", ["method"]="GET"}
2020-03-19 13:33:00.638 Status: dzVents: Debug: =====================================================
2020-03-19 13:33:00.639 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-03-19 13:33:00.759 Status: dzVents: Debug: Dumping domoticz data to /home/pi/domoticz/scripts/dzVents/domoticzData.lua
2020-03-19 13:33:00.821 Status: dzVents: Debug: dzVents version: 3.0.1
2020-03-19 13:33:00.821 Status: dzVents: Debug: Event triggers:
2020-03-19 13:33:00.821 Status: dzVents: Debug: - HTTPResponse: getXML
2020-03-19 13:33:00.872 Status: dzVents: Info: Handling httpResponse-events for: "getXML"
2020-03-19 13:33:00.872 Status: dzVents: Info: getXML: ------ Start internal script: TemperaturDraußen: HTTPResponse: "getXML"
2020-03-19 13:33:00.874 Status: dzVents: Debug: getXML: {["ok"]=true, ["isScene"]=false, ["isVariable"]=false, ["isTimer"]=false, ["data"]="<?xml version="1.0" encoding="UTF-8" ?>
2020-03-19 13:33:00.874 <maintag>
2020-03-19 13:33:00.874 <!--MISC-->
2020-03-19 13:33:00.874 <misc><misc data="station_location">Hannover, Niedersachsen, Deutschland</misc></misc>
2020-03-19 13:33:00.874 <!--STATION DATA-->
2020-03-19 13:33:00.874 <realtime><data realtime="station_date">Thu, 19 Mar 2020</data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="station_time">13:30 CET</data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="sunrise">06:24:22</data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="sunset">18:33:14<!--sunsetTime--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="moonrise">04:56:48<!--moonriseTime--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="moonset">13:01:27<!--moonsetTime--></data></realtime>
2020-03-19 13:33:00.874 <!--TEMPERATURE-->
2020-03-19 13:33:00.874 <realtime><data realtime="temp">13.4<!--outsideTemp--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="high_temp">14.0<!--hiOutsideTemp--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="low_temp">10.7<!--lowOutsideTemp--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="heatindex">13.4<!--outsideHeatIndex--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="high_heatindex">14.0<!--hiHeatindex--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="inside_temp">25.0<!--inside_temp--></data></realtime>
2020-03-19 13:33:00.874 <!--HUMIDITY-->
2020-03-19 13:33:00.874 <realtime><data realtime="hum">62<!--outsideHumidity--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="high_hum">71<!--hiHumidity--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="low_hum">60<!--lowHumidity--></data></realtime>
2020-03-19 13:33:00.874 <!--WIND-->
2020-03-19 13:33:00.874 <realtime><data realtime="winddir" misc="imgwinddir">E<!--windDirection--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="windspeed">0.7<!--windSpeed--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="windGust">1.0<!--windGust--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="high_windspeed">2.0<!--hiWindSpeed--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="windchill">13.4<!--windChill--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="low_windchill">10.7<!--lowWindchill--></data></realtime>
2020-03-19 13:33:00.874 <!--DEWPOINT-->
2020-03-19 13:33:00.874 <realtime><data realtime="dew">6.3<!--outsideDewPt--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="high_dew">7.1<!--hiDewpoint--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="low_dew">4.5<!--lowDewpoint--></data></realtime>
2020-03-19 13:33:00.874 <!--BAROMETER-->
2020-03-19 13:33:00.874 <realtime><data realtime="barometer">1025.2<!--barometer--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="changebarometer">0.2<!--hourchangebarom--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="high_barometer">1025.6<!--hiBarometer--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="low_barometer">1022.8<!--lowBarometer--></data></realtime>
2020-03-19 13:33:00.874 <!--RAIN-->
2020-03-19 13:33:00.874 <realtime><data realtime="todaysrain">0.0<!--dailyRain--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="rain_rate">0.0<!--rainRate--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="high_rain_rate">0.0<!--hiRainRate--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="storm_rate">0.0<!--dailyRain--></data></realtime>
2020-03-19 13:33:00.874 <!--UNITS-->
2020-03-19 13:33:00.874 <realtime><data units="windunit">m/s<!--windUnit--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data units="rainunit">mm<!--rainUnit--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data units="rateunit">mm/hr-<!--rateUnit--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data units="barunit">mb<!--barUnit--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data units="tempunit">C<!--tempUnit--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data units="humunit">%<!--humUnit--></data></realtime>
2020-03-19 13:33:00.874 <!--CUSTOMDATA-->
2020-03-19 13:33:00.874 <realtime><data realtime="uv_index">0.0<!--uvIndex--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="radiation">29638<!--radiation--></data></realtime>
2020-03-19 13:33:00.874 </maintag>
2020-03-19 13:33:00.874 ", ["isXML"]=false, ["_contentType"]="application/xml", ["isSecurity"]=false, ["statusText"]="OK", ["isDevice"]=false, ["isJSON"]=false, ["isSystem"]=false, ["statusCode"]=200, ["isHTTPResponse"]=true, ["isGroup"]=false, ["protocol"]="HTTP/1.1", ["isCustomEvent"]=false, ["isHardware"]=false, ["trigger"]="getXML", ["callback"]="getXML", ["baseType"]="httpResponse", ["headers"]={["Content-Length"]="3363", ["Accept-Ranges"]="bytes", ["Server"]="lighttpd/1.4.35", ["Last-Modified"]="Thu, 19 Mar 2020 12:31:01 GMT", ["ETag"]=""1082087333"", ["Date"]="Thu, 19 Mar 2020 12:33:00 GMT", ["Content-Type"]="application/xml"}}
2020-03-19 13:33:00.874 Status: dzVents: Info: getXML: ------ Finished TemperaturDraußen
2020-03-19 13:33:13.723 (ZWaveW) Temp (Boden Sued Temperature)
2020-03-19 13:33:13.834 Status: dzVents: Debug: Dumping domoticz data to /home/pi/domoticz/scripts/dzVents/domoticzData.lua
2020-03-19 13:33:13.929 Status: dzVents: Debug: Processing device-adapter for Boden Sued Temperature: Temperature device adapter
2020-03-19 13:33:13.929 Status: dzVents: Debug: dzVents version: 3.0.1
2020-03-19 13:33:13.929 Status: dzVents: Debug: Event triggers:
All the data's are there but how to get them out and update my sensors
Posted: Thursday 19 March 2020 14:12
by waaren
sailmich wrote: Thursday 19 March 2020 13:39
Next step:
converting the XML to a table.
Please execute this one and show the result + tell what value needs to go to what device (name or id and type/ subtype)
return
on =
timer =
devices =
'triggerhulp',
httpResponses =
scriptVar,
logging =
marker = scriptVar,
if item.ok then
--dz.log(item,dz.LOG_DEBUG)
rt = dz.utils.fromXML(item.data)
dz.utils.dumpTable(rt)
return
dz.openURL(
url = url,
method = 'GET',
Posted: Thursday 19 March 2020 15:01
by sailmich
This is what I got.
- Spoiler: show
- 2020-03-19 14:31:00.645 Status: dzVents: > 23:
2020-03-19 14:31:00.645 Status: dzVents: > data:
2020-03-19 14:31:00.645 Status: dzVents: > 1: 7.1
2020-03-19 14:31:00.645 Status: dzVents: > _attr:
2020-03-19 14:31:00.645 Status: dzVents: > realtime: high_dew
2020-03-19 14:31:00.645 Status: dzVents: > 24:
2020-03-19 14:31:00.645 Status: dzVents: > 1: 4.5
2020-03-19 14:31:00.646 Status: dzVents: > realtime: low_dew
2020-03-19 14:31:00.646 Status: dzVents: > 25:
2020-03-19 14:31:00.646 Status: dzVents: > data:
2020-03-19 14:31:00.646 Status: dzVents: > 1: 1025.2
2020-03-19 14:31:00.646 Status: dzVents: > _attr:
2020-03-19 14:31:00.646 Status: dzVents: > realtime: barometer
2020-03-19 14:31:00.646 Status: dzVents: > 26:
2020-03-19 14:31:00.646 Status: dzVents: > 1: 0.0
2020-03-19 14:31:00.646 Status: dzVents: > realtime: changebarometer
2020-03-19 14:31:00.646 Status: dzVents: > 27:
2020-03-19 14:31:00.646 Status: dzVents: > 1: 1025.6
2020-03-19 14:31:00.646 Status: dzVents: > realtime: high_barometer
2020-03-19 14:31:00.646 Status: dzVents: > 28:
2020-03-19 14:31:00.646 Status: dzVents: > 1: 1022.8
2020-03-19 14:31:00.647 Status: dzVents: > _attr:
2020-03-19 14:31:00.647 Status: dzVents: > realtime: low_barometer
2020-03-19 14:31:00.647 Status: dzVents: > 29:
2020-03-19 14:31:00.647 Status: dzVents: > data:
2020-03-19 14:31:00.647 Status: dzVents: > 1: 0.0
2020-03-19 14:31:00.647 Status: dzVents: > realtime: todaysrain
2020-03-19 14:31:00.647 Status: dzVents: > 30:
2020-03-19 14:31:00.647 Status: dzVents: > realtime: rain_rate
2020-03-19 14:31:00.647 Status: dzVents: > 31:
2020-03-19 14:31:00.647 Status: dzVents: > realtime: high_rain_rate
2020-03-19 14:31:00.647 Status: dzVents: > 32:
2020-03-19 14:31:00.648 Status: dzVents: > realtime: storm_rate
2020-03-19 14:31:00.648 Status: dzVents: > 33:
2020-03-19 14:31:00.648 Status: dzVents: > data:
2020-03-19 14:31:00.648 Status: dzVents: > 1: m/s
2020-03-19 14:31:00.648 Status: dzVents: > _attr:
2020-03-19 14:31:00.648 Status: dzVents: > units: windunit
2020-03-19 14:31:00.648 Status: dzVents: > 34:
2020-03-19 14:31:00.648 Status: dzVents: > 1: mm
2020-03-19 14:31:00.648 Status: dzVents: > units: rainunit
2020-03-19 14:31:00.648 Status: dzVents: > 35:
2020-03-19 14:31:00.648 Status: dzVents: > 1: mm/hr-
2020-03-19 14:31:00.648 Status: dzVents: > units: rateunit
2020-03-19 14:31:00.648 Status: dzVents: > 36:
2020-03-19 14:31:00.648 Status: dzVents: > 1: mb
2020-03-19 14:31:00.648 Status: dzVents: > units: barunit
2020-03-19 14:31:00.649 Status: dzVents: > 37:
2020-03-19 14:31:00.649 Status: dzVents: > data:
2020-03-19 14:31:00.649 Status: dzVents: > 1: C
2020-03-19 14:31:00.649 Status: dzVents: > _attr:
2020-03-19 14:31:00.649 Status: dzVents: > units: tempunit
2020-03-19 14:31:00.649 Status: dzVents: > 38:
2020-03-19 14:31:00.649 Status: dzVents: > 1: %
2020-03-19 14:31:00.649 Status: dzVents: > units: humunit
2020-03-19 14:31:00.649 Status: dzVents: > 39:
2020-03-19 14:31:00.649 Status: dzVents: > 1: 0.0
2020-03-19 14:31:00.649 Status: dzVents: > realtime: uv_index
2020-03-19 14:31:00.649 Status: dzVents: > 40:
2020-03-19 14:31:00.649 Status: dzVents: > 1: 21558
2020-03-19 14:31:00.649 Status: dzVents: > realtime: radiation
2020-03-19 14:31:00.649 Status: dzVents: > misc:
2020-03-19 14:31:00.650 Status: dzVents: > misc:
2020-03-19 14:31:00.650 Status: dzVents: > 1: Hannover, Niedersachsen, Deutschland
2020-03-19 14:31:00.650 Status: dzVents: > _attr:
2020-03-19 14:31:00.650 Status: dzVents: > data: station_location
I don't get all data's as in the xml. I copied the domoticz log direct in Domoticz. Do you know where the location at my pi is, I can't find a log file for Domoticz.
xml
- Spoiler: show
- <!--STATION DATA-->
<realtime>
</realtime>
<realtime>
<data realtime="station_time">14:46 CET</data>
</realtime>
<realtime>
</realtime>
<realtime>
18:33:14
<!--sunsetTime-->
</data>
</realtime>
<realtime>
04:56:48
<!--moonriseTime-->
</data>
</realtime>
<realtime>
13:01:27
<!--moonsetTime-->
</data>
</realtime>
<!--TEMPERATURE-->
<realtime>
13.2
<!--outsideTemp-->
</data>
</realtime>
<realtime>
14.0
</data>
</realtime>
<realtime>
10.7
</data>
</realtime>
<realtime>
13.2
</data>
</realtime>
<realtime>
14.0
<!--hiHeatindex-->
</data>
</realtime>
<realtime>
24.7
<!--inside_temp-->
</data>
</realtime>
<!--HUMIDITY-->
<realtime>
62
</data>
</realtime>
<realtime>
71
<!--hiHumidity-->
</data>
</realtime>
<realtime>
60
<!--lowHumidity-->
</data>
</realtime>
<!--WIND-->
<realtime>
NNE
</data>
</realtime>
<realtime>
1.6
<!--windSpeed-->
</data>
</realtime>
<realtime>
2.7
<!--windGust-->
</data>
</realtime>
<realtime>
2.7
<!--hiWindSpeed-->
</data>
</realtime>
<realtime>
13.2
<!--windChill-->
</data>
</realtime>
<realtime>
10.7
<!--lowWindchill-->
</data>
</realtime>
<!--DEWPOINT-->
<realtime>
6.1
<!--outsideDewPt-->
</data>
</realtime>
<realtime>
7.1
<!--hiDewpoint-->
</data>
</realtime>
<realtime>
4.5
<!--lowDewpoint-->
</data>
</realtime>
<!--BAROMETER-->
<realtime>
1025.0
<!--barometer-->
</data>
</realtime>
<realtime>
-0.2
</data>
</realtime>
<realtime>
1025.6
<!--hiBarometer-->
</data>
</realtime>
<realtime>
1022.8
<!--lowBarometer-->
</data>
</realtime>
<!--RAIN-->
<realtime>
0.0
<!--dailyRain-->
</data>
</realtime>
<realtime>
0.0
<!--rainRate-->
</data>
</realtime>
<realtime>
0.0
<!--hiRainRate-->
</data>
</realtime>
<realtime>
0.0
<!--dailyRain-->
</data>
</realtime>
<!--UNITS-->
<realtime>
m/s
<!--windUnit-->
</data>
</realtime>
<realtime>
mm
<!--rainUnit-->
</data>
</realtime>
<realtime>
mm/hr-
<!--rateUnit-->
</data>
</realtime>
<realtime>
mb
<!--barUnit-->
</data>
</realtime>
<realtime>
C
<!--tempUnit-->
</data>
</realtime>
<realtime>
<!--humUnit-->
</data>
</realtime>
<!--CUSTOMDATA-->
<realtime>
0.0
<!--uvIndex-->
</data>
</realtime>
<realtime>
21320
<!--radiation-->
</data>
</realtime>
</maintag>
Posted: Thursday 19 March 2020 15:28
by waaren
sailmich wrote: Thursday 19 March 2020 15:01
The log file location is set in /etc/init.d/domoticz.sh in the
DAEMON_ARGS section.
I have these but you ports, location of logfile, etc could vary
DAEMON_ARGS="-daemon"
DAEMON_ARGS="$DAEMON_ARGS -daemonname $NAME -pidfile $PIDFILE"
DAEMON_ARGS="$DAEMON_ARGS -www 8084"
DAEMON_ARGS="$DAEMON_ARGS -sslwww 8443"
DAEMON_ARGS="$DAEMON_ARGS -log /var/log/domoticz.log" # location of logfile
DAEMON_ARGS="$DAEMON_ARGS -loglevel normal,status,error"
if you change something in this file you need a
sudo systemctl daemon-reload
sudo domoticz stop
sudo domoticz start
Posted: Thursday 19 March 2020 18:05
by sailmich
All data's are in the log
realtime:temp = idx208 WetterAußen
realtime:windGust =idx213 Boen
realtime:rain_rate =idx216 Regen
- Spoiler: show
- 2020-03-19 17:25:00.376 Status: dzVents: Debug: =====================================================
2020-03-19 17:25:00.377 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-03-19 17:25:00.489 Status: dzVents: Debug: Dumping domoticz data to /home/pi/domoticz/scripts/dzVents/domoticzData.lua
2020-03-19 17:25:00.551 Status: dzVents: Debug: dzVents version: 3.0.1
2020-03-19 17:25:00.551 Status: dzVents: Debug: Event triggers:
2020-03-19 17:25:00.551 Status: dzVents: Debug: - HTTPResponse: getXML
2020-03-19 17:25:00.592 Status: dzVents: Info: Handling httpResponse-events for: "getXML"
2020-03-19 17:25:00.593 Status: dzVents: Info: getXML: ------ Start internal script: Test: HTTPResponse: "getXML"
2020-03-19 17:25:00.628 Status: dzVents: > maintag:
2020-03-19 17:25:00.629 Status: dzVents: > misc:
2020-03-19 17:25:00.629 Status: dzVents: > 1: Hannover, Niedersachsen, Deutschland
2020-03-19 17:25:00.629 Status: dzVents: > _attr:
2020-03-19 17:25:00.629 Status: dzVents: > data: station_location
2020-03-19 17:25:00.629 Status: dzVents: > realtime:
2020-03-19 17:25:00.629 Status: dzVents: > 1: Thu, 19 Mar 2020
2020-03-19 17:25:00.630 Status: dzVents: > realtime: station_date
2020-03-19 17:25:00.630 Status: dzVents: > 2:
2020-03-19 17:25:00.630 Status: dzVents: > data:
2020-03-19 17:25:00.630 Status: dzVents: > 1: 17:22 CET
2020-03-19 17:25:00.630 Status: dzVents: > _attr:
2020-03-19 17:25:00.630 Status: dzVents: > realtime: station_time
2020-03-19 17:25:00.630 Status: dzVents: > 3:
2020-03-19 17:25:00.630 Status: dzVents: > 1: 06:24:19
2020-03-19 17:25:00.630 Status: dzVents: > realtime: sunrise
2020-03-19 17:25:00.630 Status: dzVents: > 4:
2020-03-19 17:25:00.631 Status: dzVents: > 1: 18:33:17
2020-03-19 17:25:00.631 Status: dzVents: > _attr:
2020-03-19 17:25:00.631 Status: dzVents: > realtime: sunset
2020-03-19 17:25:00.631 Status: dzVents: > 5:
2020-03-19 17:25:00.631 Status: dzVents: > data:
2020-03-19 17:25:00.631 Status: dzVents: > 1: 04:56:45
2020-03-19 17:25:00.631 Status: dzVents: > realtime: moonrise
2020-03-19 17:25:00.631 Status: dzVents: > 6:
2020-03-19 17:25:00.631 Status: dzVents: > 1: 13:01:30
2020-03-19 17:25:00.631 Status: dzVents: > realtime: moonset
2020-03-19 17:25:00.631 Status: dzVents: > 7:
2020-03-19 17:25:00.632 Status: dzVents: > data:
2020-03-19 17:25:00.632 Status: dzVents: > 1: 10.1
2020-03-19 17:25:00.632 Status: dzVents: > _attr:
2020-03-19 17:25:00.632 Status: dzVents: > realtime: temp
2020-03-19 17:25:00.632 Status: dzVents: > 8:
2020-03-19 17:25:00.632 Status: dzVents: > 1: 14.0
2020-03-19 17:25:00.632 Status: dzVents: > realtime: high_temp
2020-03-19 17:25:00.632 Status: dzVents: > 9:
2020-03-19 17:25:00.633 Status: dzVents: > realtime: low_temp
2020-03-19 17:25:00.633 Status: dzVents: > 10:
2020-03-19 17:25:00.633 Status: dzVents: > data:
2020-03-19 17:25:00.633 Status: dzVents: > 1: 10.1
2020-03-19 17:25:00.633 Status: dzVents: > _attr:
2020-03-19 17:25:00.633 Status: dzVents: > realtime: heatindex
2020-03-19 17:25:00.633 Status: dzVents: > 11:
2020-03-19 17:25:00.633 Status: dzVents: > 1: 14.0
2020-03-19 17:25:00.633 Status: dzVents: > realtime: high_heatindex
2020-03-19 17:25:00.633 Status: dzVents: > 12:
2020-03-19 17:25:00.634 Status: dzVents: > data:
2020-03-19 17:25:00.634 Status: dzVents: > 1: 25.1
2020-03-19 17:25:00.634 Status: dzVents: > _attr:
2020-03-19 17:25:00.634 Status: dzVents: > realtime: inside_temp
2020-03-19 17:25:00.634 Status: dzVents: > 13:
2020-03-19 17:25:00.634 Status: dzVents: > 1: 70
2020-03-19 17:25:00.634 Status: dzVents: > realtime: hum
2020-03-19 17:25:00.634 Status: dzVents: > 14:
2020-03-19 17:25:00.635 Status: dzVents: > 1: 71
2020-03-19 17:25:00.635 Status: dzVents: > _attr:
2020-03-19 17:25:00.635 Status: dzVents: > realtime: high_hum
2020-03-19 17:25:00.635 Status: dzVents: > 15:
2020-03-19 17:25:00.635 Status: dzVents: > data:
2020-03-19 17:25:00.635 Status: dzVents: > 1: 60
2020-03-19 17:25:00.635 Status: dzVents: > realtime: low_hum
2020-03-19 17:25:00.635 Status: dzVents: > 16:
2020-03-19 17:25:00.635 Status: dzVents: > 1: N
2020-03-19 17:25:00.635 Status: dzVents: > misc: imgwinddir
2020-03-19 17:25:00.636 Status: dzVents: > realtime: winddir
2020-03-19 17:25:00.636 Status: dzVents: > 17:
2020-03-19 17:25:00.636 Status: dzVents: > data:
2020-03-19 17:25:00.636 Status: dzVents: > 1: 0.8
2020-03-19 17:25:00.636 Status: dzVents: > _attr:
2020-03-19 17:25:00.636 Status: dzVents: > realtime: windspeed
2020-03-19 17:25:00.636 Status: dzVents: > 18:
2020-03-19 17:25:00.636 Status: dzVents: > 1: 1.7
2020-03-19 17:25:00.636 Status: dzVents: > realtime: windGust
2020-03-19 17:25:00.636 Status: dzVents: > 19:
2020-03-19 17:25:00.637 Status: dzVents: > data:
2020-03-19 17:25:00.637 Status: dzVents: > 1: 2.7
2020-03-19 17:25:00.637 Status: dzVents: > _attr:
2020-03-19 17:25:00.637 Status: dzVents: > realtime: high_windspeed
2020-03-19 17:25:00.637 Status: dzVents: > 20:
2020-03-19 17:25:00.637 Status: dzVents: > 1: 10.1
2020-03-19 17:25:00.637 Status: dzVents: > realtime: windchill
2020-03-19 17:25:00.637 Status: dzVents: > 21:
2020-03-19 17:25:00.638 Status: dzVents: > realtime: low_windchill
2020-03-19 17:25:00.638 Status: dzVents: > 22:
2020-03-19 17:25:00.638 Status: dzVents: > data:
2020-03-19 17:25:00.638 Status: dzVents: > 1: 4.9
2020-03-19 17:25:00.638 Status: dzVents: > _attr:
2020-03-19 17:25:00.638 Status: dzVents: > realtime: dew
2020-03-19 17:25:00.638 Status: dzVents: > 23:
2020-03-19 17:25:00.638 Status: dzVents: > 1: 7.1
2020-03-19 17:25:00.638 Status: dzVents: > realtime: high_dew
2020-03-19 17:25:00.638 Status: dzVents: > 24:
2020-03-19 17:25:00.639 Status: dzVents: > 1: 4.5
2020-03-19 17:25:00.639 Status: dzVents: > _attr:
2020-03-19 17:25:00.639 Status: dzVents: > realtime: low_dew
2020-03-19 17:25:00.639 Status: dzVents: > 25:
2020-03-19 17:25:00.639 Status: dzVents: > data:
2020-03-19 17:25:00.639 Status: dzVents: > 1: 1025.2
2020-03-19 17:25:00.639 Status: dzVents: > realtime: barometer
2020-03-19 17:25:00.639 Status: dzVents: > 26:
2020-03-19 17:25:00.639 Status: dzVents: > 1: 0.1
2020-03-19 17:25:00.639 Status: dzVents: > realtime: changebarometer
2020-03-19 17:25:00.640 Status: dzVents: > 27:
2020-03-19 17:25:00.640 Status: dzVents: > data:
2020-03-19 17:25:00.640 Status: dzVents: > 1: 1025.6
2020-03-19 17:25:00.640 Status: dzVents: > _attr:
2020-03-19 17:25:00.640 Status: dzVents: > realtime: high_barometer
2020-03-19 17:25:00.640 Status: dzVents: > 28:
2020-03-19 17:25:00.640 Status: dzVents: > 1: 1022.8
2020-03-19 17:25:00.640 Status: dzVents: > realtime: low_barometer
2020-03-19 17:25:00.640 Status: dzVents: > 29:
2020-03-19 17:25:00.640 Status: dzVents: > 1: 0.0
2020-03-19 17:25:00.641 Status: dzVents: > realtime: todaysrain
2020-03-19 17:25:00.641 Status: dzVents: > 30:
2020-03-19 17:25:00.641 Status: dzVents: > data:
2020-03-19 17:25:00.641 Status: dzVents: > 1: 0.0
2020-03-19 17:25:00.641 Status: dzVents: > _attr:
2020-03-19 17:25:00.641 Status: dzVents: > realtime: rain_rate
2020-03-19 17:25:00.641 Status: dzVents: > 31:
2020-03-19 17:25:00.641 Status: dzVents: > realtime: high_rain_rate
2020-03-19 17:25:00.641 Status: dzVents: > 32:
2020-03-19 17:25:00.642 Status: dzVents: > 1: 0.0
2020-03-19 17:25:00.642 Status: dzVents: > _attr:
2020-03-19 17:25:00.642 Status: dzVents: > realtime: storm_rate
2020-03-19 17:25:00.642 Status: dzVents: > 33:
2020-03-19 17:25:00.642 Status: dzVents: > data:
2020-03-19 17:25:00.642 Status: dzVents: > 1: m/s
2020-03-19 17:25:00.642 Status: dzVents: > units: windunit
2020-03-19 17:25:00.642 Status: dzVents: > 34:
2020-03-19 17:25:00.642 Status: dzVents: > 1: mm
2020-03-19 17:25:00.642 Status: dzVents: > units: rainunit
2020-03-19 17:25:00.642 Status: dzVents: > 35:
2020-03-19 17:25:00.643 Status: dzVents: > data:
2020-03-19 17:25:00.643 Status: dzVents: > 1: mm/hr-
2020-03-19 17:25:00.643 Status: dzVents: > _attr:
2020-03-19 17:25:00.643 Status: dzVents: > units: rateunit
2020-03-19 17:25:00.643 Status: dzVents: > 36:
2020-03-19 17:25:00.643 Status: dzVents: > 1: mb
2020-03-19 17:25:00.643 Status: dzVents: > units: barunit
2020-03-19 17:25:00.643 Status: dzVents: > 37:
2020-03-19 17:25:00.643 Status: dzVents: > 1: C
2020-03-19 17:25:00.644 Status: dzVents: > _attr:
2020-03-19 17:25:00.644 Status: dzVents: > units: tempunit
2020-03-19 17:25:00.644 Status: dzVents: > 38:
2020-03-19 17:25:00.644 Status: dzVents: > data:
2020-03-19 17:25:00.644 Status: dzVents: > 1: %
2020-03-19 17:25:00.644 Status: dzVents: > units: humunit
2020-03-19 17:25:00.644 Status: dzVents: > 39:
2020-03-19 17:25:00.644 Status: dzVents: > 1: 0.0
2020-03-19 17:25:00.644 Status: dzVents: > realtime: uv_index
2020-03-19 17:25:00.644 Status: dzVents: > 40:
2020-03-19 17:25:00.645 Status: dzVents: > data:
2020-03-19 17:25:00.645 Status: dzVents: > 1: 2044
2020-03-19 17:25:00.645 Status: dzVents: > _attr:
2020-03-19 17:25:00.645 Status: dzVents: > realtime: radiation
2020-03-19 17:25:00.645 Status: dzVents: Info: getXML: ------ Finished Test
Posted: Thursday 19 March 2020 21:06
by waaren
sailmich wrote: Thursday 19 March 2020 18:05
Script could look like this. Just comment the devices and updatelines you don't use.
Please feel free to ask if something is not clear.
return
on =
timer =
devices =
'triggerhulp',
httpResponses =
scriptVar,
logging =
marker = scriptVar,
local function wind2Degrees(direction)
if direction == 'N' then degrees = 360 end
if direction == 'NE' then degrees = 315 end
if direction == 'E' then degrees = 270 end
if direction == 'SE' then degrees = 225 end
if direction == 'S' then degrees = 180 end
if direction == 'SW' then degrees = 135 end
if direction == 'W' then degrees = 90 end
if direction == 'NW' then degrees = 45 end
return '-'
local function humidityStatus(temperature, humidity)
if humidity <= 30 then return dz.HUM_DRY
elseif humidity >= 70 then return dz.HUM_WET
elseif humidity >= 35 and
humidity <= 65 and
temperature >= 22 and
temperature <= 26 then return dz.HUM_COMFORTABLE
else return dz.HUM_NORMAL end
local function getData(data)
resultTable = dz.utils.fromXML(data).maintag.realtime
relevantData = {}
for index, record in ipairs(resultTable) do
-- dz.log((record.data._attr.realtime or record.data._attr.units) .. ': ' .. record.data[1],dz.log_DEBUG)
relevantData[(record.data._attr.realtime or record.data._attr.units)] = record.data[1]
return(relevantData)
function baroForecast(pressure) -- Return text
if pressure == nil then return nil -- Should not happen
elseif pressure < 966 then return dz.BARO_THUNDERSTORM
elseif pressure < 993 then return dz.BARO_CLOUDY_RAIN
elseif pressure < 1007 then return dz.BARO_CLOUDY
elseif pressure < 1013 then return dz.BARO_UNSTABLE
elseif pressure < 1033 then return dz.BARO_STABLE
return dz.BARO_SUNNY
local function updateDevices(data)
local rain = dz.devices('Regen') -- devicetype Rain
local temperature = dz.devices('WetterAußen') -- devicetype Temperature
local wind = dz.devices('Boen') -- devicetype Wind
local humidity = dz.devices('Humidity') -- devicetype Humidity
local barometer = dz.devices('Barometer') -- devicetype Barometer
temperature.updateTemperature(data.temp)
wind.updateWind(wind2Degrees(data.winddir),data.winddir, data.windspeed, data.windGust, data.temp, data.windchill)
rain.updateRain(data.rain_rate, data.todaysrain )
humidity.updateHumidity(tonumber(data.hum), humidityStatus(tonumber(data.temp), tonumber(data.hum)))
barometer.updateBarometer(data.barometer, baroForecast(tonumber(data.barometer)))
if item.ok then
-- dz.log(item, dz.LOG_DEBUG)
-- dz.utils.dumpTable(getData(item.data))
updateDevices(getData(item.data))
return
dz.openURL(
url = url,
method = 'GET',
Posted: Friday 20 March 2020 11:01
by sailmich
Thank you very much! Your code is working, I already modified your script to get more sensors. I have trouble to get just windgust, I want to use the gust to control my blinds.
local gust = dz.devices('Gust') --devicetype utility
gust.updateGust(data.windGust)
Domoticz log
- Spoiler: show
- 2020-03-20 10:59:00.902 Error: dzVents: Error: (3.0.1) getXML: An error occurred when calling event handler Wetterstation
2020-03-20 10:59:00.902 Error: dzVents: Error: (3.0.1) getXML: ...ticz/scripts/dzVents/generated_scripts/Wetterstation.lua:96: attempt to call a nil value (field 'updateGust')
Posted: Friday 20 March 2020 11:11
by waaren
sailmich wrote: Friday 20 March 2020 11:01
I have trouble to get just windgust.
The get part is already OK but updateGust() is not a known dzVents method. (see the
wiki )
How does the complete row of your device 'Gust' look like in the devices tab ?
Posted: Friday 20 March 2020 12:51
by sailmich
Got it because it is a custom sensor
gust.updateCustomSensor(data.windGust)
One more question. What is 'triggerhulp' for?
Re: Help needed get Data from Weatherstation Lua to dzvents [Solved]
Posted: Friday 20 March 2020 13:36
by waaren
sailmich wrote: Friday 20 March 2020 12:51
triggerhulp is a device I use for testing the script. I don't like to wait during development until the next full minute
So I use a virtual switch to trigger the script immediately after I corrected a typo or a bug. When the script is ready and tested you can remove that part.
Posted: Wednesday 25 March 2020 11:01
by sailmich
Is it possible to get a time stamp for the xml file? Sometimes my weatherstation lost the USB connection to my Rpi. In that case the domoticz script got old data but doesn't remark it. So I have the same datas on my dummy devices for hours:(
I know this code want work but it's just to show what I'm talking about.
If timestamp 5 times equal then
ssh reboot my weatherpi
Posted: Wednesday 25 March 2020 17:37
by waaren
sailmich wrote: Wednesday 25 March 2020 11:01
Yes, in below example I use station_time for that
You will have to change the ssh bootcommand in line 115 as I don't know what command you need for that.
return
on =
timer =
devices =
'triggerhulp',
httpResponses =
scriptVar,
logging =
marker = scriptVar,
data =
equalCounter = { initial = 0 },
stationTime = { initial = '' },
local function osCommand(cmd)
dz.log('Executing Command: ' .. cmd,dz.LOG_DEBUG)
local fileHandle = assert(io.popen(cmd .. ' 2>&1 || echo ::ERROR::', 'r'))
local commandOutput = assert(fileHandle:read('*a'))
local returnTable = {fileHandle:close()}
if commandOutput:find '::ERROR::' then -- something went wrong
dz.log('Error ==>> ' .. tostring(commandOutput:match('^(.*)%s+::ERROR::') or ' ... but no error message ' ) ,dz.LOG_DEBUG)
else -- all is fine!!
dz.log('ReturnCode: ' .. returnTable[3] .. '\ncommandOutput:\n' .. commandOutput, dz.LOG_DEBUG)
return commandOutput,returnTable[3] -- rc[3] contains returnCode
return '-'
humidity <= 65 and
relevantData = {}
if item.ok then
local rt = getData(item.data)
if dz.data.stationTime == rt.station_time then dz.data.equalCounter = dz.data.equalCounter + 1
dz.log('Received old data. Skipping this reading', dz.LOG_ERROR)
if dz.data.equalCounter > 5 then
dz.log('Received old data for >= 5 consecutive times. Booting weatherpi', dz.LOG_ERROR)
osCommand('ssh bootCommand')
return
dz.data.stationTime = rt.station_time
dz.data.equalCounter = 0
updateDevices(rt)
return
dz.openURL(
url = url,
method = 'GET',
Posted: Wednesday 25 March 2020 18:25
by sailmich
Hello waaren, thx again for your help.
in this line
I got an error
2020-03-25 18:25:01.209 Error: dzVents: Error: (3.0.1) getXML: ...ticz/scripts/dzVents/generated_scripts/Wetterstation.lua
attempt to index a nil value (field 'data')
Posted: Wednesday 25 March 2020 20:14
by waaren
sailmich wrote: Wednesday 25 March 2020 18:25
I got an error
Are you sure you copied / paste all new lines ?
I suspect that you missed the data part between logging = and execute =
Posted: Wednesday 25 March 2020 20:19
by sailmich
I try to understand the code and have some questions and remarks. I put them into your code. The error occur in the second line.
local rt = getData(item.data) --local rt should find and get all datas in xml? Why
--compare the two times if false then counter +1.
--Where is dz.data.stationTime from? I assume rt.station_time should be station_time from xml?
--rt.station_time because of line before?
Posted: Wednesday 25 March 2020 20:47
by sailmich
You are right. Know it's working! THX again for your help!
Posted: Wednesday 25 March 2020 20:53
by waaren
sailmich wrote: Wednesday 25 March 2020 20:19
No the other way around. When equal increase counter
