Help needed get Data from Weatherstation Lua to dzvents  [Solved]
sailmich
Post by sailmich »
Rpi 2
Z-Stick 5
Fine Offset weatherstation
Hi, I tried to change a lua script, to fetch data from my personal weatherstation, into dzvents.
Lua works
time = os.date("*t")
    if  ((time.min % 10)==0)  then
os.execute('sudo wget http://192.xxx.xxx.xx/weewx_pws.xml -O /path to/weewx_pws.xml')
local filename = "path to/weewx_pws.xml"
local line = ''
local temperature = 0
local tempdevice = ''
for line in io.lines(filename) do
   if string.find(line,"\"temp\"") then
      temperature=tonumber(string.match(line, "%-?%d+.?%d*"))
-- Update virtual device idx
tempdevice='idx|1|'..temperature..';0'
--print(tempdevice))
commandArray['UpdateDevice'] = tempdevice
dzvents need help
	    timer = {'every 1 minutes'}
	    --,devices = {'triggerhulp'}
	    execute = function(domoticz)
        -- check time of the day
        if domoticz.time.isDayTime then
         os.execute('sudo wget http://xxx.xxx.xxx.xx/weewx_pws.xml -O /path to/weewx_pws.xml')
            local filename = "/path to/weewx_pws.xml"
            local line = ''
--Update virtual device id , nval(0) sval (temp)
--tempdevice='208|1|'..temperature..';0'
tempdevice = domoticz.devices('WetterAußen')
till os.execute('sudo wget http://xxx.xxx.xxx.xx/weewx_pws.xml -O /path to/weewx_pws.xml') It's running.
I don't know how to get data from xml file and update my Temperature sensor.
THX for any help
Re: Help needed get Data from Weatherstation Lua to dzvents
sailmich wrote: Thursday 19 March 2020 12:06 Hi, I tried to change a lua script, to fetch data from my personal weatherstation, into dzvents.
THX for any help
This script will get the data from the weatherstation. If you can execute it once and share the loglines I can continue from there.
Also please state what version of domoticz / dzVents you use.
local url = 'http://xxx.xxx.xxx.xxx/weewx_pws.xml'
local scriptVar = 'getXML'
return
    on =
        timer =
            'every minute at daytime',
        devices =
            'triggerhulp',
        httpResponses =
            scriptVar,
    logging =
        level = domoticz.LOG_DEBUG,
        marker = scriptVar,
    execute = function(dz, item)
        if item.isHTTPResponse then
            if item.ok then
                dz.log(item,dz.LOG_DEBUG)
                dz.log('There was a problem handling the request', dz.LOG_ERROR)
                dz.log(item, dz.LOG_ERROR)
            return
            -- tempdevice = domoticz.devices('WetterAußen')
        dz.openURL(
            url = url,
            method = 'GET',
            callback = scriptVar,
sailmich
Post by sailmich »
Thanks for your quick reply!
I use newest domoticz beta 11.796 and dzvents 3.0.1.
I will check the script in a couple of minutes!
sailmich
Post by sailmich »
This is my domoticz log.
2020-03-19 13:33:00.638 Status: dzVents: Debug: Commands sent to Domoticz:
2020-03-19 13:33:00.638 Status: dzVents: Debug: - OpenURL = {["URL"]="http://xxx.xxx.xxx.xx/weewx_pws.xml", ["_trigger"]="getXML", ["method"]="GET"}
2020-03-19 13:33:00.638 Status: dzVents: Debug: =====================================================
2020-03-19 13:33:00.639 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-03-19 13:33:00.759 Status: dzVents: Debug: Dumping domoticz data to /home/pi/domoticz/scripts/dzVents/domoticzData.lua
2020-03-19 13:33:00.821 Status: dzVents: Debug: dzVents version: 3.0.1
2020-03-19 13:33:00.821 Status: dzVents: Debug: Event triggers:
2020-03-19 13:33:00.821 Status: dzVents: Debug: - HTTPResponse: getXML
2020-03-19 13:33:00.872 Status: dzVents: Info: Handling httpResponse-events for: "getXML"
2020-03-19 13:33:00.872 Status: dzVents: Info: getXML: ------ Start internal script: TemperaturDraußen: HTTPResponse: "getXML"
2020-03-19 13:33:00.874 Status: dzVents: Debug: getXML: {["ok"]=true, ["isScene"]=false, ["isVariable"]=false, ["isTimer"]=false, ["data"]="<?xml version="1.0" encoding="UTF-8" ?>
2020-03-19 13:33:00.874 <maintag>
2020-03-19 13:33:00.874 <!--MISC-->
2020-03-19 13:33:00.874 <misc><misc data="station_location">Hannover, Niedersachsen, Deutschland</misc></misc>
2020-03-19 13:33:00.874 <!--STATION DATA-->
2020-03-19 13:33:00.874 <realtime><data realtime="station_date">Thu, 19 Mar 2020</data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="station_time">13:30 CET</data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="sunrise">06:24:22</data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="sunset">18:33:14<!--sunsetTime--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="moonrise">04:56:48<!--moonriseTime--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="moonset">13:01:27<!--moonsetTime--></data></realtime>
2020-03-19 13:33:00.874 <!--TEMPERATURE-->
2020-03-19 13:33:00.874 <realtime><data realtime="temp">13.4<!--outsideTemp--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="high_temp">14.0<!--hiOutsideTemp--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="low_temp">10.7<!--lowOutsideTemp--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="heatindex">13.4<!--outsideHeatIndex--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="high_heatindex">14.0<!--hiHeatindex--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="inside_temp">25.0<!--inside_temp--></data></realtime>
2020-03-19 13:33:00.874 <!--HUMIDITY-->
2020-03-19 13:33:00.874 <realtime><data realtime="hum">62<!--outsideHumidity--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="high_hum">71<!--hiHumidity--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="low_hum">60<!--lowHumidity--></data></realtime>
2020-03-19 13:33:00.874 <!--WIND-->
2020-03-19 13:33:00.874 <realtime><data realtime="winddir" misc="imgwinddir">E<!--windDirection--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="windspeed">0.7<!--windSpeed--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="windGust">1.0<!--windGust--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="high_windspeed">2.0<!--hiWindSpeed--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="windchill">13.4<!--windChill--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="low_windchill">10.7<!--lowWindchill--></data></realtime>
2020-03-19 13:33:00.874 <!--DEWPOINT-->
2020-03-19 13:33:00.874 <realtime><data realtime="dew">6.3<!--outsideDewPt--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="high_dew">7.1<!--hiDewpoint--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="low_dew">4.5<!--lowDewpoint--></data></realtime>
2020-03-19 13:33:00.874 <!--BAROMETER-->
2020-03-19 13:33:00.874 <realtime><data realtime="barometer">1025.2<!--barometer--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="changebarometer">0.2<!--hourchangebarom--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="high_barometer">1025.6<!--hiBarometer--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="low_barometer">1022.8<!--lowBarometer--></data></realtime>
2020-03-19 13:33:00.874 <!--RAIN-->
2020-03-19 13:33:00.874 <realtime><data realtime="todaysrain">0.0<!--dailyRain--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="rain_rate">0.0<!--rainRate--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="high_rain_rate">0.0<!--hiRainRate--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="storm_rate">0.0<!--dailyRain--></data></realtime>
2020-03-19 13:33:00.874 <!--UNITS-->
2020-03-19 13:33:00.874 <realtime><data units="windunit">m/s<!--windUnit--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data units="rainunit">mm<!--rainUnit--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data units="rateunit">mm/hr-<!--rateUnit--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data units="barunit">mb<!--barUnit--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data units="tempunit">C<!--tempUnit--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data units="humunit">%<!--humUnit--></data></realtime>
2020-03-19 13:33:00.874 <!--CUSTOMDATA-->
2020-03-19 13:33:00.874 <realtime><data realtime="uv_index">0.0<!--uvIndex--></data></realtime>
2020-03-19 13:33:00.874 <realtime><data realtime="radiation">29638<!--radiation--></data></realtime>
2020-03-19 13:33:00.874 </maintag>
2020-03-19 13:33:00.874 ", ["isXML"]=false, ["_contentType"]="application/xml", ["isSecurity"]=false, ["statusText"]="OK", ["isDevice"]=false, ["isJSON"]=false, ["isSystem"]=false, ["statusCode"]=200, ["isHTTPResponse"]=true, ["isGroup"]=false, ["protocol"]="HTTP/1.1", ["isCustomEvent"]=false, ["isHardware"]=false, ["trigger"]="getXML", ["callback"]="getXML", ["baseType"]="httpResponse", ["headers"]={["Content-Length"]="3363", ["Accept-Ranges"]="bytes", ["Server"]="lighttpd/1.4.35", ["Last-Modified"]="Thu, 19 Mar 2020 12:31:01 GMT", ["ETag"]=""1082087333"", ["Date"]="Thu, 19 Mar 2020 12:33:00 GMT", ["Content-Type"]="application/xml"}}
2020-03-19 13:33:00.874 Status: dzVents: Info: getXML: ------ Finished TemperaturDraußen
2020-03-19 13:33:13.723 (ZWaveW) Temp (Boden Sued Temperature)
2020-03-19 13:33:13.834 Status: dzVents: Debug: Dumping domoticz data to /home/pi/domoticz/scripts/dzVents/domoticzData.lua
2020-03-19 13:33:13.929 Status: dzVents: Debug: Processing device-adapter for Boden Sued Temperature: Temperature device adapter
2020-03-19 13:33:13.929 Status: dzVents: Debug: dzVents version: 3.0.1
2020-03-19 13:33:13.929 Status: dzVents: Debug: Event triggers:
All the data's are there but how to get them out and update my sensors :?:
sailmich wrote: Thursday 19 March 2020 13:39 All the data's are there but how to get them out and update my sensors :?:
Next step:
converting the XML to a table.
Please execute this one and show the result + tell what value needs to go to what device (name or id and type/ subtype)
return
    on =
        timer =
        devices =
            'triggerhulp',
        httpResponses =
            scriptVar,
    logging =
        marker = scriptVar,
            if item.ok then
                --dz.log(item,dz.LOG_DEBUG)
                rt = dz.utils.fromXML(item.data)
                dz.utils.dumpTable(rt)
            return
        dz.openURL(
            url = url,
            method = 'GET',
sailmich
Post by sailmich »
This is what I got.
2020-03-19 14:31:00.645 Status: dzVents: > 23:
2020-03-19 14:31:00.645 Status: dzVents: > data:
2020-03-19 14:31:00.645 Status: dzVents: > 1: 7.1
2020-03-19 14:31:00.645 Status: dzVents: > _attr:
2020-03-19 14:31:00.645 Status: dzVents: > realtime: high_dew
2020-03-19 14:31:00.645 Status: dzVents: > 24:
2020-03-19 14:31:00.645 Status: dzVents: > 1: 4.5
2020-03-19 14:31:00.646 Status: dzVents: > realtime: low_dew
2020-03-19 14:31:00.646 Status: dzVents: > 25:
2020-03-19 14:31:00.646 Status: dzVents: > data:
2020-03-19 14:31:00.646 Status: dzVents: > 1: 1025.2
2020-03-19 14:31:00.646 Status: dzVents: > _attr:
2020-03-19 14:31:00.646 Status: dzVents: > realtime: barometer
2020-03-19 14:31:00.646 Status: dzVents: > 26:
2020-03-19 14:31:00.646 Status: dzVents: > 1: 0.0
2020-03-19 14:31:00.646 Status: dzVents: > realtime: changebarometer
2020-03-19 14:31:00.646 Status: dzVents: > 27:
2020-03-19 14:31:00.646 Status: dzVents: > 1: 1025.6
2020-03-19 14:31:00.646 Status: dzVents: > realtime: high_barometer
2020-03-19 14:31:00.646 Status: dzVents: > 28:
2020-03-19 14:31:00.646 Status: dzVents: > 1: 1022.8
2020-03-19 14:31:00.647 Status: dzVents: > _attr:
2020-03-19 14:31:00.647 Status: dzVents: > realtime: low_barometer
2020-03-19 14:31:00.647 Status: dzVents: > 29:
2020-03-19 14:31:00.647 Status: dzVents: > data:
2020-03-19 14:31:00.647 Status: dzVents: > 1: 0.0
2020-03-19 14:31:00.647 Status: dzVents: > realtime: todaysrain
2020-03-19 14:31:00.647 Status: dzVents: > 30:
2020-03-19 14:31:00.647 Status: dzVents: > realtime: rain_rate
2020-03-19 14:31:00.647 Status: dzVents: > 31:
2020-03-19 14:31:00.647 Status: dzVents: > realtime: high_rain_rate
2020-03-19 14:31:00.647 Status: dzVents: > 32:
2020-03-19 14:31:00.648 Status: dzVents: > realtime: storm_rate
2020-03-19 14:31:00.648 Status: dzVents: > 33:
2020-03-19 14:31:00.648 Status: dzVents: > data:
2020-03-19 14:31:00.648 Status: dzVents: > 1: m/s
2020-03-19 14:31:00.648 Status: dzVents: > _attr:
2020-03-19 14:31:00.648 Status: dzVents: > units: windunit
2020-03-19 14:31:00.648 Status: dzVents: > 34:
2020-03-19 14:31:00.648 Status: dzVents: > 1: mm
2020-03-19 14:31:00.648 Status: dzVents: > units: rainunit
2020-03-19 14:31:00.648 Status: dzVents: > 35:
2020-03-19 14:31:00.648 Status: dzVents: > 1: mm/hr-
2020-03-19 14:31:00.648 Status: dzVents: > units: rateunit
2020-03-19 14:31:00.648 Status: dzVents: > 36:
2020-03-19 14:31:00.648 Status: dzVents: > 1: mb
2020-03-19 14:31:00.648 Status: dzVents: > units: barunit
2020-03-19 14:31:00.649 Status: dzVents: > 37:
2020-03-19 14:31:00.649 Status: dzVents: > data:
2020-03-19 14:31:00.649 Status: dzVents: > 1: C
2020-03-19 14:31:00.649 Status: dzVents: > _attr:
2020-03-19 14:31:00.649 Status: dzVents: > units: tempunit
2020-03-19 14:31:00.649 Status: dzVents: > 38:
2020-03-19 14:31:00.649 Status: dzVents: > 1: %
2020-03-19 14:31:00.649 Status: dzVents: > units: humunit
2020-03-19 14:31:00.649 Status: dzVents: > 39:
2020-03-19 14:31:00.649 Status: dzVents: > 1: 0.0
2020-03-19 14:31:00.649 Status: dzVents: > realtime: uv_index
2020-03-19 14:31:00.649 Status: dzVents: > 40:
2020-03-19 14:31:00.649 Status: dzVents: > 1: 21558
2020-03-19 14:31:00.649 Status: dzVents: > realtime: radiation
2020-03-19 14:31:00.649 Status: dzVents: > misc:
2020-03-19 14:31:00.650 Status: dzVents: > misc:
2020-03-19 14:31:00.650 Status: dzVents: > 1: Hannover, Niedersachsen, Deutschland
2020-03-19 14:31:00.650 Status: dzVents: > _attr:
2020-03-19 14:31:00.650 Status: dzVents: > data: station_location
I don't get all data's as in the xml. I copied the domoticz log direct in Domoticz. Do you know where the location at my pi is, I can't find a log file for Domoticz.
xml
<!--STATION DATA-->
<realtime>
</realtime>
<realtime>
<data realtime="station_time">14:46 CET</data>
</realtime>
<realtime>
</realtime>
<realtime>
18:33:14
<!--sunsetTime-->
</data>
</realtime>
<realtime>
04:56:48
<!--moonriseTime-->
</data>
</realtime>
<realtime>
13:01:27
<!--moonsetTime-->
</data>
</realtime>
<!--TEMPERATURE-->
<realtime>
13.2
<!--outsideTemp-->
</data>
</realtime>
<realtime>
14.0
</data>
</realtime>
<realtime>
10.7
</data>
</realtime>
<realtime>
13.2
</data>
</realtime>
<realtime>
14.0
<!--hiHeatindex-->
</data>
</realtime>
<realtime>
24.7
<!--inside_temp-->
</data>
</realtime>
<!--HUMIDITY-->
<realtime>
62
</data>
</realtime>
<realtime>
71
<!--hiHumidity-->
</data>
</realtime>
<realtime>
60
<!--lowHumidity-->
</data>
</realtime>
<!--WIND-->
<realtime>
NNE
</data>
</realtime>
<realtime>
1.6
<!--windSpeed-->
</data>
</realtime>
<realtime>
2.7
<!--windGust-->
</data>
</realtime>
<realtime>
2.7
<!--hiWindSpeed-->
</data>
</realtime>
<realtime>
13.2
<!--windChill-->
</data>
</realtime>
<realtime>
10.7
<!--lowWindchill-->
</data>
</realtime>
<!--DEWPOINT-->
<realtime>
6.1
<!--outsideDewPt-->
</data>
</realtime>
<realtime>
7.1
<!--hiDewpoint-->
</data>
</realtime>
<realtime>
4.5
<!--lowDewpoint-->
</data>
</realtime>
<!--BAROMETER-->
<realtime>
1025.0
<!--barometer-->
</data>
</realtime>
<realtime>
-0.2
</data>
</realtime>
<realtime>
1025.6
<!--hiBarometer-->
</data>
</realtime>
<realtime>
1022.8
<!--lowBarometer-->
</data>
</realtime>
<!--RAIN-->
<realtime>
0.0
<!--dailyRain-->
</data>
</realtime>
<realtime>
0.0
<!--rainRate-->
</data>
</realtime>
<realtime>
0.0
<!--hiRainRate-->
</data>
</realtime>
<realtime>
0.0
<!--dailyRain-->
</data>
</realtime>
<!--UNITS-->
<realtime>
m/s
<!--windUnit-->
</data>
</realtime>
<realtime>
mm
<!--rainUnit-->
</data>
</realtime>
<realtime>
mm/hr-
<!--rateUnit-->
</data>
</realtime>
<realtime>
mb
<!--barUnit-->
</data>
</realtime>
<realtime>
C
<!--tempUnit-->
</data>
</realtime>
<realtime>
<!--humUnit-->
</data>
</realtime>
<!--CUSTOMDATA-->
<realtime>
0.0
<!--uvIndex-->
</data>
</realtime>
<realtime>
21320
<!--radiation-->
</data>
</realtime>
</maintag>
sailmich wrote: Thursday 19 March 2020 15:01 I don't get all data's as in the xml. I copied the domoticz log direct in Domoticz. Do you know where the location at my pi is, I can't find a log file for Domoticz.
The log file location is set in /etc/init.d/domoticz.sh in the
DAEMON_ARGS section.
I have these but you ports, location of logfile, etc could vary
DAEMON_ARGS="-daemon"
DAEMON_ARGS="$DAEMON_ARGS -daemonname $NAME -pidfile $PIDFILE"
DAEMON_ARGS="$DAEMON_ARGS -www 8084"
DAEMON_ARGS="$DAEMON_ARGS -sslwww 8443"
DAEMON_ARGS="$DAEMON_ARGS -log /var/log/domoticz.log"    # location of logfile
DAEMON_ARGS="$DAEMON_ARGS -loglevel  normal,status,error"
if you change something in this file you need a
sudo systemctl daemon-reload
sudo domoticz stop
sudo domoticz start
sailmich
Post by sailmich »
All data's are in the log :D
realtime:temp = idx208 WetterAußen
realtime:windGust =idx213 Boen
realtime:rain_rate =idx216 Regen
2020-03-19 17:25:00.376 Status: dzVents: Debug: =====================================================
2020-03-19 17:25:00.377 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-03-19 17:25:00.489 Status: dzVents: Debug: Dumping domoticz data to /home/pi/domoticz/scripts/dzVents/domoticzData.lua
2020-03-19 17:25:00.551 Status: dzVents: Debug: dzVents version: 3.0.1
2020-03-19 17:25:00.551 Status: dzVents: Debug: Event triggers:
2020-03-19 17:25:00.551 Status: dzVents: Debug: - HTTPResponse: getXML
2020-03-19 17:25:00.592 Status: dzVents: Info: Handling httpResponse-events for: "getXML"
2020-03-19 17:25:00.593 Status: dzVents: Info: getXML: ------ Start internal script: Test: HTTPResponse: "getXML"
2020-03-19 17:25:00.628 Status: dzVents: > maintag:
2020-03-19 17:25:00.629 Status: dzVents: > misc:
2020-03-19 17:25:00.629 Status: dzVents: > 1: Hannover, Niedersachsen, Deutschland
2020-03-19 17:25:00.629 Status: dzVents: > _attr:
2020-03-19 17:25:00.629 Status: dzVents: > data: station_location
2020-03-19 17:25:00.629 Status: dzVents: > realtime:
2020-03-19 17:25:00.629 Status: dzVents: > 1: Thu, 19 Mar 2020
2020-03-19 17:25:00.630 Status: dzVents: > realtime: station_date
2020-03-19 17:25:00.630 Status: dzVents: > 2:
2020-03-19 17:25:00.630 Status: dzVents: > data:
2020-03-19 17:25:00.630 Status: dzVents: > 1: 17:22 CET
2020-03-19 17:25:00.630 Status: dzVents: > _attr:
2020-03-19 17:25:00.630 Status: dzVents: > realtime: station_time
2020-03-19 17:25:00.630 Status: dzVents: > 3:
2020-03-19 17:25:00.630 Status: dzVents: > 1: 06:24:19
2020-03-19 17:25:00.630 Status: dzVents: > realtime: sunrise
2020-03-19 17:25:00.630 Status: dzVents: > 4:
2020-03-19 17:25:00.631 Status: dzVents: > 1: 18:33:17
2020-03-19 17:25:00.631 Status: dzVents: > _attr:
2020-03-19 17:25:00.631 Status: dzVents: > realtime: sunset
2020-03-19 17:25:00.631 Status: dzVents: > 5:
2020-03-19 17:25:00.631 Status: dzVents: > data:
2020-03-19 17:25:00.631 Status: dzVents: > 1: 04:56:45
2020-03-19 17:25:00.631 Status: dzVents: > realtime: moonrise
2020-03-19 17:25:00.631 Status: dzVents: > 6:
2020-03-19 17:25:00.631 Status: dzVents: > 1: 13:01:30
2020-03-19 17:25:00.631 Status: dzVents: > realtime: moonset
2020-03-19 17:25:00.631 Status: dzVents: > 7:
2020-03-19 17:25:00.632 Status: dzVents: > data:
2020-03-19 17:25:00.632 Status: dzVents: > 1: 10.1
2020-03-19 17:25:00.632 Status: dzVents: > _attr:
2020-03-19 17:25:00.632 Status: dzVents: > realtime: temp
2020-03-19 17:25:00.632 Status: dzVents: > 8:
2020-03-19 17:25:00.632 Status: dzVents: > 1: 14.0
2020-03-19 17:25:00.632 Status: dzVents: > realtime: high_temp
2020-03-19 17:25:00.632 Status: dzVents: > 9:
2020-03-19 17:25:00.633 Status: dzVents: > realtime: low_temp
2020-03-19 17:25:00.633 Status: dzVents: > 10:
2020-03-19 17:25:00.633 Status: dzVents: > data:
2020-03-19 17:25:00.633 Status: dzVents: > 1: 10.1
2020-03-19 17:25:00.633 Status: dzVents: > _attr:
2020-03-19 17:25:00.633 Status: dzVents: > realtime: heatindex
2020-03-19 17:25:00.633 Status: dzVents: > 11:
2020-03-19 17:25:00.633 Status: dzVents: > 1: 14.0
2020-03-19 17:25:00.633 Status: dzVents: > realtime: high_heatindex
2020-03-19 17:25:00.633 Status: dzVents: > 12:
2020-03-19 17:25:00.634 Status: dzVents: > data:
2020-03-19 17:25:00.634 Status: dzVents: > 1: 25.1
2020-03-19 17:25:00.634 Status: dzVents: > _attr:
2020-03-19 17:25:00.634 Status: dzVents: > realtime: inside_temp
2020-03-19 17:25:00.634 Status: dzVents: > 13:
2020-03-19 17:25:00.634 Status: dzVents: > 1: 70
2020-03-19 17:25:00.634 Status: dzVents: > realtime: hum
2020-03-19 17:25:00.634 Status: dzVents: > 14:
2020-03-19 17:25:00.635 Status: dzVents: > 1: 71
2020-03-19 17:25:00.635 Status: dzVents: > _attr:
2020-03-19 17:25:00.635 Status: dzVents: > realtime: high_hum
2020-03-19 17:25:00.635 Status: dzVents: > 15:
2020-03-19 17:25:00.635 Status: dzVents: > data:
2020-03-19 17:25:00.635 Status: dzVents: > 1: 60
2020-03-19 17:25:00.635 Status: dzVents: > realtime: low_hum
2020-03-19 17:25:00.635 Status: dzVents: > 16:
2020-03-19 17:25:00.635 Status: dzVents: > 1: N
2020-03-19 17:25:00.635 Status: dzVents: > misc: imgwinddir
2020-03-19 17:25:00.636 Status: dzVents: > realtime: winddir
2020-03-19 17:25:00.636 Status: dzVents: > 17:
2020-03-19 17:25:00.636 Status: dzVents: > data:
2020-03-19 17:25:00.636 Status: dzVents: > 1: 0.8
2020-03-19 17:25:00.636 Status: dzVents: > _attr:
2020-03-19 17:25:00.636 Status: dzVents: > realtime: windspeed
2020-03-19 17:25:00.636 Status: dzVents: > 18:
2020-03-19 17:25:00.636 Status: dzVents: > 1: 1.7
2020-03-19 17:25:00.636 Status: dzVents: > realtime: windGust
2020-03-19 17:25:00.636 Status: dzVents: > 19:
2020-03-19 17:25:00.637 Status: dzVents: > data:
2020-03-19 17:25:00.637 Status: dzVents: > 1: 2.7
2020-03-19 17:25:00.637 Status: dzVents: > _attr:
2020-03-19 17:25:00.637 Status: dzVents: > realtime: high_windspeed
2020-03-19 17:25:00.637 Status: dzVents: > 20:
2020-03-19 17:25:00.637 Status: dzVents: > 1: 10.1
2020-03-19 17:25:00.637 Status: dzVents: > realtime: windchill
2020-03-19 17:25:00.637 Status: dzVents: > 21:
2020-03-19 17:25:00.638 Status: dzVents: > realtime: low_windchill
2020-03-19 17:25:00.638 Status: dzVents: > 22:
2020-03-19 17:25:00.638 Status: dzVents: > data:
2020-03-19 17:25:00.638 Status: dzVents: > 1: 4.9
2020-03-19 17:25:00.638 Status: dzVents: > _attr:
2020-03-19 17:25:00.638 Status: dzVents: > realtime: dew
2020-03-19 17:25:00.638 Status: dzVents: > 23:
2020-03-19 17:25:00.638 Status: dzVents: > 1: 7.1
2020-03-19 17:25:00.638 Status: dzVents: > realtime: high_dew
2020-03-19 17:25:00.638 Status: dzVents: > 24:
2020-03-19 17:25:00.639 Status: dzVents: > 1: 4.5
2020-03-19 17:25:00.639 Status: dzVents: > _attr:
2020-03-19 17:25:00.639 Status: dzVents: > realtime: low_dew
2020-03-19 17:25:00.639 Status: dzVents: > 25:
2020-03-19 17:25:00.639 Status: dzVents: > data:
2020-03-19 17:25:00.639 Status: dzVents: > 1: 1025.2
2020-03-19 17:25:00.639 Status: dzVents: > realtime: barometer
2020-03-19 17:25:00.639 Status: dzVents: > 26:
2020-03-19 17:25:00.639 Status: dzVents: > 1: 0.1
2020-03-19 17:25:00.639 Status: dzVents: > realtime: changebarometer
2020-03-19 17:25:00.640 Status: dzVents: > 27:
2020-03-19 17:25:00.640 Status: dzVents: > data:
2020-03-19 17:25:00.640 Status: dzVents: > 1: 1025.6
2020-03-19 17:25:00.640 Status: dzVents: > _attr:
2020-03-19 17:25:00.640 Status: dzVents: > realtime: high_barometer
2020-03-19 17:25:00.640 Status: dzVents: > 28:
2020-03-19 17:25:00.640 Status: dzVents: > 1: 1022.8
2020-03-19 17:25:00.640 Status: dzVents: > realtime: low_barometer
2020-03-19 17:25:00.640 Status: dzVents: > 29:
2020-03-19 17:25:00.640 Status: dzVents: > 1: 0.0
2020-03-19 17:25:00.641 Status: dzVents: > realtime: todaysrain
2020-03-19 17:25:00.641 Status: dzVents: > 30:
2020-03-19 17:25:00.641 Status: dzVents: > data:
2020-03-19 17:25:00.641 Status: dzVents: > 1: 0.0
2020-03-19 17:25:00.641 Status: dzVents: > _attr:
2020-03-19 17:25:00.641 Status: dzVents: > realtime: rain_rate
2020-03-19 17:25:00.641 Status: dzVents: > 31:
2020-03-19 17:25:00.641 Status: dzVents: > realtime: high_rain_rate
2020-03-19 17:25:00.641 Status: dzVents: > 32:
2020-03-19 17:25:00.642 Status: dzVents: > 1: 0.0
2020-03-19 17:25:00.642 Status: dzVents: > _attr:
2020-03-19 17:25:00.642 Status: dzVents: > realtime: storm_rate
2020-03-19 17:25:00.642 Status: dzVents: > 33:
2020-03-19 17:25:00.642 Status: dzVents: > data:
2020-03-19 17:25:00.642 Status: dzVents: > 1: m/s
2020-03-19 17:25:00.642 Status: dzVents: > units: windunit
2020-03-19 17:25:00.642 Status: dzVents: > 34:
2020-03-19 17:25:00.642 Status: dzVents: > 1: mm
2020-03-19 17:25:00.642 Status: dzVents: > units: rainunit
2020-03-19 17:25:00.642 Status: dzVents: > 35:
2020-03-19 17:25:00.643 Status: dzVents: > data:
2020-03-19 17:25:00.643 Status: dzVents: > 1: mm/hr-
2020-03-19 17:25:00.643 Status: dzVents: > _attr:
2020-03-19 17:25:00.643 Status: dzVents: > units: rateunit
2020-03-19 17:25:00.643 Status: dzVents: > 36:
2020-03-19 17:25:00.643 Status: dzVents: > 1: mb
2020-03-19 17:25:00.643 Status: dzVents: > units: barunit
2020-03-19 17:25:00.643 Status: dzVents: > 37:
2020-03-19 17:25:00.643 Status: dzVents: > 1: C
2020-03-19 17:25:00.644 Status: dzVents: > _attr:
2020-03-19 17:25:00.644 Status: dzVents: > units: tempunit
2020-03-19 17:25:00.644 Status: dzVents: > 38:
2020-03-19 17:25:00.644 Status: dzVents: > data:
2020-03-19 17:25:00.644 Status: dzVents: > 1: %
2020-03-19 17:25:00.644 Status: dzVents: > units: humunit
2020-03-19 17:25:00.644 Status: dzVents: > 39:
2020-03-19 17:25:00.644 Status: dzVents: > 1: 0.0
2020-03-19 17:25:00.644 Status: dzVents: > realtime: uv_index
2020-03-19 17:25:00.644 Status: dzVents: > 40:
2020-03-19 17:25:00.645 Status: dzVents: > data:
2020-03-19 17:25:00.645 Status: dzVents: > 1: 2044
2020-03-19 17:25:00.645 Status: dzVents: > _attr:
2020-03-19 17:25:00.645 Status: dzVents: > realtime: radiation
2020-03-19 17:25:00.645 Status: dzVents: Info: getXML: ------ Finished Test
sailmich wrote: Thursday 19 March 2020 18:05 All data's are in the log :D
Script could look like this. Just comment the devices and updatelines you don't use.
Please feel free to ask if something is not clear.
return
    on =
        timer =
        devices =
            'triggerhulp',
        httpResponses =
            scriptVar,
    logging =
        marker = scriptVar,
        local function wind2Degrees(direction)
            if direction == 'N' then degrees = 360 end
            if direction == 'NE' then degrees = 315 end
            if direction == 'E' then degrees = 270 end
            if direction == 'SE' then degrees = 225 end
            if direction == 'S' then degrees = 180 end
            if direction == 'SW' then degrees = 135 end
            if direction == 'W' then degrees = 90 end
            if direction == 'NW' then degrees = 45 end
            return '-'
        local function humidityStatus(temperature, humidity)
            if humidity <= 30 then return dz.HUM_DRY
            elseif humidity >= 70 then return dz.HUM_WET
            elseif  humidity >= 35 and
                    humidity <= 65 and
                    temperature >= 22 and
                    temperature <= 26 then return dz.HUM_COMFORTABLE
            else return dz.HUM_NORMAL end
        local function getData(data)
            resultTable = dz.utils.fromXML(data).maintag.realtime
            relevantData = {}
            for index, record in ipairs(resultTable) do
                -- dz.log((record.data._attr.realtime or record.data._attr.units) .. ': ' .. record.data[1],dz.log_DEBUG)
                relevantData[(record.data._attr.realtime or record.data._attr.units)] =  record.data[1]
            return(relevantData)
        function baroForecast(pressure)                                               -- Return text
            if pressure == nil          then return nil                                               -- Should not happen
                elseif pressure < 966   then return dz.BARO_THUNDERSTORM
                elseif pressure < 993   then return dz.BARO_CLOUDY_RAIN
                elseif pressure < 1007  then return dz.BARO_CLOUDY
                elseif pressure < 1013  then return dz.BARO_UNSTABLE
                elseif pressure < 1033  then return dz.BARO_STABLE
            return dz.BARO_SUNNY
        local function updateDevices(data)
            local rain = dz.devices('Regen')                   -- devicetype Rain
            local temperature = dz.devices('WetterAußen')      -- devicetype Temperature
            local wind = dz.devices('Boen')                    -- devicetype Wind
            local humidity = dz.devices('Humidity')            -- devicetype Humidity
            local barometer = dz.devices('Barometer')          -- devicetype Barometer
            temperature.updateTemperature(data.temp)
            wind.updateWind(wind2Degrees(data.winddir),data.winddir, data.windspeed, data.windGust, data.temp, data.windchill)
            rain.updateRain(data.rain_rate, data.todaysrain )
            humidity.updateHumidity(tonumber(data.hum), humidityStatus(tonumber(data.temp), tonumber(data.hum)))
            barometer.updateBarometer(data.barometer, baroForecast(tonumber(data.barometer)))
            if item.ok then
                -- dz.log(item, dz.LOG_DEBUG)
                -- dz.utils.dumpTable(getData(item.data))
                updateDevices(getData(item.data))
            return
        dz.openURL(
            url = url,
            method = 'GET',
sailmich
Post by sailmich »
Thank you very much! Your code is working, I already modified your script to get more sensors. I have trouble to get just windgust, I want to use the gust to control my blinds.
local gust = dz.devices('Gust')                     --devicetype utility
gust.updateGust(data.windGust)
Domoticz log
2020-03-20 10:59:00.902 Error: dzVents: Error: (3.0.1) getXML: An error occurred when calling event handler Wetterstation
2020-03-20 10:59:00.902 Error: dzVents: Error: (3.0.1) getXML: ...ticz/scripts/dzVents/generated_scripts/Wetterstation.lua:96: attempt to call a nil value (field 'updateGust')
sailmich wrote: Friday 20 March 2020 11:01 I have trouble to get just windgust.
The get part is already OK but updateGust() is not a known dzVents method. (see the wiki )
How does the complete row of your device 'Gust' look like in the devices tab ?
sailmich
Post by sailmich »
Got it because it is a custom sensor
gust.updateCustomSensor(data.windGust)
One more question. What is 'triggerhulp' for?
Re: Help needed get Data from Weatherstation Lua to dzvents  [Solved]
sailmich wrote: Friday 20 March 2020 12:51 One more question. What is 'triggerhulp' for?
triggerhulp is a device I use for testing the script. I don't like to wait during development until the next full minute :D So I use a virtual switch to trigger the script immediately after I corrected a typo or a bug. When the script is ready and tested you can remove that part.
sailmich
Post by sailmich »
Is it possible to get a time stamp for the xml file? Sometimes my weatherstation lost the USB connection to my Rpi. In that case the domoticz script got old data but doesn't remark it. So I have the same datas on my dummy devices for hours:(
I know this code want work but it's just to show what I'm talking about.
If timestamp 5 times equal then
ssh reboot my weatherpi
sailmich wrote: Wednesday 25 March 2020 11:01 Is it possible to get a time stamp for the xml file?
Yes, in below example I use station_time for that
You will have to change the ssh bootcommand in line 115 as I don't know what command you need for that.
return
    on =
        timer =
        devices =
            'triggerhulp',
        httpResponses =
            scriptVar,
    logging =
        marker = scriptVar,
    data =
        equalCounter = { initial = 0 },
        stationTime = { initial  = '' },
        local function osCommand(cmd)
            dz.log('Executing Command: ' .. cmd,dz.LOG_DEBUG)
            local fileHandle = assert(io.popen(cmd .. ' 2>&1 || echo ::ERROR::', 'r'))
            local commandOutput = assert(fileHandle:read('*a'))
            local returnTable = {fileHandle:close()}
            if commandOutput:find '::ERROR::' then     -- something went wrong
               dz.log('Error ==>> ' .. tostring(commandOutput:match('^(.*)%s+::ERROR::') or ' ... but no error message ' ) ,dz.LOG_DEBUG)
            else -- all is fine!!
                dz.log('ReturnCode: ' .. returnTable[3] .. '\ncommandOutput:\n' .. commandOutput, dz.LOG_DEBUG)
            return commandOutput,returnTable[3] -- rc[3] contains returnCode
            return '-'
                    humidity <= 65 and
            relevantData = {}
            if item.ok then
                local rt = getData(item.data)
                if dz.data.stationTime == rt.station_time then dz.data.equalCounter = dz.data.equalCounter + 1
                    dz.log('Received old data. Skipping this reading', dz.LOG_ERROR)
                    if dz.data.equalCounter > 5 then
                        dz.log('Received old data for >= 5 consecutive times. Booting weatherpi', dz.LOG_ERROR)
                        osCommand('ssh bootCommand')
                    return
                dz.data.stationTime = rt.station_time
                dz.data.equalCounter = 0
                updateDevices(rt)
            return
        dz.openURL(
            url = url,
            method = 'GET',
sailmich
Post by sailmich »
Hello waaren, thx again for your help.
in this line
I got an error
2020-03-25 18:25:01.209 Error: dzVents: Error: (3.0.1) getXML: ...ticz/scripts/dzVents/generated_scripts/Wetterstation.lua:100: attempt to index a nil value (field 'data')
sailmich wrote: Wednesday 25 March 2020 18:25 I got an error
Are you sure you copied / paste all new lines ?
I suspect that you missed the data part between logging = and execute =
sailmich
Post by sailmich »
I try to understand the code and have some questions and remarks. I put them into your code. The error occur in the second line.
local rt = getData(item.data) --local rt should find and get all datas in xml? Why
                    --compare the two times if false then counter +1.
                    --Where is dz.data.stationTime from? I assume rt.station_time should be station_time from xml?
                    --rt.station_time because of line before?
sailmich
Post by sailmich »
:oops: You are right. Know it's working! THX again for your help!
sailmich wrote: Wednesday 25 March 2020 20:19 I try to understand the code and have some questions and remarks. I put them into your code. The error occur in the second line.
No the other way around. When equal increase counter
